Old 24th June 2007, 02:15   #16
razor4077's Avatar
Thanked: 258 Times
Availability, pricing... main constraints.
We in Calcutta aren't as lucky as you B'lore chaps Very limited choice.
As for the tyres, my options are mentioned in the first post. What's your take? And btw, suspension will not remain stock... see first post again.
razor4077 is offline   Reply With Quote
Old 24th June 2007, 02:27   #17
v1p3r's Avatar
Thanked: 27 Times
Well, seeing as you are getting your tyres shipped, might as well get the alloys shipped too. I'd spend a little extra and go for the good stuff. There's a reason why they're used in rallies, you know.
If you want comfort and some grip, stick with the Michelins. If you want outright grip, and decent comfort too, go Yokohama Advan Neova. Expect the Advans to last 30k km with sane driving, and as low as 7k if you think Calcutta is your personal test track. The ES-100s were great when they were launched, over 3 years ago, but now they're out of the game. Goodyear sucks, no two ways to put it. The Yoko AVS Sports have ceased manufacture.
With your suspension setup, you could really go 17s, you know. Also, I don't see the need for an aftermarket suspension setup unless you're hitting the track. The Lancer OE kit does a good job of giving you some comfort and not shaming its rally cousin.
Old 24th June 2007, 02:27   #18
faithless_1984's Avatar
Thanked: 217 Times
15` 15` 15`....and ill keep repeating that untill you get them.!
faithless_1984 is offline   Reply With Quote
Old 24th June 2007, 03:35   #19
razor4077's Avatar
Thanked: 258 Times
Actually, I am not getting my tyres shipped. That was the whole point of this thread My original choice was ES100's shipped from Mumbai. But, given the logistical and cost issues I am not opting for that. Hence, my choice has been narrowed down to the whatever is available locally.
17"... have you driven on these regularly on bad roads? Logically, 40-profile tyres with 17" rims will not give a significant amount of comfort, vis-a-vis a 60/14 or 50/15. And I wasn't kidding about my back problems... it's due for surgery, to give you an idea of the extent of it...
Regd the aftermarket suspension, the car is 7 years old and was due for a suspension overhaul anyway. I wanted to try out an advanced setup, so I took advantage of the situation and went for the Pedders. I had also considered Koni, but decided against it.
Tyre-wise, it seems that Michelins (Pilot Precedas) have the vote. The problem is, they aren't available here in 205/50/15... will have to pressurize the guy into ordering them for me.
If that doesn't work out, I'll have to go for a 195/60/14 setup.
Old 24th June 2007, 03:47   #20
Thanked: 217 Times
well if that`s the case then go for 14` rims and tyres coz 15` rims and 50 profile tyres will give you a harsh ride.
Old 24th June 2007, 09:00   #21
Akshay1234's Avatar
Thanked: 7,242 Times
nice choice of wheels. i have them on my ride. get them in 15 or larger because they dont look good in 14.
Old 24th June 2007, 10:00   #22
Vid6639's Avatar
Thanked: 21,060 Times
Originally Posted by lancer80 View Post
You can also try 195/55/15 but the ride isn't that great. Even though is better than 205s. I wouldn't recommend 205s 15inch at all.
195/55-15 that dint strike me. That's a sweet size. Looks like best of both worlds.
195/60-14
Overall Diameter = 589.53mm
sidewall height = 116.84mm
205/50-15
Overall Diameter = 585.97mm
sidewall height = 102.36mm
205/55-15
Overall Diameter = 606.29mm
sidewall height = 112.52mm
195/55-15
Overall Diameter = 595.37mm
sidewall height = 107.18mm
Old 24th June 2007, 12:35   #23
razor4077's Avatar
Thanked: 258 Times
Any idea what tyres are available in 195/55/15? I think F1 GSD3 is, but that's not found favour with anyone yet.
Is Pilot Preceda available in that size?
Old 24th June 2007, 13:09   #24
iraghava's Avatar
Thanked: 156 Times
I've been using the PP's on Dhanno for over 4k now & have been bloody happy about them! Best tyres I ever bought with regards to grip & wet-weather performance but the ride is a tad stiff compared to the Energy XM1's.
Highly receommended over other options is my advice.
Kinda hard to find that size.
Old 24th June 2007, 14:46   #25
lancer80's Avatar
Pilot Preceda will not be available in that size.
lancer80 is offline   Reply With Quote
Old 24th June 2007, 15:12   #26
Ricky_63's Avatar
Thanked: 394 Times
Razor
I read thru most of the thread - i am using 205/55/15 on my Lancer THERE IS ABSOLUTELY NO PROBLEM. The Alloys I have are League You can see my Gallery & see if you want lower profile. Believe me 205/55 or even 205/50 will work. DO NOT go lower than 50 profile if you don't want damaged rims etc keeping in view the roads you drive on & more importantly watch your back.
Old 24th June 2007, 15:18   #27
razor4077's Avatar
Thanked: 258 Times
@ricky: i have no intention of going under 50 profile. i wanted to fit 205/55/15 but not getting much choice in this tyre-wise.
So am settling for 205/50/15 OR 195/55/15 OR 195/60/14. I will get some speedo error for all of these, but else will be fine.
Regd the back... thanks for your concern
Old 24th June 2007, 15:34   #28
Ricky_63's Avatar
Thanked: 394 Times
IMO Go for 15" preferably - they are just right. Looks wise as well ride wise
Old 24th June 2007, 16:21   #29
razor4077's Avatar
Thanked: 258 Times
Ok... based on suggestions, here is what I am going to go in for:
Choices:
1st: 195/55/15 - tyre?
2nd: 205/50/15 - Pilot Preceda
3rd: 195/60/14 - Pilot Preceda
Waiting on the tyrewalla to get back to me on the pricing and availibility of the first 2 choices. Ishan is doing some looking up too. Hopefully will get what I'm after.
Old 24th June 2007, 16:32   #30
manikjeet's Avatar
Thanked: 110 Times
But coming back to the 15"... how harsh a ride will these provide, as compared to a 14" setup?
i have sat in both stock 13" and 15"
the ride in the 15" is not that bad actually they are good in the handling department and 15" look almost stunning
you don't feel the bumps that much
the car i am talking about has 205 50 r15 and its 2006 lancer D
i have driven a lancer with 17" rim but the ride was harsh but not that hard but here in chandigarh we have very good roads so cann't really comment on ride
manikjeet is offline   Reply With Quote
White Punto (Rim + Tyre upgrade) EDIT : Pics on Page 2 karan561 Tyre & Alloy wheel Section 82 27th February 2013 23:16
Help:Tyre and Rim upgrade for OHC 1.5 adnan Tyre & Alloy wheel Section 9 3rd April 2007 18:40
Losing the air between RIM and tyre, is this possible? Laxminarayan Street Experiences 14 17th January 2007 17:11
Rim and tyre change for Matiz.. Su-47 Tyre & Alloy wheel Section 19 2nd November 2006 12:00
