Old 12th July 2012, 11:24   #436
shuvc's Avatar
Thanked: 283 Times
I saw 225/60/15 C Drives the other day.
Tire calculator says it's around a +2.6% upsize and is within tolerable limits. The dia increases by around 14mm.
# will this increase in dia foul with the wheel well?
# can/should 225 width be mounted on the stock alloys?
Old 12th July 2012, 18:52   #437
Thanked: 9 Times
Default re: Honda Civic : Tyre & wheel upgrade thread
225/60/15 is 35 mm wider than the stock size 195/65/15. Anything more than a 20 mm difference in width is not advisable.
See http://www.team-bhp.com/forum/modify...-your-car.html (ARTICLE: Choosing The Right Set Of Tyres for your Car) for more info on choosing the right upgrade.
kranti is offline   Reply With Quote
Old 12th July 2012, 20:29   #438
shuvc's Avatar
Thanked: 283 Times
Hehe ! Yes, I am aware of that .. I've been exploring all options.
I got some answers myself today.
- 225 can be mounted on the stock 6J alloys. I did a test fitting of one wheel at the shop.
- 225/60/15 did not seem to foul anywhere. But then I did not drive with that wheel. Possibly since the dia is bigger, there would remain a chance that the tyre will touch something around the wheel well when going over bad roads/bumps.
Old 12th July 2012, 21:44   #439
Thanked: 9 Times
Lol. I guessed as much, but its surprising how often we overlook the obvious.
However, I'm guessing that it'll be difficult to tell whether 225 would work flawlessly, unless you're brave enough to drive with them. Do keep us posted if you try these out. I'm due for a shoe change in the next couple of months.
Old 16th July 2012, 22:35   #440
shuvc's Avatar
Thanked: 283 Times
After lots of deliberation, switched to 225/60r15 C-Drives on the stock alloys. Car was earlier running on 205/60r15 db-V550.
Drove 40 odd kms today on good roads. I got a feeling I was sitting slightly higher and ride has improved immensely, which is expected given the huge increase in sidewall height. High speeds feel planted as usual. Braking is good too. No drama. Could not get ABS to kick in.
Let me run them in for a few hundred clicks and see how they behave. This being the monsoons, they should get some wet weather exposure too.
Rs. 7580 each !!!! Ouch.
shuvc is offline   (4) Thanks Reply With Quote
Old 16th July 2012, 23:52   #441
iTNerd's Avatar
Thanked: 503 Times
Attachment 957757
225 sounds meaty for Civic . I have 205/65/15 PLC, have run around 30K and now I am contemplating upgrading to 17". Did you get the C drive from ChangeMyTyre.com or from a local dealer? Would be great if you can compare with your previous tyres in terms of noise, grip and wear and tear.
iTNerd is online now   Reply With Quote
Old 17th July 2012, 00:31   #442
shuvc's Avatar
Thanked: 283 Times
Got them from a local Yoko dealer. The choices on 15s were:
- 205/60 ES100 for ~ 6300 iirc.
- 205/60 V550 for ~ 6700 (car was running on these)
- 205/65 V550 for ~ 6300
- 205/65 C-Drive for ~ 6100
- 205/65 A-Drive for ~ 5800 I think. Don't recall.
- 225/60 C-Drive for 7560.
Decided to live life king size for a while !
Noise and wear/tear - time will tell I guess. For now, they sound smooth and grip great too. But then they have a 20mm advantage in width over the V550s. So it's an unfair comparo.
What I liked was that the steering feel hasn't changed. That is there is no apparent added heaviness. Still the perfectly weighted Civic steering.
Old 17th July 2012, 10:23   #443
Tempelhof's Avatar
Thanked: 123 Times
Attachment 957757
Good to hear this. I'll be very keen to know your feedback - so please do keep me in the loop. Which make are these? Where did you buy? Any rubbing against the metal walls?
Tempelhof is offline   Reply With Quote
Old 17th July 2012, 12:26   #444
shuvc's Avatar
Thanked: 283 Times
Sure. Will update this thread as I put on some miles on the car.
