Old 19th December 2014, 15:28   #586
Default re: Honda Civic : Tyre & wheel upgrade thread
My Civic need shoe change as it has crossed 40k and nearing 7yrs. Please suggest some good shops in sarjapur / HSR area (bangalore) area ?
swageo is offline   Reply With Quote
Old 19th December 2014, 19:56   #587
Thanked: 40 Times
Had ordered via Snapdeal for a set of 4 Yoko Earth1 (195/65R15) for around 1.5k less per tyre.
Got tryes manufactured in june, have fitted them and no issues whatsoever.
Just a suggestion, can use the saved money on some accesories though
Adi22 is online now   Reply With Quote
Old 29th December 2014, 16:44   #588
Changed all 4 tyres to XM2 205/65/R15. Steering has become bit tight. Road noise is low
But biggest problem is when you take turn at highway speed (~100kmph). I feel like car is going to drift outwards. May be its just a feel, but not something I like. Is it because of higher profile ?. i.e 6mm higher than my stock tyre.
I did a 40K service at Honda ASS, and they made a remark on the advice sheet. "All tyres over sized and not recommended".
Old 2nd January 2015, 17:08   #589
Thanked: 118 Times
swageo,
205/65 is a lot of rubber, some 'squishy' handling & 'mushy' ride is to be expected. On the upside, I'm sure the car is supremely comfortable!
If the steering is very tight, it is advisable to check your tyre pressures lest they are running underinflated.
6.5mm taller sidewall to be exact, but there are other things in play here like tyre construction (sidewall stiffness), condition of suspension (especially the rubber parts and struts), tread compound, alignment, etc.
Honda is known to have small tyres, a friend of mine has been running 195/65R15 on his City for over 4 years without problems. You can easily ignore the service notes.
bharatsomany is offline   Reply With Quote
Old 3rd January 2015, 00:59   #590
sumeethaldankar's Avatar
Thanked: 781 Times
My Civic has 205's running on it and i have found the steering had become harder to turn after fitting the upsized tyres.Also my car has faced power steering leak problem twice in 3.5 years and somehow i do feel the up-sized towards though not directly but could have contributed to faster wear and tear of the power steering pump seals etc.May be people who have 205's or other up-sized tyres on their Civic's could confirm if they ever had a power steering leakage issue with their cars especially after fitting bigger tyres.
sumeethaldankar is online now   Reply With Quote
Old 21st January 2015, 18:41   #591
1lokesh's Avatar
Thanked: 352 Times
Got my Civic's stock tyres upgraded last year to Yoko C Drive 205/65/R15
Have done 10k+ after that and have rarely heard that ominous sound of underbelly getting scraped through some badly built bumps.
Haven't noticed any issue with the steering hardness. But yes, HASS has recently reported steering oil leak. On second opinion, FNG rejected the fault.
So, IMHO, there is no clear connect between tyre upgrade and steering oil leak.
Also C drives have been very good till date. Although, I think that Michelin is quieter, but my past experience with Michelin wasn't really great hence preferred Yokos. And I'm happy with the decision.
1lokesh is offline   (1) Thanks Reply With Quote
Old 21st January 2015, 19:04   #592
WasavaTyres's Avatar
Thanked: 184 Times
My pre owned civic was running on 235/40/R17 for 3 years before I bought the car about six months ago. I have downsized her to 205/55/R16 since the previous tyres were too stiff. No issues with the power steering setup at all. The car has clocked 31K kms to date.
WasavaTyres is offline   (1) Thanks Reply With Quote
Old 31st January 2015, 20:26   #593
black12rr's Avatar
Thanked: 264 Times
Changed all four tires to Michelin P 3ST 195/65 R15 , initial impression is smooth . Also changed new valves, balancing and alignment.
Madhu's did a good job to do everything perfect and fast .
black12rr is offline   (1) Thanks Reply With Quote
Old 24th February 2015, 23:04   #594
Thanked: 71 Times
Mine has done 29k km (odo is at 89 k) after upsizing to 205/65/15.No issues whatsoever with power steering.
ramanak is offline   (1) Thanks Reply With Quote
Old 6th April 2015, 22:59   #595
Thanked: 30 Times
Post deleted by the Team-BHP Support : Please do NOT post messages that add little or no informational value to the thread. We need your co-operation to maintain the quality of this forum.
Please read our rules before proceeding any further. We request you to post ONLY when you have something substantial to add to a discussion.
spoth001 is offline   Reply With Quote Received Infraction
Old 10th October 2015, 11:23   #596
Thanked: 781 Times
Default Re: Honda Civic : Tyre & wheel upgrade thread
My Civic's Turanza's developed minor surface cracks and have now started making noises (whoop whoop kind) while driving on certain surfaces. Is 4 years long enough for the tyres to start cracking? I have done around 33k kms in 4 years on these 205 65 R15 spec tyres. I guess the low running contributed to the wear. I would mostly keep them for a additional 6-7k kms and dispose them off. No more Turanza's for me. Probably will go for Goodyear Assurance or MRF ZlO when i change.
Old 10th October 2015, 22:46   #597
khoj's Avatar
Thanked: 1,229 Times
Are these Turanzas from the GR90 or ER60 series?
Old 10th October 2015, 23:00   #598
Thanked: 781 Times
They are the ER 60 series.
sumeethaldankar is online now   (1) Thanks Reply With Quote
Old 11th October 2015, 08:48   #599
Thanked: 781 Times
Honda Civic : Tyre & wheel upgrade thread-tmp_834820151011_0831431101077125.jpg
Honda Civic : Tyre & wheel upgrade thread-tmp_834820151011_083112755277705.jpg
Notice the cracks on the tyre,is this normal for a 4 year tyre. Also tread depth is sufficient but tyres give out funny noises while driving on asphalt roads. They are ok on concrete roads though. Anyone faced such funny noises. I have had 2 cars before, i dont recall anyone making whoop whoop sound when they were driven on old tyres. Previous cars had goodyear/ MRF hence inclined to go for same once i am through with the Turanzas.
Old 26th January 2016, 20:20   #600
ajslave's Avatar
Thanked: 9 Times
Hello all. I picked up a used, 2007 model SMT Civic this month.
The car had 36k kms on the odo and the owner hadn't had the factory tyres changed at all (except one tyre).
So ordered a set of 4 Yoko E400s in 205/65/R15 size from PayTm, received these Dec 2015 manufactured tyres.
Going to get them fitted in a day or two and will report with an update.
Honda Civic : Tyre & wheel upgrade thread-img_20160126_200250.jpg
Honda Civic : Tyre & wheel upgrade thread-img_20160126_200258.jpg
ajslave is offline   Reply With Quote
Honda City : Tyre & wheel upgrade thread drajesh Tyre & Alloy wheel Section 299 26th March 2017 18:10
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 307 23rd March 2017 17:23
Honda Jazz : Tyre & wheel upgrade thread Kenneth Tyre & Alloy wheel Section 99 25th February 2017 12:17
Honda Brio : Tyre & wheel upgrade thread sunnyman_46 Tyre & Alloy wheel Section 32 13th October 2016 14:49
Honda Accord : Tyre & wheel upgrade thread ab500 Tyre & Alloy wheel Section 27 27th May 2016 17:26
