Tyre & Alloy wheel Section Everything to do with footwear for your car!
Thread Tools
Old 23rd June 2007, 22:26   #1 (permalink)
razor4077's Avatar
Default Tyre and rim upgrade for the Lancer
Hey guys,
As some of you know, my Lancer is undergoing a major overhaul. Skipping to the relevant part - the tyres and the alloys.
For the alloys, I have decided upon the Plati PY509 rims, which are the M6 replicas that can be seen on this thead:
http://www.team-bhp.com/forum/tyre-a...ade-civic.html (17" upgrade for civic)
Now comes the tough part - the tyres.
I had almost finalized Yokohama AVS ES100 tyres - size: 205/55/15.
However, these are unavailable in Calcutta... am getting them in Bombay for 4k per tyre. Shipping will cost close to 1.5k for 5 tyres + octroi + W.Bengal state taxes + the running around to get a waybill for the same.
So I started checking out the local options.
In the 205/55/15 size, the only option for me is Goodyear Eagle Ventura. Some like this tyre, but I think they are a little too hard, and not to my liking.
Tyrewalla suggested I opt for 205/50/15, which have a smaller RR than the stock 175/80/13, but have been used without hassles on Lancers.
Options:
Goodyear Eagle F1 GSD3 & a Falken tyre (dunno the model name).
Else,
Go down one size and opt for 195/60/14.
Options:
Michelin Pilot Preceda, GY Eagle F1 GSD2, Bridgestone Potenza G3
So guys, need your suggestions here. Should I go for 15 inchers? 205/50/15 seems to suggest a harsh ride (however, I am fitting Pedders heavy duty coil springs + Pedders Comfort Gas shockers - this should be kept in mind). The GSD3's cannot be that bad... tirerack has it #3 in its category. I've been quoted 4.4k per, but this may go down after some bargaining.
Or should I play it safe and opt for 14"? I was thinking of the Pilot Precedas (< 3.5k per) if so. What's the feedback on them?
Little help here?
razor4077 is offline   Reply With Quote
Old 23rd June 2007, 22:35   #2 (permalink)
vid6639's Avatar
Razor, 205/55-15 will foul on full load with the rear body work. Suggest you take the 205/50-15.
Harmon_bro had the same problem with his tyres, they used to scrape the rear fender.
https://www.team-bhp.com/forum/tyre-...tml#post438970
Ride will go down but they will not scrape.
Tyres, from your options the goodyear venturas seem to be ok. No such bad review from those. But dont go near the goodyear eagle f1's. higher rate of wear and very noisy. They are number one on tire rack cause the roads are not comparable to the ones we have here. On bad roads they pose many problems.
Michelin Preceda is the best bet. Our inhouse tyre wallah Iraghava has them on his OHC. get a review from him.
The bridestone Potenza g-III are also very good. Nice grip but they can be a little noisy on the lancer.
I would play it safe for good ride and handling and go for 195/60-14 in the Michelin energy XM1 or the potenza G-III.
__________________
\ / ][ |) `/ [_] "!"
(o.o)
( X )
This is Bunny. Copy Bunny into your signature to help him achieve world domination.
vid6639 is offline   Reply With Quote
Old 23rd June 2007, 23:03   #3 (permalink)
razor4077's Avatar
You mean Preceda? Don't want to go for XM1.
Old 23rd June 2007, 23:18   #4 (permalink)
vid6639's Avatar
Yeah preceda if your looking for performance and energy XM1 if ride is more priority.
__________________
(o.o)
( X )
Old 23rd June 2007, 23:32   #5 (permalink)
faithless_1984's Avatar
@razor - as someone mentioned in harmon_bro`s thread the look of a particular rim (like the M6 replica) or any rim depends on the size ,it may not look that good in 14` size but would look killer in 17` but as you want good ride quality then IMHO atleast go for 15` rims.
