Old 26th October 2013, 20:39   #541
unknown's Avatar
Thanked: 13 Times
Default re: Honda Civic : Tyre & wheel upgrade thread
Hows the yokohame Earth 1 ? & between c drives & 550s which is better ?
unknown is offline   Reply With Quote
Old 28th October 2013, 11:31   #542
spadix's Avatar
Thanked: 185 Times
I've driven only the V550s, so I can't compare. In absolute terms the V550s are *good*. A TBHPian who uses 3STs on his Cruze was complimenting the silence of the V550s on a drive yesterday. Of course, the comparison point was only the silence.
The tyre positioning map on the Yoko website is a good starting point in terms of wrapping one's head around the various products. The Yokos are especially bad when it comes to this as many if the products seem similar in what they offer. :(
spadix
spadix is offline   Reply With Quote
Old 31st October 2013, 11:31   #543
spadix's Avatar
Thanked: 185 Times
Originally Posted by spadix View Post
Finally changed my stock Goodyear Eagle NCT5s. Three of them ran for 37787 km. One had gone completely bald by around the 32500 km mark, so the stepney tyre did "mains" duty for the last 5k kms. Now it's back as the stepney, and the other four have been replaced by Yoko AVS dB v550s in 195/65 R15 size.
I've had the tyres for exactly 20 days now. Did 1726 kms on them so far.
With the older NCT5s, I noticed that tyre pressure never dropped in 2 or 3 weeks even, so I'd stopped checking once a week like I used to in the very early days after buying the car. Instead I used to combine tyre pressure monitoring with refueling visits, which typically happen once in 3-4 weeks (on average if I'm mostly driving in-city) for me.
Continuing in that vein I topped up air for the first time today after the Yokos were installed and found the pressure (cold) to be around 23-24 psi in all four tyres! I use the same pump I always visit.
When the tyres were mounted 31 psi was pumped into them and valve caps were also installed.
So I should now monitor pressure once a week (which is a good practice anyway) as these tyres seem to demand that compared to the NCT5s. Or at least I should make it a point to definitely monitor on every refueling visit (had 4 of those in the 1726 kms) without getting out off due to either laziness or by the line at the air pump.
spadix
Old 31st October 2013, 13:42   #544
Thanked: 20 Times
This is such a hard decision .. sigh !
From my Civic tyres I want (like most of us) ;
1. A soft ride
2. Silence
3. Grip
Here's my dilemma.
I believe that up-sizing to 205/65 R 15 will give a better ride due to the (slightly) increased sidewall height. Is this true ? Are there any other foreseeable problems ? Any chance of the ABS sensor accuracy being affected by the (very small) increase in the diameter ?
Could all members who have upsized to this size please provide their personal feedback. Is it worth upsizing or should i stick to the stock size ?
Secondly,
I wanted to initially go for the Yokohama C Drives, but they are very difficult to obtain and some tyre dealers have mentioned that they are going to be discontinued. Obviously then, i would want to avoid them, as if i (God forbid) need a replacement in the future i won't be able to get the same pattern.
The AVS db V550 also have been replaced in Thailand and other similar markets by the Advan db V551. That would lead me to infer that the AVS db V550 would also be gradually phased out if the Advan db is introduced here.
Nikhil / Irags .. and all other tyre experts, are the Advan db going to be introduced here in the near future ?
I was also suggested the Pirelli Cinturato P1 by a dealer here who said that it would provide a soft ride. Any inputs on the Pirellis ? Why aren't they popular in our market ?
and
The Michelin Primacy 3 ST are only available in 195/65 R 15.
However if these are so good that they will give the same dynamics without an up-size i don't mind this option either.
What do you guys advise ?
Heeelllllllllpppppppp !!
revvhed is offline   Reply With Quote
Old 8th November 2013, 14:28   #545
Nikhilb2008's Avatar
Thanked: 4,793 Times
1. A soft ride
2. Silence
3. Grip
Here's my dilemma.
Secondly,
and
There is no chance of Advan being made in India anywhere in the near future. A best case could be where Yokohama at least brings it to India.
Nikhilb2008 is offline   (1) Thanks Reply With Quote
Old 9th November 2013, 14:59   #546
Thanked: 72 Times
1. A soft ride
2. Silence
3. Grip
Here's my dilemma.
