Old 22nd August 2007, 01:32   #1
Thanked: 80 Times
Default Tyre Up Size for MAGNUM...!!!
hi guys,
i'm gettin a Magnum optra in a few weeks...
wht would be the right upsize for it...?
stock is 195/60 rims 15...
can i go to 16 inch without compromising on ride quality especially the cusioning over potholes and bad roads...?
please suggest....
thanks...
rana_kirti is offline   Reply With Quote
Old 22nd August 2007, 05:43   #2
hellspawn's Avatar
Infractions: 0/1 (10)
imho the stock size is the perfect size for our indian roads.you have the option of upgrading to 16" but then you will surely lose out on road comfort.
hellspawn is offline   Reply With Quote
Old 22nd August 2007, 07:19   #3
Rudra Sen's Avatar
Thanked: 4,295 Times
Do not go for 16 inch. It'll give you good look for sure with a bad ride.
Old 22nd August 2007, 09:50   #4
rishibravo's Avatar
The stock tyres for the magnum are perfect. I dont think you should go for an unsize. 16 inchers will look awesome. But going for a lower profile will definitely deteriorate the ride quality.
rishibravo is offline   Reply With Quote
Old 22nd August 2007, 09:54   #5
Originally Posted by rana_kirti View Post
hi guys,
please suggest....
thanks...
As you go from 15" to 16" tyre sidewall flex zone is reduced thus your ride comfort is reduced.
At the same time your handling, steering response, braking, highway high speed stability is improved.
You need to decide and list your priority.
If comfort is your prime requirement please do not inch-up.
itzzme is offline   Reply With Quote
Old 22nd August 2007, 11:51   #6
faithless_1984's Avatar
Thanked: 217 Times
The stock size is 15` and he just wants to upsize to 16` which is just one size above the stock so IMHO the rides not gonna be that bad ,its not like he`s going from 13` to 16`....but then am no tyre expert.
I agree the ride quality will decrease but if he stays with a profile of 55 (dont know the correct size,please correct me if am wrong) then i guess he can go for 16` rims.
faithless_1984 is offline   Reply With Quote
Old 22nd August 2007, 12:41   #7
shuvd's Avatar
Got the Magnum recently. Don't want to change the stock alloys (though they look ugly). How about a bit wider (205) rubber on the stock rims? What should be the proper up size in this scenario?
shuvd is offline   Reply With Quote
Old 22nd August 2007, 12:44   #8
iraghava's Avatar
Thanked: 156 Times
Correct upsizes would be:
205/60-15
215/55-15
Old 22nd August 2007, 12:49   #9
shazikon's Avatar
Thanked: 19 Times
Unless you have driven the Magnum a lot, it doesnt make sense going for a upgrade right after purchasing the car. You must understand how the car behaves on a rough road with stock wheels and rubber and then decide. May be you can go for better or wider tires for starters.
shazikon is offline   Reply With Quote
Old 22nd August 2007, 13:26   #10
shuvd's Avatar
@ iraghava - Thanks. Since the Yokos are still not available in Calcutta, guess I'll look at Michelins. (Stock Goodyear GSD3 or something)
Old 22nd August 2007, 14:14   #11
shuvc's Avatar
Thanked: 287 Times
Minku might have stock of Falken's too
Old 22nd August 2007, 17:32   #12
iraghava's Avatar
Thanked: 156 Times
No problem. And stock's would be either Goodyear GT3 or NCT 5, GSD3 won't be stantdard.
Old 22nd August 2007, 18:37   #13
shuvd's Avatar
@ shuvc - Whats wrong with Falkens? You have seen my Falkens. They're holding their own quite well IMO
@ iraghava - Uh-oh! My mistake.
Old 22nd August 2007, 19:48   #14
well i also thought of upsizing to 205/60/15 but somehow i feel stock tyres are good enough.
saketnagpal is offline   Reply With Quote
spare tyre size aadix Tyre & Alloy wheel Section 8 29th October 2006 23:50
Tyre Size aveek Tyre & Alloy wheel Section 4 19th August 2005 23:02
What tyre size on 2002 santro ? tabrez02 Tyre & Alloy wheel Section 2 3rd May 2005 13:53
Getz and City max tyre size ? jesal The Indian Car Scene 16 2nd November 2004 20:00
