Old 21st March 2012, 09:17   #601
josepeter's Avatar
Thanked: 547 Times
Default re: Tata Safari : Tyre & wheel upgrade thread
I have heard that the better riding tyres ( like Yokos) are not a good bet in stock size. Apparently this is because of the softer sidewalls which causes them to burst in high load conditions. I have heard this for more than one of my friends running Yokos in stock size.
So i believe one should go for the next upsize when selecting such tyres; the extra volume of air should take care of stressful situations under load.
josepeter is offline   Reply With Quote
Old 21st March 2012, 11:00   #602
Thanked: 245 Times
Originally Posted by Irish View Post
Thanks to all for the advice!
I agree that Storme is a refined product by TATA but following are the reasons (my own views) for not waiting it's launch:
  • Have been waiting for more than 8-10 months but still there is NO confirmation on Storme launch date
  • Can't wait for few more months
  • TATAs have a history of providing manufacturing defects / niggles in the first year of launch
  • Current Safari has got better looks than the Storme
  • Price difference will be more than 2 lakhs
I have waited so much and now I dont have patience also because of excise duty hike.
Cheers!
Irish
Its expected around mid-year and the excise duty is already applicable for vehicles coming out from 16th March onwards, unless someone has an older stock of the variant and colour you need.
Old 22nd March 2012, 01:02   #603
himavanth_m's Avatar
Thanked: 269 Times
It is time for Replacing the tyres on my Safari 4x4 and I would like some advice on the same.
My current Bridgestone H/T duellers lasted 63k kms and I had one tyre blast with this tyre recently at 80kmph due to a sidewall failure due to a stone on the highway. Below is pic of tyre after blast
Tata Safari : Tyre & wheel upgrade thread-img_1376.jpg
Apart from this incident, they did a good job for me.
My usage pattern is 80% highway and 20% rocky and non existent roads in muddy and rocky areas. When on Highway, I usually drive for long periods like 12 hours continuous without stops but not at too much high speeds ( I usually cruise around 80-100kmph mark).
Based on this usage pattern, I am looking for a tyre which has
1. Strong side wall
2. Hard compound as I want the tyres to last another 50-60k kms atleast.
So my question is
1. Do I need to buy A/T tyres?
So far the H/Ts did a good job for me, but I am planning to do Leh and Sikkim sometime in the near future.
2. Based on my usage pattern which would be the best choice for me to go for?
I am completely new to the tyre selection process. So T-bhpians help on this would be greatly helpful
himavanth_m is offline   Reply With Quote
Old 23rd March 2012, 07:32   #604
sumannandy's Avatar
Thanked: 219 Times
Go for a Michelin A/T, I am a highly satisfied user of the tire.
Earlier I used Bridgestone and it started giving troubles only after 60k kms.
sumannandy is offline   (1) Thanks Reply With Quote
Old 23rd March 2012, 12:11   #605
Thanked: 269 Times
Do Michelin A/Ts last long? And does it have a really strong side wall?
What is the approximate cost I can expect for Michelin A/T tyres?
And since you are using it, can you also comment on how long the tyres will last?
Old 23rd March 2012, 14:55   #606
sumannandy's Avatar
Thanked: 219 Times
I think it would last as much as the bridgestones that I had earlier. Its already 40k and I think still 1/3rd tread left.
I have driven it over a variety of terrains and never was disappointed. Good comfort, never had any issues, only one puncture where it was flat. I had some issues with the valve pin/neck though, but that might not be anything to do with the tire as such.
sumannandy is offline   Reply With Quote
Old 15th April 2012, 21:44   #607
Rahulk76's Avatar
Thanked: 204 Times
My BfGoodrich a/t tires are loosing air to the tune of 5 psi a week. I got the tires inspected and all the valves are nice n fine. No punctures no nothin..
Any ideas ?
They are a year old
Rahul
Rahulk76 is offline   Reply With Quote
Old 17th April 2012, 15:19   #608
Thanked: 269 Times
I have finally shortlisted the following. Which one should I choose?
