Old 5th March 2008, 16:01   #106
Akshay1234's Avatar
Thanked: 6,665 Times
looks nice. you shudda got 14inchers.
Old 5th March 2008, 17:17   #107
Thanked: 18 Times
Well ! i dont know maybe the 14" will be a touch too much and the ride quality may not be as smooth as 13" on my ride(that is my opinion though) and moreover one never knows if the body has to be lifted again and hence decided not to take a chance.
VJ_MAVRICK is offline   Reply With Quote
Old 6th March 2008, 21:45   #108
abhibh's Avatar
Thanked: 33 Times
MAV dood awesome looking alloys.
1 question does it scrap with 5.5J alloys ?
Old 10th March 2008, 10:37   #109
Thanked: 18 Times
Nope Abhi ! I am not finding any scraping and the ride quality too is good.
Old 21st April 2010, 13:53   #110
Thanked: 18 Times
Fellow Petrol Heads,
I am reopening this thread as I want to make some suspension mods and planning to get either Koni Shocks or any other which might be suggested here. Maverick clocked slightly above 70K and kindly suggest the best suited ones.
Old 21st April 2010, 18:15   #111
lilMonSter's Avatar
Thanked: 28 Times
Let me also know what you decide upon. even i'm in the market for a suspension upgrade...trying to source lowering springs right now.next step is to loose the rear seats and fill it with ice
lilMonSter is offline   Reply With Quote
Old 26th April 2010, 10:49   #112
ranjithrnair's Avatar
Thanked: 81 Times
Even my alto vxi 1.1 clocked close to 71K , i feel the its time to change the front shocks , i am also interested in suspension mods.
ranjithrnair is offline   Reply With Quote
Old 29th April 2010, 18:17   #113
lilMonSter's Avatar
Thanked: 28 Times
Hey, could you post a pic of your endcan and how it's fitted. from under the car if possible so i could see the route the pipe is following and the size of the endcan..
Old 29th April 2010, 19:29   #114
nitrous's Avatar
Thanked: 282 Times
OT:
I highly recommend following the routing that the factory uses.
Old 5th May 2010, 10:12   #115
Thanked: 81 Times
VJ_MAVRICK , did you get any useful information on the suspension mods ?
Old 5th May 2010, 12:08   #116
lilMonSter's Avatar
Thanked: 28 Times
Originally Posted by nitrous View Post
OT:
i intend to use the factory routing.. it's just that the factory exhaust is not designed or intended to have an endcan. i need to get one to loose the automech buzz i've been living with. hence i need to have a look at how it is mounted. i don't want the pipes flowing at weird angles that would be detrimental to performance.
cheers,
Old 17th May 2010, 14:57   #117
Thanked: 18 Times
@ranjith: I went ahead a replaced the front shockers with Gabriel shocks and the ride is pretty smooth now. Initially wanted to get Koni during the replacement but went ahead with regular Gabriel shocks as Koni is too expensive.
@lilmonster: I got the end can fitted when the entire FFE was installed.
Old 6th June 2010, 23:20   #118
Mr_Bean's Avatar
Thanked: 126 Times
VJ - After the FFE, did you get to dyno the car, I am just curious about the power the 1.1 litre is transferring to the wheels.
Mr_Bean is offline   Reply With Quote
Old 21st June 2010, 16:57   #119
Thanked: 18 Times
Sorry Mr_Bean for this rather late reply as I hardly log in nowadays anyways better late than never. I have not dyno'ed the car and will be planning to do as am thinking about RD's ECU sometime in future.
Old 17th July 2010, 19:15   #120
awinash's Avatar
Hi all,
I am a newbie and I went through a lot of threads and spent a lot of time trying to figure out a nice tire and wheel for my alto1.1. after close to a couple of months of research, I decided on HRS 13x5.5J alloys and 165/60R13 GIIIs. I always drive alone and occasionally have one or two other seats occupied. Yesterday, I had to go on a short out of station trip with 4 other passengers which is when I noticed that the rear tires scrapes the wheel arch. It doesn't always happen. Happens only when I am travelling at around 70+ and the road happens to have a smooth short dip. I pulled over to check the clearance between the tires and the arch (with the passengers in of course) and found a very small gap... maybe around a couple of inches.
My questions now:
1. Stock 145/80R12 has an overall diameter of 536.70mm (21.13in). Upsized 165/60R13 has an overall diameter of 528.06mm (20.79in). That's an 8.64mm reduction in diameter, which implies an increase in distance between the tire's periphery and the wheel arches, thereby increasing clearance for the suspension to move. But in spite of this I do not understand why the upsized tire scrapes the wheel arch. What am I missing here?
2. What options do i have to get over this?
Thanks in advance.
awinash is offline   Reply With Quote
Modifying original Banded Steel rims for the Classic muscle car look Tej Khokhar Tyre & Alloy wheel Section 2 30th May 2011 16:45
Alloy Rims for Estilo vebmetal Tyre & Alloy wheel Section 30 29th September 2009 17:53
Query : Tubeless tires / Normal Tires nicejits Tyre & Alloy wheel Section 12 10th June 2009 09:59
My 17" Rims and Tires are for Sale... swapszone Shifting gears 13 12th November 2007 02:48
alloy rims for sale(2 sets) mclaren6162 Shifting gears 0 17th February 2007 14:22
