Old 4th July 2007, 23:50   #1
Question NHC Tyre Upgrade Advice
Hi
I have a New Honda City GXi model with stock 176/65/14" tyres and aftermarket alloys.
Now I want to go for 15" wheels (is it a good decision?) I have selected a lenso model. My question is what will be the best fit for this wheel.
I am considering 195/50/15" goodyear f1 gs-d3 tyres. is it a good choice. Does upsizing to 15" have any negative effects?
Will the ride comfort/braking be effected and will there be any drop in mileage?
Sunil Varma
sunilvarma is offline   Reply With Quote
Old 5th July 2007, 03:08   #2
iraghava's Avatar
Thanked: 153 Times
Here are a few existing toopics to solve your queries:
https://www.team-bhp.com/forum/tyre-...zer-250-a.html
https://www.team-bhp.com/forum/tyre-...tment-nhc.html
Old 6th July 2007, 01:57   #3
i need a more specific answer for my case. plz reply...
Old 6th July 2007, 08:27   #4
CrAzY dRiVeR's Avatar
Thanked: 16,769 Times
Originally Posted by sunilvarma View Post
Hi
Sunil Varma
Stock tyres are 175/65-14.
195/50-15 can be fitted on the NHC.
15" upsize wont cause much problems on the NHC as its only the first upsize. Although ride comfort may become a bit hard.
Mileage may drop slightly with the use of 195/50- 14 tyres due to larger contact patch on the road and more rolling resistance. Dont think that they'll cause a big worry cause of the wonderful FE given by the NHC.
Old 6th July 2007, 12:34   #5
iraghava's Avatar
Thanked: 153 Times
Well the upsize is correct but the drawbacks of the same are:
Harsher ride than the stock size
Increased chances of tyre problems due to low sidewall height & poor conditions of our roads
But that said there are many people running that size on Honda's without any problems as such but do be prepared to make a sacrifice on the comfort front. Braking should not be effected but rather should improve marginally with the wider contact patch & better rubber.
Also do look at other tyres other than the F1 GS-D3, there are many, better options available.
Old 6th July 2007, 17:54   #6
is the NHC really that fuel efficient? mine gives just 10kmpl and i am worried. :(
Old 6th July 2007, 21:03   #7
NHC is hailed as the mileage king in the segment (petrol), isn't it?
May be the NHC owners in the forum can share their FE figures.
Old 6th September 2007, 16:54   #8
Awaiting Email Confirmation
Red face New Wheel Set for NHC
Guyz, i'm planning to upgrade the OE wheel set on my NHC. Even after reading through a hell lot of posts through TBHP and others on the internet, i am in a gr8 dilemma. The tyre size calc. on Car Bibles: The Wheel and Tire Bible show the following figures for the sizes i zeroed on--
Stock - 175/65 R14
Possible upgrades - 1. 195/55 R15 (2.13% speedo and odo error)
2. 195/60 R15 (5.47% speedo and odo error)
3. 205/55 R15 (4.01% speedo and odo error)
Now i want a bigger set of wheels, but if i go in for choices no. 2 & 3, the odo would overread by 2000-2500 kms after 50,000 kms. (Which i think is a lot !) But if i go in for choice no. 1 then i dont get much improvement in overall size of the wheel. Also, i have to keep in mind that the wheel wells are able to accomodate them. So, kindly give your opinions on the same.
Next, the tires. This time i really wanna try out yokohama's, but am confused b\w the models -- AVS ES100, AVS Sport, S drive. I want grippy tires, but not the extreme ones (very low FE, and plus they would be expensive too). Or as someone pointed out, are Potenza GIII's better ??? I am utterly confused !!!
Mod's Note: Please search and use an existing thread rather than opening new threads on the same topic. Threads merged.
Vishesh is offline   Reply With Quote
Old 6th September 2007, 17:16   #9
And ohh i forgot to ask, are the soft compound yokohama's very prone to punctures, cuts etc ? If thats the case i might need to consider only bridgestones. And how about michelins ?
Old 6th September 2007, 17:17   #10
reignofchaos's Avatar
Thanked: 1,175 Times
If you want the best, get the Michelin Pilot Preceda 2. Its better than both those yokos.
Old 6th September 2007, 17:18   #11
Akshay1234's Avatar
Thanked: 6,670 Times
i think the best out of them is 195/55 r15. i suggest you go for 195/50 r15. it will have the least error. also get yokohama s drives. if they are too pricey then you can get es100s.
Old 3rd October 2007, 19:42   #12
Thanked: 20 Times
Please help.... Even my car turned around 41K and time to changes my tyres... I have read the responses on various topics on tyre upsize... Would be please advice me, if it is ok to stick to michelin 195/60R14 to my NHC. Will the FE drop ?
contactme27 is offline   Reply With Quote
Old 3rd October 2007, 20:31   #13
iraghava's Avatar
Thanked: 153 Times
Yes, there will be a marginal drop in FE of your car. I think you can expect around a 1kmpl drop.
Old 3rd October 2007, 22:28   #14
Originally Posted by Vishesh View Post
Stock - 175/65 R14
195/50 R15 is very good option for you.
options for you in this size are
PP 4900/=
PP2 5300/=
S.Drive 4600/=
In 195/55 R15 only S.drives will be available for around 4500/=
itzzme is offline   Reply With Quote
Old 3rd October 2007, 22:32   #15
kpzen's Avatar
Thanked: 1,598 Times
195/60-14 would give u decent ride quality and better grip than stock ones.
Yes, there could be marginal drop in FE.
PP2 are great tyres and i feel the AVS sport and S drives are in the same league.
Have u driven all three tyres in the same manner in the same car to prove that?
Tyre upgrade/alloys fitment - NHC AshOnTheRocks Tyre & Alloy wheel Section 21 26th July 2014 19:18
NHC Tyre upgrade cuttingcrew Tyre & Alloy wheel Section 9 12th May 2010 12:07
NHC Tyre Upgrade...Help needed !!! funkydevil Tyre & Alloy wheel Section 11 19th November 2007 12:49
NHC tyre and wheel upgrade!! nikkibike Tyre & Alloy wheel Section 12 4th October 2007 19:02
Tyre upgrade for NHC Samurai Tyre & Alloy wheel Section 13 29th March 2005 13:56