BFGoodrich Long Trail T/A tour
Bridgestone Dueler D689
Goodyear Wrangler HP AW
Please do not suggest any other tyres. My only contenders are the above three.
As I have mentioned before, I do not drive in extreme rocky and rough conditions often where tyres are tested to the limits. My main criteria are Longevity and Strong sidewall ( I often drive for 12 to 14 hours stretches continuously without a stop). I also do drives on the beaches and mud and slush but not too often.
My second question is pertaining to Bridgestone.
I currently have a 2 year old unused Bridgestone Dueler HT. In case I opt for Bridgestone D689, can I buy only 3 tyres and use the Bridgestone Dueler HT as the 4th tyre? Does it create problems in suspension set up and other mechanicals of the car with this set up? The tyre shop person mentioned that it would not create any such problems with the set up but I want to confirm the same with the fellow T-BHpian Gurus.
Thanks a lot for your help.
Old 17th April 2012, 15:51   #609
tsk1979's Avatar
Thanked: 16,422 Times
The BF Goodrich makes good sense. Its not a hard core A/T tire, but a trail driving tire.
As for bridgestone, I did not have a good experience. Lost multiple tires due to stones, highway burst etc.,
tsk1979 is offline   (1) Thanks Reply With Quote
Old 22nd April 2012, 18:10   #610
Thanked: 649 Times
Cool re: Tata Safari : Tyre & wheel upgrade thread
Originally Posted by v&v View Post
Finally bought Michelin Latitude Cross for 6540/- per tyre from Reliance Autozone , Gurgaon. Original quoted price was 7800/- per tyre.
Immediate observation : Tyres are very quiet.
You got the 'DEAL'.
The same tyres at Reliance Autozone at EDM mall (Ghaziabad) is costing Rs 8300. It really looks awesome!
BTW, whats your feedback on their usage on highways, bad roads or no roads?
Cheers!
Irish
Irish is offline   Reply With Quote
Old 23rd April 2012, 08:41   #611
rjstyles69's Avatar
Thanked: 795 Times
Cheers!
Irish
PM fellow member lukeskywalker, IIRC he was using the same Michelins.
rjstyles69 is offline   (1) Thanks Reply With Quote
Old 23rd April 2012, 08:50   #612
Thanked: 245 Times
Any ideas ?
They are a year old
Rahul
Its a pin puncture, get them overinflated to about 45psi and then check under water for bubbles.
Old 23rd April 2012, 09:43   #613
v&v
v&v's Avatar
Thanked: 1,099 Times
You got the 'DEAL'.
Cheers!
Irish
Yes, even now when the i visit the reliance auto zone, he still comments on that deal. Feedback for 4k kms i have done Its very quite and road grip is much better than my OE Bridgestone. I am happy with it.
v&v is offline   (1) Thanks Reply With Quote
Old 23rd April 2012, 09:59   #614
Lukeskywalker's Avatar
Thanked: 1,170 Times
Riju, I am currently using Michelin LTX AT2 which are currently not available, the Latitude Cross is not a hard core All terrain tyre, it looks more like a comfort/highway tyre.
My current set have crossed 61k kms and still have at least another 10k kms of life left.
Lukeskywalker is offline   Reply With Quote
Old 24th April 2012, 01:27   #615
Thanked: 269 Times
Can someone from Hyderabad tell me a good tyre shop for the Safari Tyres who are willing to buy an unused 2 year old Bridgestone Dueler? None of the dealers I talked to deal in the seconds market.
I am planning to get 5 BF Goodrich Long Trail tyres. Hence, I want to sell off the tyre.
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 18 8th July 2018 21:32
Fiat Palio : Tyre & wheel upgrade thread shahmotors Tyre & Alloy wheel Section 637 26th March 2017 12:56
Tata Bolt : Tyre & wheel upgrade thread narayan Tyre & Alloy wheel Section 11 11th September 2015 18:36
Tata Indigo Manza : Tyre & wheel upgrade thread -NUT-case Tyre & Alloy wheel Section 99 15th June 2015 19:59