I went for 205/65/15 Michelin XM2 for my Civic.No problems whatsoever due to upsize even with 5 people + full boot load . Ride will be lot better due to up-size you can get rid of common problems like under body scraping on speed breakers etc. You will enjoy increased stability in high speed cornering as well. Did not notice any impact on ABS.
Cheers.
ramanak is offline   (2) Thanks Reply With Quote
Old 9th November 2013, 18:51   #547
spadix's Avatar
Thanked: 185 Times
The Michelin Primacy 3 ST are only available in 195/65 R 15. However if these are so good that they will give the same dynamics without an up-size i don't mind this option either. What do you guys advise?
3ST is available in 205/60 R16 etc. but at around 9300-9600 per tyre. So if you really want a 205 cross-section you could upgrade to 16" alloys and get this.
The manual mentions 205/65 R15 as well, so I assume it's within design spec ABS/suspension/etc.-wise.
spadix
spadix is offline   (1) Thanks Reply With Quote
Old 9th November 2013, 19:14   #548
Thanked: 20 Times
Thanks for the replies guys.
@ Spadix - I see that you have not upsized and retained the stock 195s. May i know the reason for this decision please ?
@ Nikhil - What is your feedback on the Pirelli's ?
Old 9th November 2013, 20:48   #549
spadix's Avatar
Thanked: 185 Times
Many reasons. I was happy with stock tyre width and profile. I didn't want the added steering weight, lower fuel efficiency and higher cost of a wider section tyre. And at that this stage of my life, with a little kid in tow, I definitely won't be carving corners. Not that that would have mattered, because I could never ever get even the pathetic stock Goodyear Eagle NCT5s to squeal. So 195 section on any new tyre that's better than stock is already more than sufficient in terms of cornering grip.
spadix
Old 23rd December 2013, 18:46   #550
Thanked: 50 Times
Same old question friends, does upsizing have any major cons? i am planning to change my stock tyres and am confused between 195 65 R15 and 205 65 R15s. Have spoken to at least 5 different dealers and have received varied responses from all. Changemytyre.com confidently suggests that a shift from 195 to 205 will not create any problem.
Also, all dealers have unanimously recommended Bridgestones (Turanza Er 300) irrespective of 195 or 205. Are these really the best? Or should i try the Michelins/Yokos/any other brand?
I am looking for minimum road noise and uncompromised road handling (especially at high speeds on highways). I do not mind if the FE takes a minor hit. However, I do not want any additional scraping issues due to the upsized tyres. Changing the rim is not option.
rohan.xj is offline   Reply With Quote
Old 24th December 2013, 10:59   #551
For a Civic, 205/65-15 is the perfect upsize. You will not have any issues with the car. I myself am running 205/65-15 Michelin Primacy LCs on my car and am very happy with the increased ground clearance and better ride comfort.
In 205/65-15, you can go for the Yoko A drives, C Drives, Michelin XM2, and lot of other options.
Old 24th December 2013, 11:16   #552
Thanked: 20 Times
Hey Nikhil,
What's your feedback on the Pirelli Cinturato P1 ?
Old 24th December 2013, 11:43   #553
dinu2506's Avatar
Thanked: 320 Times
I ran my Civic on 205 65 R15 Bridgestone Turanza ER60 for 3 years before I sold the car. Absolutely fantastic tyres and no complaints.
dinu2506 is offline   Reply With Quote
Old 24th December 2013, 13:39   #554
Thanked: 50 Times
Thanks Nikhil, getting the new tyres fitted asap!
Thanks for the advice on Bridgestones Dinu, i will scout the market for Michelins, else Bridgestone Turanza ER 300 it is!
Old 24th December 2013, 14:54   #555
dinu2506's Avatar
Thanked: 320 Times
Mine was not ER300, it was ER60. I run the same on my Verna as well. Have had absolutely no complaints. Slightly pricier compared to the A Drives.
Honda Jazz : Tyre & wheel upgrade thread Kenneth Tyre & Alloy wheel Section 124 10th December 2017 11:51
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 333 25th November 2017 20:12
Honda City : Tyre & wheel upgrade thread drajesh Tyre & Alloy wheel Section 317 12th September 2017 07:16
Honda Brio : Tyre & wheel upgrade thread sunnyman_46 Tyre & Alloy wheel Section 39 7th September 2017 13:06
Honda Accord : Tyre & wheel upgrade thread ab500 Tyre & Alloy wheel Section 29 31st July 2017 11:13
