Old 29th August 2007, 17:53   #1
Default four options for MARUTI 800 ...which one is better
About Car- MARUTI 800 STD 97 Model with AC . has done 62000 KM .
I travel about 750-900 per month which is about 60:40 city & Highways ratio.
Fuel efficiency , good ride & SAFETY are important. look is not of my priority. I have these options.
All are 12" only as it seems 13" rim will reduce my FE & bit bumpy.
  1. Goodyear GT 770 145/70/R12 ( Rs1275 each )
  2. Goodyear GPS 2 145/70/R12 ( Rs1400 each )
  3. Goodyear TUBELESS GPS 2 145/70/R12 ( Rs1450 each )
  4. Goodyear TUBELESS GPS 2 155/70/R12 ( Rs1520 each )
For TUBELESS planning to go for12" RIM( 650/-)- wheelsIndia Brand.
is that OK.pl let me know which one seems to be good choice ?
Any other better option kindly let me know. TIA.
shapath is offline   Reply With Quote
Old 29th August 2007, 17:59   #2
gopz's Avatar
Check out this thread:
http://www.team-bhp.com/forum/tyre-a...800-tires.html
gopz is offline   Reply With Quote
Old 29th August 2007, 19:20   #3
Akshay1234's Avatar
Thanked: 7,241 Times
please also look at other brands like bridgestone.
Old 29th August 2007, 19:47   #4
snaronikar's Avatar
Thanked: 23 Times
BS have good tyres and will last long......I had the same on my car.....
snaronikar is offline   Reply With Quote
Old 30th August 2007, 00:16   #5
akshay1234
any specific reason for BS.?
snaronikar: do you have Tube or Tube less . what is the SIZE and model no. thanks.
Old 30th August 2007, 00:39   #6
WasavaTyres's Avatar
Thanked: 255 Times
I suggest you go for GPS2 tube / t-less depending on where you drive. GPS2 is a much slower wearing compound compared to GT770+ which was launched just to give the consumer a lower priced alternative to GPS2.
WasavaTyres is offline   Reply With Quote
Old 30th August 2007, 08:02   #7
WasavaTyres can you pl explain this point - " tube / t-less depending on where you drive"
Old 5th September 2007, 00:01   #8
Thanked: 255 Times
What I mean is depending on your regular route,make sure you have proper tyre repair shops en route as an ill equipped shop or a repairman who doesn;t kow how to proprely fix a tubeless tyre wud ruin it.
Old 5th September 2007, 07:56   #9
Thanked: 253 Times
I would recommend you go for tubeless and use 'Slime' or 'Airseal Tyre Milk' to puncture-proof your tyres.
Old 5th September 2007, 08:28   #10
Thanked: 44 Times
Personally I found the GPS 2 to be a comfortable tyre. Bridgestones are also very good, do give them a try, they are possibly the best quality tyre made in India.
Go for tubeless on new rims, the difference in the ride quality is worth it, and educate yourself about tyre repair procedures.
filcord is offline   Reply With Quote
Old 6th October 2007, 13:56   #11
hi shapath, go for the g3s in 165 60 r 12 real good .if u need help in getting them pm me . paid 1850 a piece
manek is offline   Reply With Quote
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
Mission Leh! Four people, one scorpio and one helluva road trip! (Delhi-Leh Sep 2011) speed crusader Travelogues 15 11th July 2012 19:50
Which one is better : Fusion or Fiesta? dphe Sedans 15 7th August 2007 18:21
So which one is a better value here? Zappo Hatchbacks 5 28th February 2007 15:32
"Which one sounds better" BAD 130Y The International Automotive Scene 4 8th June 2006 20:49
