Tyre & Alloy wheel Section Everything to do with footwear for your car!
Thread Tools
Old 23rd July 2007, 22:01   #1 (permalink)
basilmabraham's Avatar
Unhappy Help Required: Procuring Alloy Wheel nuts for Palio (98 PCD conversion)
Guys,
I have tried almost all shops in Trivandrum and ernakulam to get a "little longer" wheel nuts for my palioD. The alloys wheels are a bit more thicker than the OE wheels and so the wheel nuts dont screw in properly (only few threads get screwed in). I have been running this potential risk for quite a while now....with the rains and the roads getting more potholes its all the more dangerous...
Can any one help me source these wheel nuts...any one who have changed their stock palio tires to alloys shud be able to help me...
I tried ordering for these at RF motors, from Fiat, with no luck...Please help.
__________________
Never be afraid to try something new.
Remember, amateurs built the ark, and professionals built the Titanic.
basilmabraham is offline   Reply With Quote
Old 23rd July 2007, 22:46   #2 (permalink)
xinome's Avatar
Originally Posted by basilmabraham View Post
Guys,
have you tried new bharath tyres, if you havnt i will ask them when i get my tyres done by the end of this month.
__________________
I meant what I said and I said what I meant. "
बूम शाकालाका बेबी
xinome is offline   Reply With Quote
Old 23rd July 2007, 23:08   #3 (permalink)
kpzen's Avatar
Are the alloys 98 PCD or 100PCD??
__________________
Prajesh
ECLIPSEd
Old 23rd July 2007, 23:27   #4 (permalink)
xinome's Avatar
isnt it the abvious 98pcd! Thats what i here from everyone! am i rite basil
__________________
बूम शाकालाका बेबी
Old 24th July 2007, 00:17   #5 (permalink)
speedzak's Avatar
Exclamation You also bite the dust.
Oh My God!
You also in trouble? I thought only Carfreak had this trouble.
It is indeed a nightmare! I don't know why it is caused. it can be well avoided if the car manufacturer can be a bit more careful when producing/designing a car. Out of many cars I've seen in my short life, only Fiats (especially Palio and Siena/Petra have so much of a problem in this department.
I know many will ask me later to elaborate this! So, let me explain it here itself. People who has a Palio and have switched their alloys according to their liking (without doing a lot of compromise) will understand this scenario better. Especially where Basil is right now. I repeat; It is indeed a nightmare! (And worst, it doesn't end by just opening your eyes from the slumber!).
  1. You cannot get stock nuts because it is too short. So, you have to get a bit longer ones.
  2. If you get longer ones, then it will foul with the brake liners etc.. behind the wheels which is even dangerous.
  3. You cannot get longer nuts and chop/grind a bit and make it of the desired length. Because, the nuts have a specially pointed shape in the tip without which it is a bit hard to get the nuts fit in correctly.
  4. You cannot throw away these alloys because you bought it with a lot of liking for it and with your hard earned money.
  5. Even if you decide to change the current alloys, then You cannot opt for slimmer alloys. Because that will cause the nuts (even the stock/short ones) foul with the earlier said thingys behind the wheels.
  6. If you decide to get something of similar thickness as the stock alloys, then it will be very hard to find one in the market.
  7. Even if you find one to the above said specifications and suits your car's nuts, it will not suit the PCD most of the times due to the odd 98 PCD size!
  8. You can follow what the dealer says and ADJUST a 100PCD alloy to 98PCD and live with it in another risky situation.
  9. Even if you find one alloy suiting all the specifications said above, it may not be to your liking. (I have said earlier; Compromise??)
  10. And after a lot of days and hunting in different countries/cities/towns/villages/jungles etc... you may find one. But it will cost you a bomb!
  11. You can still decide to pay for it and put an end to all. But you may still have problems coming out like one nut broken etc... and the put your car into more riskier situations like running on just 3 nuts etc....
The only option left is compromise that very nice yearning you had for a good set of alloys and go back to the stock ones which Fiat has exclusively designed for you. Again, WHY? Why can't some cars be more simple to modify/personalise??
Why I said all these things???
Because, I have seen (and experienced a bit) how Mr. Carfreak went thru all these. After a lot of trouble, he had to switch back to stock (flowerish) alloys. For that again, he had to pay a bomb!
Anyway, there are some places in Cochin where we can search for these kinda nuts. No, they're not normal tyre/spare parts shops.
@BasilMabraham. Give me a ring next time you are in Cochin.
__________________
Music heaven a touch away!
SK456's Santro.
speedzak is online now   Reply With Quote
Old 24th July 2007, 06:31   #6 (permalink)
Thanks for the replies guys...
@Xinome: appreciate your help...hope you have fond ur dream home...
