Old 6th September 2008, 00:42   #16
sanju.sreekumar's Avatar
Dont go beyond 185/60/R14..i have got that on my Ikon 1.6 and i have no probs at all!
Sanju
sanju.sreekumar is offline   Reply With Quote
Old 6th September 2008, 11:32   #17
ghostrider's Avatar
Thanked: 307 Times
Paiyappa, I JUST finished a thread on upgrading the rims and tyres on my Ikon, so I can actually tells you from experience what will work and what won't.
Mine is the 2006 model, so she had 175/65 R14 rims. I wanted to upgrade to 15" rims and a nice set of tyres. Finally chose Lenso SHU Mirror Lip Rims and Yokohama S-drive 195/50 R15 tyres. I wanted to get a slightly taller profile (195/55), but we tested it and found that under full load in the back (3 people) there was a high chance of the rims rubbing against the wheel-wells and mudflaps.
The rims and tyres got fitted yesterday, and she rides like a dream. The grip is amazing, and yes, the ride is a little firmer, but not significantly. It's not at all uncomfortable, and it's not at all compromising the suspension.
Things to note:
1. Try to get alloys either from Lenso, League, or HiJoin. Yes, Aura rims come wmith a warranty, but that is ONLY against manufacturing defects. If you damage a rim, the warranty won't help you. The imported rims look MUCH bettter, so check them out first.
2. Don't go beyond 195/50 R15. Yes, it's possible to do that, but then you're going into dangerous territory.
3. MAKE SURE your offset on the rims is +38, and that your PCD is 108. THIS IS VITAL.
4. I have no opinion on Maxis, but the Bridgestone Potenza GIIIs are best avoided. If your budget allows, get either BF Goodrich, Michelins or Yokohamas.
5. Get 5 rims and 5 tyres. If you ever damage a rim, you have a spare.
Good hunting!!
Originally Posted by paiyappa View Post
I talked to the dealer, he advised not to go beyond 185. He says the right size would be 185/60 R14.
He does have the Michelin Energy XM1, at around 2800 in this size but he is suggesting that I look at Federal and Good year, and another brand called Maxix.
How do you feel about these brands; havent really heard of Maxix, the dealer says it is catching the market in Bangalore. Federal I have seen on quite a few cars, nice looking threads but unsure of performance....
ghostrider is offline   Reply With Quote
Old 6th September 2008, 22:51   #18
ghostrider's Avatar
Thanked: 307 Times
Paiyappa,
I just uploaded some pics if you want to see what she looks like with the new rims and tyres. Here's the link: (Upgrading my Ikon 1.6 to 15" rims... advice?).
Brilliant levels of grip, the tyres and nice and quiet, and the ride comfort is perfect.
Oh, and did mention I think they look awesome???
Good hunting!!
Old 11th March 2010, 23:20   #19
lloydofcochin's Avatar
Thanked: 180 Times
Default Tyres for Ikon 1.6
Fellow BHPian's,
Need help in buying Tyres for my Ikon 1.6.
I bought the Car used and it is closing in on 50k and the tyres have worn out and needs replacement.
I am planning to upsize to 14" since Ikon OEM tyres are 13".
I was thinking about upsizing to 185/60-14, Michelin as per the info on the threads here but when I spoke to the guy at Sai Iyengar he said that it is not advisable to do so and suggested 175/65/14. He also quoted 3.8k per tyre.
I need to get all 5 and I am looking for 14" Steel rims as well. Any idea how much would it cost, and where to get it from? I am looking for a durable and dependable tyre with a Ladakh plan too in mind.
Now eagerly waiting for some advice
lloydofcochin is offline   Reply With Quote
Old 11th March 2010, 23:41   #20
Nikhilb2008's Avatar
Thanked: 6,656 Times
185/60 R14 is the correct size. Whoever told you that is mistaken. Lots of guys on the forum are running 185/60 R14 and have NO problems whatsoever.
The XM1+s are too expensive in this size. Get the Yoko C drives. Will cost you about 3700 or so.