Yokohama C-Drive bought from an authorised Yoko dealer, with a proper stamped warranty card ! The first time I've got a warranty card for tyres :-)
No rubbing at all during full lock turns.
shuvc is offline   (1) Thanks Reply With Quote
Old 17th July 2012, 12:53   #445
Tempelhof's Avatar
Thanked: 123 Times
I am impressed. Thanks.
Old 18th July 2012, 22:58   #446
Originally Posted by sumeethaldankar View Post
There are no issues with the tyres with respect to suspension issues or premature wear.I have not checked the car yet on a full load ie 5 passengers + luggage so can't say anything when the car is packed to capacity but on regular drive with max 3-4 people i have not seen any case where the tyre hits the wheel well.As for mileage there is no significant change.
Hi Sumeethaldankar
Thanks for your input. I did go ahead with the 205/65 R15 upgrade and my experience is very similar to yours. The higher sidewalls have improved ride quality and the wider footprint has kinda made the car just a tad sluggish at the start but am pretty pleased with it.
Quick question: What is the ideal tire pressure for this size? I am at 33psi but the tyres visually look under-inflated. Do you think I can go higher?
navinmra is offline   Reply With Quote
Old 27th July 2012, 11:06   #447
iTNerd's Avatar
Thanked: 503 Times
Have decided to get new alloys and tyres for the civic. Contemplating between 16" and 17". Though choice of alloys and tyres are wide in 17", I am leaning towards 16" for a balance in ride quality and handling (and looks).
I am thinking of graphite/Carbon or gun metal alloys. Some of my friends are recommending to opt for black alloys, but I am not too sure how it would come out on a white car. Here are the few I have shortlisted. Your comments would be appreciated!
Name:  candidate alloy 1 H117.png
Name:  candidate alloy 1 H286.png
Name:  candidate alloy 2 H286 black blue.png
Name:  candidate alloy 2 H286 black.png
I like the first one, with the 7 spokes. Only problem is, it is available in machine black, or hyper silver. Not available in graphite/carbon finish. I have been seeing a lot of cars lately with the Blue/Red colored ring on black alloys. Is that the trend with black alloys? And the above alloys are HRS. How good are they? Any other brands I should have a look at?
Old 27th July 2012, 11:22   #448
shuvc's Avatar
Thanked: 283 Times
I would go for no:2. It'll look classy.
And I do feel that graphite gray/gunmetal would look better. For example I like the look of the Jazz alloys.
How much do HRS's these cost?
Old 27th July 2012, 14:34   #449
iTNerd's Avatar
Thanked: 503 Times
Civic's stock alloy PCD is 114.3, I think. And the PCD of these alloys are 100+114.3, width is 7.0 and offset is 40. I guess, it should be an easy fit.
Tyres I have on mind:
215/55/R16 (1.26% difference and gain of 4mm in GC)
225/50/R16 (-0.35% difference and lose of 1mm in GC)
225/55/R16 (3.16% difference and gain of 10mm in GC)
Can the tyres Guru tell me of the above sizes, which one is readily available - Yoko and Michelin?
The gun metal/hyper black/graphite are hard to get by with my choice of the alloy design, I had in mind. But I am searching . Cost is around 20K to 25K for 4 alloys.
I have found some more designs:
which of these would look great on a white civic?
Old 27th July 2012, 22:36   #450
shuvc's Avatar
Thanked: 283 Times
Primacy LC
Pilot Sport 3. My pick !
Too much difference. I would not consider this size.
For me - the last one
Honda City : Tyre & wheel upgrade thread drajesh Tyre & Alloy wheel Section 319 18th January 2018 00:11
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 337 21st December 2017 09:25
Honda Jazz : Tyre & wheel upgrade thread Kenneth Tyre & Alloy wheel Section 124 10th December 2017 11:51
Honda Brio : Tyre & wheel upgrade thread sunnyman_46 Tyre & Alloy wheel Section 39 7th September 2017 13:06
Honda Accord : Tyre & wheel upgrade thread ab500 Tyre & Alloy wheel Section 29 31st July 2017 11:13