__________________
God.....is a DJ.
faithless_1984 is offline   Reply With Quote
Old 23rd June 2007, 23:46   #6 (permalink)
razor4077's Avatar
@faithless: that's a good point. will have to mount them on the car and see how they look. i saw these in 14" on an NHC and they looked pretty darn good... in fact, they were my inspiration so to speak
but yea, i'll keep that in mind.
btw, any other suggestions for rims? i want to go for the machined-black finish (as in the rim pics mentioned above).
Old 24th June 2007, 00:23   #7 (permalink)
well to give you an idea about how the M6 replica rims would look in a bigger size here is a pic of a Lancer with 17` M6 replica rims.
[img=http://img444.imageshack.us/img444/9300/mivecpk5.th.jpg]
source -
http://www.team-bhp.com/forum/team-b...ter-noida.html (Pics: Mini meet @ Greater Noida)
So please dont go for 14` rims.....Phoenix deserves bigger rims.
__________________
God.....is a DJ.
Old 24th June 2007, 00:47   #8 (permalink)
razor4077's Avatar
Lol.. you're tempting me dude! I'm just a little unsure about the kind of ride I'll get from 15 inchers, especially with a 50 profile.
Will I survive Indian roads on these?
Old 24th June 2007, 00:51   #9 (permalink)
vid6639's Avatar
yeah dude no probs with the 15".
Also you are changing your suspension. That should be a little stiff so even with the 205/55-15 your car may not come that low to touch the body work.
Just select the alloy offset and rim width correctly.
__________________
(o.o)
( X )
Old 24th June 2007, 01:01   #10 (permalink)
lancer80's Avatar
You can also try 195/55/15 but the ride isn't that great. Even though is better than 205s. I wouldn't recommend 205s 15inch at all.
I think your best bet would be 195/60/14 Michelin Pilot Preceda.. best of both worlds (performance & comfort)
Im sure a lot of you have used the Michelin Pilot Preceda, how are they for our Indians roads, when considering comfort as priority?
lancer80 is offline   Reply With Quote
Old 24th June 2007, 01:02   #11 (permalink)
lancer80's Avatar
Opps! I did not consider the change of suspension in my ealier post.
Old 24th June 2007, 01:08   #12 (permalink)
razor4077's Avatar
205/55/15 is a little tough to get... like i mentioned, only Venturas are available in this size and i'm not too keen on those.
What say you about 205/50/15?
Old 24th June 2007, 01:57   #13 (permalink)
v1p3r's Avatar
Put 17"s with 215/40 ZR 17. Looks smashing on a Lancer.
__________________
Peace is a lie, there is only passion.
v1p3r is online now   Reply With Quote
Old 24th June 2007, 02:06   #14 (permalink)
razor4077's Avatar
Lol... I have a bad back already dude. Don't think 17 inchers will help
Wish I could tho...
But coming back to the 15"... how harsh a ride will these provide, as compared to a 14" setup?
Old 24th June 2007, 02:07   #15 (permalink)
v1p3r's Avatar
To be honest, 17s are not all that bad. I've driven quite a few cars with them, and with soft OE setups like the Lancer, they're livable. Yes, you can't fly over bad roads or speed-breakers, but they'll be ok.
Anyway, 15"s vs 14"s also depends on the brand of the tyre. Some are softer and ride better, so you won't tell the difference, some aren't. But empirically, the 14"s will have a better ride.
Why Plati? Why don't you go OZ or Enkei?
__________________
Thread Tools
Tyre upgrade for lancer. help pls.. prav_05 Tyre & Alloy wheel Section 9 12th November 2007 22:15
Help:Tyre and Rim upgrade for OHC 1.5 adnan Tyre & Alloy wheel Section 9 3rd April 2007 18:40
Tyre upgrade for lancer sfxi vid6639 Tyre & Alloy wheel Section 25 23rd September 2006 23:18
Rim upgrade for WagonR sbelekar Tyre & Alloy wheel Section 7 4th June 2006 09:16
Indigo Rim & Tyre Upgrade viper Tyre & Alloy wheel Section 0 16th January 2006 19:03
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
