Old 3rd September 2007, 15:09   #1
Vino_David's Avatar
Default Suggest for tire and alloy - Santro
Tyrestore chennai quoted,
Michellin XMI - 2,490 per tyre
Bridgestone Turanza - 2500 per tyre
HR alloy 13" - 13,650 (4)
prices okay ??? gurus
Vino_David is offline   Reply With Quote
Old 3rd September 2007, 15:16   #2
manikjeet's Avatar
Thanked: 109 Times
the price of alloys is a little higher
when i asked for the price of the xm1 i was told by the dealer its for 2200 per tyre
manikjeet is offline   Reply With Quote
Old 3rd September 2007, 15:33   #3
Vino_David's Avatar
can any chennai gurus suggest me a dealer offering cheaper that what i said ??
Old 3rd September 2007, 15:51   #4
akroy's Avatar
Thanked: 29 Times
What is the tyre specs?
I got Michelin XM1 155/65R13 for 2175 / tyre in Bangalore...
Abhi
akroy is offline   Reply With Quote
Old 3rd September 2007, 17:30   #5
crazydiablo's Avatar
Thanked: 21 Times
Does the prices of alloys include the special bolts also? HR is slightly higher than other brands. If its inclusive of nuts, fitting and alignment then it may be OK. you can still bargain for something
crazydiablo is offline   Reply With Quote
Old 4th September 2007, 00:23   #6
kpzen's Avatar
Thanked: 1,598 Times
Whats the tyre spec?
If its 165/65-13 then the price quoted is fine.
Old 4th September 2007, 10:21   #7
Vino_David's Avatar
ya its 165-65-R13 for santro, can the prices be still reduced, i see for same specs and same tire brand, many here quoted less price ??
gurus suggest
Old 4th September 2007, 12:41   #8
kpzen's Avatar
gurus suggest
Michelin XM1 price quoted seems to be fine. I think u can bargain a little to make it 2400 per tyre.
The two tyres u have mentioned are one of the best available 13" tyres in the market..
Old 4th September 2007, 16:54   #9
khanak's Avatar
Thanked: 128 Times
You can also check out 175/60/13 Bridgestone Potenza GIII @ 2700 and 175/60/13 Yokohama A539 @ 2400.
khanak is offline   Reply With Quote
Old 4th September 2007, 17:09   #10
Vino_David's Avatar
thanx gurus for valuable input
Wagon R tire upgrade, inner tire wall touching suspension Wind splitter Tyre & Alloy wheel Section 36 6th August 2012 20:43
Tire and Alloy upgrade for the new (2011) Ford Fiesta aseem Tyre & Alloy wheel Section 12 22nd July 2012 13:12
Why rim size is as critical as tire pressures or tire sizes !! speedsatya Tyre & Alloy wheel Section 23 12th July 2011 18:00
Use of Old car tire, Tire Art! Beautifully done, Must see. SirAlec Shifting gears 2 18th March 2011 22:02
Swift tire pressure and fixing spare alloy wheel doubt ece2k2 Technical Stuff 24 21st March 2008 21:57
