Old 10th May 2012, 22:36   #631
Lukeskywalker's Avatar
Thanked: 1,170 Times
Default re: Tata Safari : Tyre & wheel upgrade thread
Well sir to trust a thing you have to test it so i wont pass judgement on these tyres till i test them, also i said i spent half the amount i was planning to. I dint mean that the tyres cost half of what a yoko geo At would.
Good point, I am sorry if I sounded condescending, it was not my intention, what tyres did the car have as OE?
Lukeskywalker is offline   Reply With Quote
Old 10th May 2012, 23:02   #632
Born 2 Be Wild's Avatar
Thanked: 173 Times
The car had apollo hawkz when i saw it in the yard but i built a rapport with the sales guy and requested him to get me Bridgestone duellers which he eventually did by swapping this set with another EX standing in the yard with Bridgestones.
Born 2 Be Wild is offline   Reply With Quote
Old 11th May 2012, 11:12   #633
mercedised's Avatar
Thanked: 174 Times
One can now buy the tyres online, Not relevant to this thread but as I own a Safari so sharing here, Pardon if already shared:
Tyres for TATA SAFARI All Variants :: Change My Tyre
Old 28th June 2012, 03:52   #634
Back after a really long long long....time, looking for some help. Hope you guys would forgive my absence.
Today two of my cars tyres burst-ed near the delhi airport. Its a 2009 Gx which has done almost 55K on the stock Bridgestone Duellers. I was planning on buying Bridgestone once again but after going through this thread I think it would be sensible to shift to a 255 with stronger sidewalls.
I would be happy to go with any H/T with stronger side walls, as I wont be doing anything crazy for the next 2-3 years (newest member of the family is yet to complete 2 months). Most of the discussion here seems to be focused on A/T, so I am unable to make up my mind even after spending quite some time on the forum. What's the best option when it comes to H/T: Yoko, Micheline, MRF, BGF, JK, Apollo, Bridgestone, or any other?
I do not have much time to spend on negotiations, as I can not drive until I get the tires replaced. Have to get it done within a day. And the dealer would have to bring the tyres to Dwarka and do the fitting.
I do not expect anything for the 3 tyres which are still intact, but how much can I expect for the stock alloys if I wish to go for new alloys. If I am not mistaken 6.5J and 7J can both handle 255, right?
I would be really grateful if someone can please suggest a good dealer (for tyres & alloys) who would be willing to walk the extra mile without ripping me off. And some suggestions to get me out of this conundrum with regard to the tyres.
King_Jsr is offline   Reply With Quote
Old 16th August 2012, 21:07   #635
Thanked: 51 Times
Hi Guys,
I am looking to change tyres of my steed. Did some calling today and got below rates. Currently I am running Hankook 245/70/R16 but now they are up for change.
Below are today's rates. Please advise which will be a better buy. My usage is 70 percent highway and 30 percent slush, rocky roads.
Yoko Geolander 235/70/R16- 6900
Yoko Geolander 245/70/R16- 8100
Michelin LTX-AT 235/70/R16 - 7125
Michelin Latitude cross: 7900
I checked Bridgestone Duelers and they were 7800. I don't think they make any sense if Geolander cost less than that.
Please advice
-Ijeet
ijeet is offline   Reply With Quote
Old 17th August 2012, 11:04   #636
rjstyles69's Avatar
Thanked: 793 Times
Originally Posted by ijeet View Post
Hi Guys,
You sure about that Geolander size, I think the next upsize from 235/70/R16 is 255/65/R16. Both the Michelin and the Geolander's are good. I have been using the geolander on my scorp for the last 30k plus kms and have been pretty satisfied with them.
Fellow member lukeskywalker who is using the Michelin's have been happy with them. So it's safe to say you can pick one of them above two brands.
That said, please stay away from the BS Duelers, pathetic road noise and the braking was scary with these tires. I had used them for 5k clicks before I swapped over to the Geolanders.
Old 17th August 2012, 11:20   #637
jkdas's Avatar
Thanked: 1,436 Times
Yup they have that size. IIRC, they launched it an year back or so. 255 ( experts say) is a overkill on stock alloy and hence 245 would be better?
Old 17th August 2012, 12:57   #638
rjstyles69's Avatar
Thanked: 793 Times
Expect some amount of speedo error and the correct up-sizes for the Dicor would be
245/70-16
255/65-16
265/60-16
275/60-16
rjstyles69 is offline   (1) Thanks Reply With Quote
Old 17th August 2012, 17:11   #639
Thanked: 51 Times
Thanks rjstyles69,
So what do you think. Is there much difference between 235 and 245? I am currently running 245 but don't recall how 235 were?
Is percieved advantage justify extra expenditure of 1000+INR
-Ijeet
ijeet is offline   (1) Thanks Reply With Quote
Old 17th August 2012, 21:38   #640
rjstyles69's Avatar
Thanked: 793 Times
Thanks rjstyles69,
-Ijeet
Yikeees !! Clicked thanks instead of quote.
On a lighter note, yes there is a difference of 10mm .However the size that you mentioned earlier isn't the right up-size for the dicor though. My previous post has the right upsizes.
Read this post, should give you an idea.
Old 17th August 2012, 22:29   #641
Thanked: 51 Times
Returned your thanks
Rj, what do you really mean by not correct upsize? I am running 245/70/R16 now and they were okay until i messed them up because of my stupidity.
What i really wanted to know that how much difference does 10mm makes while it comes to braking , taking care of slush etc.
-ijeet
Old 20th August 2012, 09:47   #642
rjstyles69's Avatar
Thanked: 793 Times
-ijeet
Sorry man I misread the size. You are correct and that is the right up-size.
Old 20th October 2012, 19:48   #643
Does it make sense in having different size tyres in front and back of a rear wheel drive Safari- something like on Nano. Like 235 in front - wider ones have issue with fender and full turns- and 245 or 255 on the rear?
Ravi Kashyap is offline   Reply With Quote
Old 25th October 2012, 19:35   #644
arvindmanju's Avatar
Thanked: 152 Times
-ijeet
Hello Ijeet,
Did you get the tires changed, if yes to which brand and size (235 or the 245)?
thanks,
arvindmanju is offline   Reply With Quote
Old 25th October 2012, 20:16   #645
jkdas's Avatar
It seems even MRF Wanderer's 235 would look wider. Do also check that.
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 15 15th June 2018 16:33
Fiat Palio : Tyre & wheel upgrade thread shahmotors Tyre & Alloy wheel Section 637 26th March 2017 12:56
Tata Bolt : Tyre & wheel upgrade thread narayan Tyre & Alloy wheel Section 11 11th September 2015 18:36
Tata Indigo Manza : Tyre & wheel upgrade thread -NUT-case Tyre & Alloy wheel Section 99 15th June 2015 19:59