14" steel rims in 108 PCD is near impossible to find. Tata rims might be available on J C Road but stay away. They are quite soft. Ford rims are difficult to get hold of.
If you buy genuine rims from the Ford service centre, you will be charged around 3k for a set of 5.
If you are looking at a Ladakh plan, then scrap the Michelins, Yokos, etc... get the MRFs and be happy.
Dont expect ride comfort, handling, etc... though.
Old 12th March 2010, 00:03   #21
Thanked: 180 Times
Thumbs up
Nikhilb2008, Thank you for your detailed reply.
Now the Ladakh plan is not 100% sure. I'm all for it but my friends should agree too
Which tyre would be better if it is for general use? I mean with decent handling & ride comfort? And can I buy the original 14" rims from Metro Ford or Lathangi Ford? Don't mind spending 3k for that.
Old 12th March 2010, 00:14   #22
You should be able to buy it from them. For normal city use, I would recommend the Yoko A drives or the C Drives as the XM1+ is too expensive in that size.
Old 12th March 2010, 00:23   #23
Thanked: 180 Times
Nikhilb2008, Thank you for your prompt reply.
Will check with Ford dealers regarding the rims. So I guess it is safer to stick to Yoko A or C drives, is it? Which one would be better for a mix of 70% Highway + 30% City use? Is there a price difference between Yoko A drive & C drive?
Old 12th March 2010, 00:25   #24
nitrous's Avatar
Thanked: 285 Times
I'd say get 13" stock steelies and run 175/70/13 for Ladakh.
Old 12th March 2010, 00:29   #25
Thanked: 180 Times
Nitrous, Any particular reason for that? I'm curious . Upsizing to 14", Will it help GC?
Old 12th March 2010, 00:41   #26
Jaguar's Avatar
Thanked: 151 Times
I am one such user, running 185/60 R14 PP2s. No issues whatsoever for the past one year
Jaguar is online now   Reply With Quote
Old 12th March 2010, 12:30   #27
Thanked: 180 Times
Guys,
I spoke to the spare parts guy at Lathangi Ford and he said that they have Fiesta 14" Steel rims @ Rs.1200/- apiece. Now he said that the wheel rim is not wide enough to accommodate 185/60 R14's since the Fiesta comes with 175/65R 14's and that will only fit the rim.
Any suggestions on this? I don't want to go for alloys since this vehicle is only sparingly used and wouldn't want to invest too much on it.
Old 12th March 2010, 13:00   #28
Forged_Piston's Avatar
I think the ikon nxt came with 14" wheels as standard.My ikon has them.You could try and source these.185/70 fits perfect on these.
You could also try getting second hand wheels from a tyre and accessories shop.But please check for any damages.
Forged_Piston is offline   Reply With Quote
Old 12th March 2010, 13:38   #29
anurag_p80's Avatar
Thanked: 7 Times
What is the width of the rims? As long as they are 5.5 and above you should be fine running 185/60....
anurag_p80 is offline   Reply With Quote
Old 12th March 2010, 14:02   #30
para_7k's Avatar
Thanked: 65 Times
Originally Posted by lloydofcochin View Post
Guys,
Yes, I guess there rims are 5J and will not safely accomodate 185 section tyres.
As you don't have plans of alloys, get grippy rubber in 175/70 R13. For 185, it will be difficult for you to source rims as most of the cars that come with 185 as OE sizes also come with OE alloys (The i20, Swift Z series, etc.,)
para_7k is offline   Reply With Quote
Audi A6 Right Tyre Size? Leo_Rulez Tyre & Alloy wheel Section 6 27th October 2011 22:31
How Do You Determine The Right Size of Performance Filter For Your Car abhik Technical Stuff 39 8th July 2008 23:38
max tyre/alloy size for my Ikon? plz help young_icon Tyre & Alloy wheel Section 25 9th October 2007 09:16
Tyre Size and alloy wheels for Ikon Flair shalini_g Tyre & Alloy wheel Section 0 3rd May 2006 17:30
