Tyre & Alloy wheel Section Everything to do with footwear for your car!
Thread Tools
Old 22nd August 2007, 14:48   #1 (permalink)
Default Advice Required for Neo Alloy for Accent
Dear All,
I need some guidance from all the senior and experianced people regarding My Accent 2001 model. I want to upgrade the stock rims to alloys. I want to know what is exactly is the problem of Wheel scraping in the Neo set of wheels. I'm talking about the below mentioned model.
Model name: RALLY
Size(inches): 13 x 5.5
Offset(mm): 36
Backspacing: 116
Holes: 4/5
PCD(mm): min-98 max 114.3
Boredia(mm): min-58.4 max 70
Finish: Hi Tone Machined
One fellow member has put up his alloy for sale and I'm interested in the same but wanted to know will the scraping problem be with Accent also? Also the Neo Wheels website confirms that the same can be used with Accent, but they don't offer any warranty for this partcular model. Any particular reasons which you all can think off.Can you all also confirm if the same can be used in Accent without any modification or change?
Saurabh
saurabhkum is offline   Reply With Quote
Old 23rd August 2007, 19:47   #2 (permalink)
VC12's Avatar
Not suure of Rally model, it could be more to do with the Finish.
I have recently purchased Dozen model and have done my research ( has none of any such problems) , call 022 27602272 contact Sangeeta @ Neo wheels office in Mumbai.
She call explain .
__________________
VC 12=>>>
VC12 is offline   Reply With Quote
Old 23rd August 2007, 20:05   #3 (permalink)
faithless_1984's Avatar
Good that you posted your query here ,now can you post a pic of the alloys ? or provide a link ?
__________________
Why so serious ??
faithless_1984 is offline   Reply With Quote
Old 23rd August 2007, 20:23   #4 (permalink)
This is the link of Neo wheel here just check for Rally Model
Neo Wheels India
The link of sale of fellow BHPian which I'm planning to pick , provided rate is good and it fits properly is
http://www.team-bhp.com/forum/indian...sale-pune.html
I just want to be sure that this fit into my Accent without any modification. I don't want to get into trouble later also it will be cause discomfort to Manish who is selling it
Old 23rd August 2007, 23:45   #5 (permalink)
kpzen's Avatar
Accent PCD is 100....
The alloys which are for sale should be 98 PCD
__________________
Prajesh
If you think your teacher is tough, wait till you get a boss.
Old 24th August 2007, 01:35   #6 (permalink)
WasavaTyres's Avatar
Does Neo make 8 nut-hole alloy wheels ?? As far as I know, they make rally only in 100 and 108 PCD and only 4 hole models. I've fitted 108 PCD wheels onto and Ikon and an Indica,both very satisfied clients. Just get your PCD issue cleared.
__________________
Man made booze........
God made grass.........
Who do u trust ??
WasavaTyres is offline   Reply With Quote
Old 24th August 2007, 08:32   #7 (permalink)
VC12's Avatar
Yes, NEO makes perfect PCD as per most cars in India and so it has exact 4 holes with PCD as specified by the car co's.
However there are many other models from NEO having 8 holes too...
Saurabh,
Check the exact PCD for accent it may be 100, for Ikon& Indica it is 108.
__________________
VC 12=>>>
Old 24th August 2007, 10:15   #8 (permalink)
Originally Posted by VC12 View Post
Saurabh,
In that model of Neo it's mentioned as PDC from 98 to 114.3 does this mean that while bying a new one they fix the PDC to say 98 or 100 or 108 which can't be modified latter?
Old 24th August 2007, 10:22   #9 (permalink)
VC12's Avatar
NO,
Check with Hyundai guys and ask them the PCD for your accent model or you ll find in you car manual.
the details mentioned by NEO is that it has rally model for the cars between that PCD's.
__________________
VC 12=>>>
Old 24th August 2007, 10:51   #10 (permalink)
kpzen's Avatar
Accent PCD is 100 and the alloys which are for sale is 98PCD
__________________
Prajesh
Old 24th August 2007, 11:10   #11 (permalink)
True, but is there a way to get the same fitted to Accent.
Old 24th August 2007, 12:01   #12 (permalink)
VC12's Avatar
Saurabh,
I suppose Prajesh's point was loud and clear, is it Prajesh selling them?
__________________
VC 12=>>>
Old 24th August 2007, 12:21   #13 (permalink)
iraghava's Avatar
Guys as Kevin just said the alloys are 98 PCD i.e. they are meant for fitment on to Fiat's not Accent's. Please get 100 PCD alloys for your car.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Old 28th August 2007, 14:35   #14 (permalink)
It means, Neo manufactures the same design in 98, 100, 108 & 114.3 PCD. They cannot be modified or interchanged with some other PCD. A 98 pcd meant for Fiat should not be used on any other 100 pcd vehicle
__________________
sn48001
sn48001 is offline   Reply With Quote
Old 17th February 2008, 17:05   #15 (permalink)
Leave aside Neo...I suppose Aura from Hindalco might have something you are looking for!!
I have heard that Aura has a good range of alloy wheels...has anyone tried any models from Aura...? Or better if anyone could tell me which one is better between aura and Neo!!
Harshad is offline   Reply With Quote
Thread Tools
Alloy + Rubber for an Accent viva crdi? rider60 Tyre & Alloy wheel Section 48 3rd July 2008 21:38
Help Required: Procuring Alloy Wheel nuts for Palio (98 PCD conversion) basilmabraham Tyre & Alloy wheel Section 32 27th October 2007 03:36
Alloy Wheels Advice Dinesh99 Modifications & Accessories 16 8th May 2007 13:57
Scorpio Alloy Wheel Size required!! powerpartsrak Tyre & Alloy wheel Section 2 10th January 2007 20:18
Alloy Wheels Required For Wagon R raja_ys Shifting gears 0 1st October 2006 23:46
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
