Old 3rd January 2012, 12:35   #421
rxpaul's Avatar
Thanked: 99 Times
Default re: Honda Civic : Tyre & wheel upgrade thread
Have you considered the BS Turanza ER 60 ? I have put them on my Octavia recently.
rxpaul is offline   Reply With Quote
Old 11th January 2012, 13:25   #422
Thanked: 29 Times
Finally changed the tyres yesterday. Switched to Michelin PLC 205/65 R15. The initial impression was very good. Never knew the drive in the Civic could be so good. The NCTs that were there earlier made every unevenness in the road be noticed prominently. Now is a completely different story. Even the difference in the ride height helps.
swarooppatil is offline   Reply With Quote
Old 11th January 2012, 13:48   #423
mempheS.D's Avatar
Thanked: 209 Times
Err. A bit of a nursery kid here, but what does PLC stand for ? Are you referring to Pilot Sports?
Saw a couple more abbreviations - CPC2, NCT ???
Appreciate your help.
mempheS.D is offline   Reply With Quote
Old 11th January 2012, 14:01   #424
Nikhilb2008's Avatar
Thanked: 5,067 Times
PLC= Michelin Primacy LC
PP2 = Michelin Pilot Preceda 2
PS2/PS3 = Michelin Pilot Sports 2/3
CPC2 = ContiPremiumContact2 from Continental.
NCT: It's a Goodyear brand. Usually comes as oem on the Civic. The Goodyear Eagle NCT5. Dont know what exactly NCT stands for. There is also an NCT3 in the market but in fewer sizes.
Nikhilb2008 is offline   (2) Thanks Reply With Quote
Old 11th January 2012, 14:22   #425
Blue Thunder's Avatar
Thanked: 330 Times
Thumbs up re: Honda Civic : Tyre & wheel upgrade thread
Thanks for the details, Nikhilb2008!
As per Goodyear website, NCT = Neutral Contour Technology.
Blue Thunder is offline   (1) Thanks Reply With Quote
Old 11th January 2012, 17:07   #426
Thanked: 29 Times
There it comes from the expert himself. By the way thanks to you Nikhil and also Vasoo, for helping me in making that decision.
Old 24th February 2012, 23:13   #427
manim's Avatar
Thanked: 377 Times
Default Michelin PLC
Bought 2 no.s Michelin PLC, Rs.5,500 each.
The older ones have done 48K.
Honda Civic : Tyre & wheel upgrade thread-dsc_5385.jpg
Honda Civic : Tyre & wheel upgrade thread-dsc_5376.jpg
Honda Civic : Tyre & wheel upgrade thread-dsc_5384.jpg
manim is offline   Reply With Quote
Old 27th February 2012, 06:50   #428
Manim, the older tire looks worn out on one of the sides.
What is the reason? Any alignment problem? When did you align the tires and how frequently you do them?
How have you fitted the new tires (front/rear)?
Jidousha is offline   Reply With Quote
Old 27th February 2012, 12:08   #429
manim's Avatar
Thanked: 377 Times
Post re: Honda Civic : Tyre & wheel upgrade thread
Must be the alignment problem, but I check it at the A.S.S every 10K.
I will be fitting the new ones on the rear, as recommended my Michelin.
Check out this recent discussion about this along with the video on this thread (post #35):
http://www.team-bhp.com/forum/street...es-dont-2.html (Living with bald tyres? Don't!)
Old 27th February 2012, 19:04   #430
Looks like the alignment has not been properly done.
Did you do in Tuticorin why don't you try another shop in a bigger city with better facilities.
Although 10k interval is alright for normal run, please check periodically for uneven wear as soon as alignment is done and also if you use the car in rough roads.
I would suggest to invest in 2 more new Michelin tires and replace all the 4 and keep the best of the worn out as spare.
I guess you often use the car in highways and therefore you need highly reliable tires on the front wheels as well.
BTW what is the date of manufacture of the new tires?
Old 27th February 2012, 23:54   #431
manim's Avatar
Thanked: 377 Times
I insisted on the latest stock and got: '4211', '4411'.
That is, Sep 2011 and Oct 2011.
Old 11th March 2012, 11:28   #432
sumeethaldankar's Avatar
Thanked: 1,047 Times
I had topped my BS ER 60 with 30PS air today at the fuel pump and went for a drive.It was 9 Am in the morning and i did not bother to switch on the a/c and left the window down a little.As i drove over the concretised SV road i heard the tyres making quite a racket.I found as the car was going over the concrete sections it made a nasty chapak chapak sound , for a moment i thought i had got a flat tyre.
I rolled up the window and noise was gone and couldn't hear anything.Later when i parked the car to inspect the tyres i found they were all properly infalted and there was no sign of a flat tyre.Is this chapak chapak sound normal for a BS ?
thanks
sumeethaldankar is online now   Reply With Quote
Old 11th June 2012, 16:22   #433
Originally Posted by sumeethaldankar View Post
Some feedback on the 205 upsized.I found the acceleration to be marginally slowed compared to before.The steering now decidedly feels much heavier and the tyres have a very chunky look to them.Though i am not very pleased with slight slow acceleration (maybe my imagination) but the offsets better braking,high speed stability and slight increase in GC would very much make for the cons.
Hi sumeethaldankar
I've been scouring the forums on long term experience of upgrading to 205/65 R15s. What would be your feedback on the following:
1. Any suspension issues?
2. Fouling of the wider tyre with wheel well or suspension?
3. Mileage drop?
4. Any premature Tyre wear that you observed?
navinmra
navinmra is offline   Reply With Quote
Old 11th June 2012, 19:41   #434
suhaas307's Avatar
Thanked: 6,623 Times
I only have good things to say about the new shoes we've given our Nov' 2006 Civic. The car had done 35k and is in pristine condition. The stock Goodyears were honestly horrible. Not only did we have to deal with 4-5 punctures, the grip would be lost very early and it simply did not inspire confidence. The ride wasn't great either.
But now, we've switched to a set of Michelin XM2 - 205/65 R15 and it has helped tremendously. While the ride quality has improved marginally, the car feels more confident around corners and the ground-clearance has improved as well, owing to the wider tyre and the same profile. It grips really well.
The steering seems to have gotten a tad heavier at slower speeds, but lightens up as you go faster.
All in all, I'm happy with the new shoes.
suhaas307 is offline   Reply With Quote
Old 11th June 2012, 20:37   #435
Originally Posted by navinmra View Post
Hi sumeethaldankar
3. Mileage drop?
navinmra
There are no issues with the tyres with respect to suspension issues or premature wear.I have not checked the car yet on a full load ie 5 passengers + luggage so can't say anything when the car is packed to capacity but on regular drive with max 3-4 people i have not seen any case where the tyre hits the wheel well.As for mileage there is no significant change.
Honda City : Tyre & wheel upgrade thread drajesh Tyre & Alloy wheel Section 318 16th January 2018 15:31
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 337 21st December 2017 09:25
Honda Jazz : Tyre & wheel upgrade thread Kenneth Tyre & Alloy wheel Section 124 10th December 2017 11:51
Honda Brio : Tyre & wheel upgrade thread sunnyman_46 Tyre & Alloy wheel Section 39 7th September 2017 13:06
Honda Accord : Tyre & wheel upgrade thread ab500 Tyre & Alloy wheel Section 29 31st July 2017 11:13
