Old 23rd March 2007, 18:30   #16
drifter's Avatar
Thanked: 13 Times
No some bull**** about release order and registration drama at rto.
Drifter
drifter is offline   Reply With Quote
Old 23rd March 2007, 18:35   #17
Su-47's Avatar
Thanked: 91 Times
Originally Posted by Godfather View Post
Su-47 .. Which dealer have you booked your vehicle from??
If it is Prerana then you will not have any issues with the warranties..Trust me on this.. The owner himself has a Dicor with huge wheels.(Also happens to be one of my close friends). also my car is serviced by Prerana though i bought it from Concorde.
Godfather
Yep, its Prerana. And, yes the sales guy later clarified that there wont be an issue with the warranty.
On tyres: I will get Yokos only after 15 days. So, I will get to experience the Bridgestones for some time!
Cheers,
Su-47
Su-47 is offline   Reply With Quote
Old 23rd March 2007, 18:45   #18
iraghava's Avatar
Thanked: 154 Times
Of late I'm seeing all new dicors with Apollo HAWKZ....
Apollo must be offering them to TATA at dirt cheap prices!!
That might seriously dent the resale of your Bridgestones, unless you have a prior understanding with your tyre dealer.
Old 23rd March 2007, 19:07   #19
Godfather's Avatar
Thanked: 65 Times
Cheers,
Su-47
I got the tires changed immediately.. Got a very good rate.. If you use them then the resale drops.. In turn you will have to shell out more..
What my point here is that if you are anyway going to change the tires..change them the next day...make sure that you dont even cross 100Km mark.. and get used to driving on the new set itself..
Godfather
Godfather is offline   Reply With Quote
Old 27th March 2007, 09:50   #20
pogusingh's Avatar
Godfather
Please excuse me for the novice query. But I assume all the tyres being talked about as the replacement of the original TATA provided tyres are the tubeless one. Is this assumption correct?
regards
POGU
pogusingh is offline   Reply With Quote
Old 27th March 2007, 10:01   #21
kpzen's Avatar
Thanked: 1,617 Times
regards
POGU
No Godfather is talking about aftermarket fittment tyres...
He replaced his stock tyres given by TATA with Hankook Dynamic 255/65 16"
Old 27th March 2007, 11:26   #22
Su-47's Avatar
Thanked: 91 Times
Default Rim width..
Does anyone know the rim-width of a stock steel wheel on safari? The e-brochure of safari lists the rim dimensions as 6.0Jx16. I am hoping that the e-brochure is old and they have changed it to 7".
Why am I asking this: Most 255-wide tyres requires a rim wider than 6". For example: Michelin Synchrone: 255/65 R16 has an approved width of 7.0" - 9.0", with 8" listed as optimum. (source: Michelin Australia)
Thanks,
Su-47
Old 27th March 2007, 12:11   #23
I don't know about the stock steel wheels but the 4x4 version comes with 5 nos. 6.5J x 16 alloy wheels
dicorex4x4 is offline   Reply With Quote
Old 27th March 2007, 15:17   #24
Godfather's Avatar
Thanked: 65 Times
regards
POGU
Yes.. I have changed the Tires to Tubeless one's.. I got Bridgestone Duelers tube type.. The reason i went in for the change are
1. Wider tires = More road grip + control
2. Tubeless Tires = No headaches of immediate punchers.. Imagine trying to Jack up a Safari and trying to change the tire on busy Bangalore roads
3. Better looks
Godfather
Old 27th March 2007, 15:19   #25
Godfather's Avatar
Thanked: 65 Times
Even the LX rim's are 6.5J x 16". All the tires size are same be it 4x4 or a 2WD
Godfather
Old 27th March 2007, 20:48   #26
pogusingh's Avatar
Godfather
Godfather
I browsed website of bridgestone and came across the following
Bridgestone India Private Limited
Is this the tubeless one that you chose?
POGU
Old 27th March 2007, 21:02   #27
Godfather's Avatar
Thanked: 65 Times
Godfather
POGU
I think you are confused here.. I had got Bridgestones Duelers (TubeTypr) radials from company as stock tires..
Which later on i changed to Hankook Dynamics 255 / 65 16"
I dont have the stock company radials anymore..
Godfather
Old 27th March 2007, 22:10   #28
pogusingh's Avatar
Godfather
Thanks Godfather for the clarification. Personally I dont like wider tyres on the DICOR but I understand your point about the road grip as well
Slightly out of context( for this thread ) query, but has some DICOR owner tried his hand on upgrading the interiors/upholstery of the DICOR. If yes can myself be pointed to the right thread
POGU
Old 30th March 2007, 11:19   #29
Su-47's Avatar
Thanked: 91 Times
Default Welcome Safari.
Gents,
Got delivery of beautiful Silver-Safari on Tuesday evening.
Mr. Murphy has decided to interfere and I've been crushed under work-pressure. Haven't been able to drive it much :(.
Tomorrow should be a little better. I will take it out to add a couple of accessories:
- Tyre change to Michelin 4x4 Synchrone (highway + light offroading).
- ICE: Not decided yet! ( May be Alpine/Pioneer HU + JBL 6" on all four doors. Thats it! )
- Sunfilm: Not decided again. Need something in light shade with decent heat-blocking performance. Howz LLumar Platinum?
- Rear visibility improvement: Suggestions?? How about a mirror which is mounted on top of the rear glass? I think that it would be helpful to see the rear-bottom of car while reversing..
Gotta be back at work! Will try to write about the buying experience etc. later.
Cheers,
Su-47
Old 30th March 2007, 11:48   #30
iraghava's Avatar
Thanked: 154 Times
Congratulations on your new car SU!!!
Excellent choice, they are good tyres. Slightly expensive but worth it.
That's a good choice again!
Try LLumar or 3M both are very good.
Fiat Palio : Tyre & wheel upgrade thread shahmotors Tyre & Alloy wheel Section 637 26th March 2017 12:56
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 10 29th August 2016 17:08
Tata Bolt : Tyre & wheel upgrade thread narayan Tyre & Alloy wheel Section 11 11th September 2015 18:36
Tata Indigo Manza : Tyre & wheel upgrade thread -NUT-case Tyre & Alloy wheel Section 99 15th June 2015 19:59