@kpzen: mine is a 100PCD adjusted to 98PCD in a local tire store, havnt had any problems there though, except for the nut part...
@Zak: you are gem of a guy. Nice detailed reply. Tell you what, I never realised the problem I am faciing, is this bad....Had thought, I just had to get a longer nut...Now it seems even worse...
I had stock steel wheels, which I replaced with these alloys. I did an upsize from 13" to 14", so my new tires wont fit my steel rims. Also, I love my alloys, cant get rid of them. So planning to take te risk of running on "not properly" screwed in nuts.
I have been running on these for almost 20K now...I manage by not taking more than 3 people in the car...
Zak, I go to Cochin almost every weekend, will give you a ring next time I am there.
__________________
Old 24th July 2007, 09:01   #7 (permalink)
speedzak's Avatar
@Basil. I know you come down almost every week. So next time, you give me a ring before you leave Trivandrum.
I'm very much glad you understood my post.
Adjusting the nuts is the most common procedure in this car. They fix the alloys, put every nut in It's holes, screw all of them bit by bit upto a point where everything seems tight.
Is this the only way out of this hell of a problem?
__________________
SK456's Santro.
Old 24th July 2007, 11:50   #8 (permalink)
kpzen's Avatar
Zak..!!
Great work. Very well explained.
I think the Fiats have Bolts instead of nuts for the wheels.
Good to see Basil,a Fiat freak taking it in a good spirit.
__________________
Prajesh
ECLIPSEd
Old 24th July 2007, 14:33   #9 (permalink)
rjstyles69's Avatar
So to sum it up "Palio Owners need to stick to and live with OE Alloys" ?
Zak wonderfully written mate. Good one.
__________________
rjstyles
You never really learn to SWEAR until you learn to DRIVE.
Old 24th July 2007, 15:15   #10 (permalink)
jkdas's Avatar
who's who? you or nut or the car?
you missed the freaky story of carfreak. We will meet up next time so that zak can narrate it again for full effect!
__________________
~ I n d i v i d u a l l y , we are one drop. Together, we are an ocean. ~
Old 24th July 2007, 15:48   #11 (permalink)
artofzen's Avatar
Doesnt Hydarshok face this problem?
__________________
Corum..
artofzen is online now   Reply With Quote
Old 24th July 2007, 16:09   #12 (permalink)
rishibravo's Avatar
Either stick to the OE Alloys or keep looking for 98 PCDs .I failed to do so and took the adjustment route. And I curse my decision when I get a puncture . But when i look at my baby with those rims I feel happy. So its a give some and take some deal. Some take it and some dont. I took it and there have been much more happy moments than the treacherous ones...
__________________
Boyz will remain Boyz.......Only their Toyz change
rishibravo is offline   Reply With Quote
Old 24th July 2007, 16:11   #13 (permalink)
rishibravo's Avatar
Hydrashok doesnt face this problem as he didnt upsize the tyres. Moreover he has PCD 98 HRs I think
__________________
Old 24th July 2007, 16:12   #14 (permalink)
speedzak's Avatar
Mods, Please shift this thread to Tyres and Alloys section. Many Palio owners have this same problem and together, we may find a good solution.
Whenever I meant nuts, it is infact screws! Yes, that is the major problem in Fiat Palio/Petras. How did I forget that??
Normally, Wheels are fitted onto the hubs by just hooking it to the nuts provided in the hubs and then bolt it until tight. In case of this car, there're no nuts/bolts you can hook your alloys onto. You have to depend on a special kind of holder designed by Fiat for their alloys/steel wheels. And again, this cannot be kept when we put new alloys so that has to be removed and so you have to hold the wheel in line with the screwing holes and slowly screw it in.
It is a good procedure because it actually helps us to build some good muscles!
And you cannot just screw in all the way inside. Remember! I told you in my first post about the ADJUSTING part right? That has to be sone carefully to make the car stay on the road. Very tedious job it is!
__________________
SK456's Santro.
Old 24th July 2007, 20:13   #15 (permalink)
artofzen's Avatar
He has upsized his tyres.Those are 15" on his car.
__________________
Corum..
Thread Tools
Damaged Alloy Wheel(Palio Stile1.6) guyonblackybx Tyre & Alloy wheel Section 16 1st October 2008 16:28
Suggestion/Solutions 98 PCD Alloy wheels for FIAT(Palio, Adventure) s.prashanth Tyre & Alloy wheel Section 17 14th July 2008 20:15
Wheel locking nuts Samurai Tyre & Alloy wheel Section 32 3rd March 2008 08:48
PCD Conversion: How Safe and Availability moralfibre Tyre & Alloy wheel Section 13 29th February 2008 08:14
Scorpio Alloy Wheel Size required!! powerpartsrak Tyre & Alloy wheel Section 2 10th January 2007 20:18
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
