Old 2nd October 2007, 20:47   #91
iraghava's Avatar
Thanked: 154 Times
Or else play around with the pressure a bit. If you find the ride bouncy decrease it by 2 psi & see and vice-versa if you find the car feels a bit heavy (especially the steering).
Old 2nd October 2007, 21:42   #92
What TYRE PRESSURE should be ideal for an good ride quality , life & high speed stability with this tyre setup (i.e. 215/55 R16) ??
Technically if you have changed from 205/55 R16 to 215/55 R16 the pressure should be reduced a bit from OE recommended pressure.
The rason for above reduction in pressure is: now you have tyres with bigger volume to accomodate air inside.
Talking about high speed highway driving :
in such case always better to overinflate your tyres by 3-5 psi.
In high speed highway driving tyres do not get enough time to spring back to normal shape (deformation casued at the point of road contact) such condition leads to excess heat generation(in such condition tyres do not perform to the optimum level of performance).
itzzme is offline   Reply With Quote
Old 3rd October 2007, 13:36   #93
Akshay1234's Avatar
Thanked: 6,727 Times
itzzme - but ive always found that if you increase your pressure by that much then the ride gets very bouncy.
Old 3rd October 2007, 15:36   #94
In this case of high speed highway driving safety is more important than anything else. This overinflation avoids overheating and failures related to it.
Old 3rd October 2007, 21:01   #95
karan561's Avatar
Thanked: 9,342 Times
I feel 30psi - front , 29psi - rear , in city should be good , whereas , highway driving 32psi - front 31psi - rear should be ideal ? ? ?
what say ?
karan561 is offline   Reply With Quote
Old 3rd October 2007, 21:17   #96
Akshay1234's Avatar
i guess that would be fine. but try and it and see whether you like it or not.
Old 3rd October 2007, 21:25   #97
karan561's Avatar
I have this combi at the moment , havent tried the highway combi yet ... but right now it feels silky smooth.
Old 17th October 2007, 20:42   #98
adnan's Avatar
Default bridgestone adrenalin re001
hi guys... my bro got a laura...wanted to change the tyres of it... so wanted to know which tyre to opt for...how about bridgestone adrenalin re001...looking for a comfortable ,smooth drive...
adnan is offline   Reply With Quote
Old 18th October 2007, 09:20   #99
androdev's Avatar
Thanked: 1,786 Times
i have 31psi front, 29psi rear. very nice for the city.
androdev is offline   Reply With Quote
Old 18th October 2007, 10:10   #100
One of the latest launches by Bridgestone, but not homologated for India.
Old 18th October 2007, 11:09   #101
karan561's Avatar
Why do you need to chenge the STOCK ones .. Turanzas itself provide you a great ride comfort.
Old 18th October 2007, 11:20   #102
androdev's Avatar
comfort/soft ride yes. but road noise could be lower. i was told Michelin Primacy Pilot are quieter than OEM. maybe i will buy these when my next tire change is due. not worth changing now - the OEM ones are alright.
Correct tire pressure makes *HUGE* difference in terms of comfort and noise. First thing to check after getting the vehicle from the dealer!
Old 27th March 2008, 18:54   #103
androdev's Avatar
The factory fitted Bridgestone Turanza (205/55-16) front-left tyre on my Laura developed a sidewall crack + small rupture after 9800KM. Asked TAFE Bangalore to replace it under warranty. They started the "process" by sending a photo of the damage to Skoda and said will take two weeks time and I am afraid it will take longer than that. But I suspect this type of damage wont be covered under warranty and I have decided to forget about warranty and instead use this as an opportunity to do some shopping. Here are my options. Please post your recommendations:
1. Replace the damaged tyre alone with the same make/spec. Since my spare tyre is brand new (and same spec) I will effectively have a pair of new tyres.
>>>How much does a new Bridgestone Turanza (205/55-16) 91V cost?
2. Get 5 new tyres. Requirements: Safety (grip, handling), Comfort (avg will do), decent longevity. Michelin Pilot Preceda (PP2) is what I am considering.
>>>How much does a set of 5 PP2s (205/55-16) cost?
3. What is the approximate budget for "pimp my ride" option: 17" alloys (18" is bad?) + matching PP2 tyres?
I am leaning towards option#1 and option#3.
Old 28th March 2008, 11:27   #104
androdev's Avatar
*bump* help please?
Old 28th March 2008, 11:40   #105
karan561's Avatar
I had got my Tyre replaced(for free) @ JMD Skoda when my Tyre had developed a SIDE WALL AIR BUBBLE ... got passed as a manufacturing DEFECT of the Tyre .
not Sure what will the case be in case of a SIDE WALL CRACK.
But the procedure took about 2 weeks .
Skoda Rapid : Tyre & wheel upgrade thread kryptonite Tyre & Alloy wheel Section 137 16th October 2017 17:28
Skoda Yeti : Tyre & wheel upgrade thread Invinsible Tyre & Alloy wheel Section 474 2nd August 2017 17:22
Fiat Palio : Tyre & wheel upgrade thread shahmotors Tyre & Alloy wheel Section 637 26th March 2017 12:56
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 10 29th August 2016 17:08
