Tyre & Alloy wheel Section Everything to do with footwear for your car!
Thread Tools
Old 15th June 2007, 04:45   #1 (permalink)
aah78's Avatar
Arrow Land Rover LR3 tyre replacement
the 2005 Land Rover LR3 (Discovery 3, if you prefer) came equipped with the Goodyear Wrangler HP All-Season 255/60R18 M+S 112V tires as OE.
more info located here -> Goodyear Tires.
now, while these tyres provide a decent ride and good handling on-road, they are utterly useless off-road. they're also prone to premature wear and tear in normal highway driving.
people have had worn tyres begining from 7500 miles and probably the most mileage anyone has got on these is around 30,000 miles.
regular rotation doesn't help. Land Rover has revised the wheel alignment spec but nobody has confirmed whether it's a suspension issue or the tyre is bad, in general.
they're expensive tyres - each costing around $230.
earlier on some one had slashed one of my tyres while i'd parked overnight on the streets of New York and it had to be changed.
after 38,000 miles these tyres have been reduced to racing slicks!
here are a few pictures - just to get an idea regarding the abnormal tread-wear. the rear passenger side tyre has born the brunt of it. the rear driver side tyre is the best of the lot as it's around 10,000 miles younger than the rest (this replaced the slashed tyre).
Front Driver - Side View
Front Driver - Front View
Front Passenger - Front View
Rear Driver - Front View
Rear Passenger - Front View
Rear Passenger - Rear View
replacing them was Very Urgent & Very Necessary, but getting the same tyres wasn't an option!
Tire Rack - is an excellent choice for buying tyres at a much lower rate than you would get at your dealer or a tyre store.
after going through a lot of reviews and price considerations I've decided to give the AVON Tech ST 265/60SR18 M+S 114S tyres a try. they're rated for a slower speed but have good reviews overall.
AVON Tyres Ltd. is a UK based company that specializes in Performance tyres for track use and Motorcycle tyres. they've tied up with Cooper Tires to manufacture their tyres in the US. selling rights belong exclusively to Tire Rack.
i've got an upsize for more than $100/tyre less than the Goodyears'. will get them fit tommorrow. hoping for an improvement! we'll see how things go....
__________________
Ein bißchen Frieden
aah78 is offline   Reply With Quote
Old 15th June 2007, 05:51   #2 (permalink)
Mpower's Avatar
Seems like you are having a severe wheel alignment issue (positive camber) on your rear pass side. Get it corrected otherwise it will chew up your new Avons.
Independent rear suspensions are new to Landrover and looks like they are struggling.
EDIT: check this out, a class action lawsuit is in progress...suggest you jump on the bandwagon
Loud Land Rovers land company in class-action lawsuit - Autoblog
__________________
The difference between the men and the boys....................is the speed of their toys.
Mpower is online now   Reply With Quote
Old 15th June 2007, 22:37   #3 (permalink)
aah78's Avatar
the wheel alignment was off, no doubts and changing the spec did help but the tyres were long gone.
i had had alignment done twice in 2 months to no avail with the original spec.
just had the new tyres fit. drives much better - which is to be expected on new tyres. will see how they hold up in the long run. i'll put up pictures over the weekend.
i've heard about the lawsuit - have gone through most of the terms and conditions but i haven't made up my mind whether to go for it.
__________________
Ein bißchen Frieden
Old 16th June 2007, 01:54   #4 (permalink)
iraghava's Avatar
It is certainly an alignment issue which screwed up your tyres. Maybe you should jump on to the bandwagon and join the people suing.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Old 20th June 2007, 03:18   #5 (permalink)
aah78's Avatar
Default AVON Tech ST 265/60R16 M+S 114S
here's a couple of pictures with the new tyres!
Rear Driver
Front Driver
the huge gap in the wheel well is due to the car being in Off-Road mode.
__________________
Ein bißchen Frieden
Old 20th June 2007, 13:29   #6 (permalink)
V-16's Avatar
The Avons look great, Incidently, Avons were OEs on the pre BMW takeover Rolls Royces and Bentleys. Hope your alignment issues were sorted out. Enjoy the new shoes.
__________________
SINGH IS KING!!!!
V-16 is offline   Reply With Quote
Thread Tools
Tyre needed for Land Rover. SirAlec Tyre & Alloy wheel Section 12 6th August 2008 21:25
What should I do with my Land Rover Sport? jkdas Shifting gears 5 25th July 2008 23:31
Pics: Silver Land Rover Range Rover SE Gordon Super-Cars & Imports in India 35 4th April 2007 14:33
A Land Rover speciality.....? islero Technical Stuff 15 6th July 2006 15:18
Is the all new Land Rover LR2 a replacement for the freelander? 1Day The International Automotive Scene 2 27th June 2006 20:29
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458
