Old 20th August 2007, 19:55   #16
kpzen's Avatar
Thanked: 1,598 Times
No offence. Have some mercy on that little 1.1L engine..
I feel 175/60-13 is more than sufficient for a Santro..
Old 20th August 2007, 20:42   #17
Originally Posted by rajeevrs View Post
Iam looking to Upsize by ONE INCH from R13 to R14 for my Santro.
So Iam looking for tyres with 175/55(60) R14 or 185/50(55) R14. Anybody can help me where to find this in chennai? and also the price for five of these.Iam looking for Pirelli/Michelin/Yokohama low profile ultra performance tyres. If any help me....Currently I have 155/70 R13 on it.
thanks & Regards,
Rajeev.R.S.
In 14" only options you have are :
175/60 R14 YOKOHAMA A539
175/60 R14 GOODYEAR
185/55 R14 YOKOHAMA S.drive
Above three are very much avialable in market, I would suggest you to go for 185/55 R14 because in case of 175/60 R14 overall diameter change is more than 3%.
itzzme is offline   Reply With Quote
Old 20th August 2007, 22:15   #18
kpzen's Avatar
175/60-14" is a wrong upsize and i'm sure it will scrape and touch on all the wheel wells.
Old 20th August 2007, 22:58   #19
esteem_lover's Avatar
Thanked: 445 Times
And who do you think cares about that ?
Man, seriously, i advice you to stick to your company OE sizes for your santro, I am sure you are not expecting extreme performanes from your santro. For a regular drive, get michelins or better tyres in your stock size.
cheers
Old 20th August 2007, 23:36   #20
razor4077's Avatar
Thanked: 252 Times
Originally Posted by iraghava View Post
Rajeev - Finding the 195/50 R14 will be a challange since very few companies actually make them.
In addition to that, your ride will be really harsh if you go for 50 profiles on a Santro. The suspension is set up kind of stiff anyway... you really feel the bumps. Add low profiles to that, and you're asking for bone-jarring trouble.
My advice would be to stick to the 13" in 165 or 175.
Actually, upsizing to 165/65/13 on good rubber makes a world of difference in a Santro, especially at high speeds (not neccessarily extreme performance, but high enough).
razor4077 is offline   Reply With Quote
Old 11th June 2013, 23:09   #21
docvino's Avatar
Default Re: Tyre UP-One Size 0f 155/70 R13 to 175/55 R14 or 185/50 R14 availability in chenna
The ideal upsize for the santro is 195/45 r14 and not 195/50 R14 because this gives a % variation from standard of -2.9 which is just in the accepted range of +/- 3% you go any higher on the profile it will hit the wheel well.i had been using the 195/45 r14 on the santro for the past 3 yrs and I was very impressed with the quality of the ride to my surprise .the tyres where hankook ventus prime and my it is a gem of a tyre even after 3 yrs and running 35k the tyre thread is like new but I burst one tyre when the car fell into a pothole in the present rains and this tyre is not available in the whole of India due to some ISI issues it seems the tyre companies need to pay around 3 Lakhs for getting a license for each size and it just happens since this is a very infrequently sold size they have not applied for the license so I am planning to change to 185/50 R 14 for both the front tyres alone and keep the back at 195/45R14 don't know if it will cause issues. You can check out my car at introduce yourself section - Santro nicknamed batmobile ,it has made it to the top 20 of the most viewed in that section along with the ferraris and masseratti intros
docvino is offline   Reply With Quote
Review of Michelin XM1 155/65/R13 on my WagonR bj96 Tyre & Alloy wheel Section 54 23rd May 2010 22:22
185/55 R14 or 195/45 R14/R15 For a Zen? riffst3r Tyre & Alloy wheel Section 48 22nd October 2009 10:32
Can i put 165/70/r13 tyres on alloys that say they need 175/70/r13's ? jcoxy4 Tyre & Alloy wheel Section 6 20th November 2008 04:19
Wanted: R13 Tubeless used tyres for cheap: Any brand any size >= 185 IronWolf Shifting gears 28 20th July 2007 21:06
155/70/R14 or 165/70/R14 Available? nitrous Tyre & Alloy wheel Section 11 16th March 2006 18:28
