Old 6th September 2007, 18:52   #1
sushrutha's Avatar
Thanked: 325 Times
Default HELP -OHC under body(silencer) scraping speed breakers
I have OHC (Type -2) 1.3EXi. The underbody (silencer) is getting heavily scrapped on the speed breakers, Can you people help me to over come this.
What could be the possible reasons for this?
My tyres will last another 5,000Kms (13" ones). I have to change the tyres.
I'm thinking of puttin 14" rims with tyres. Do i need to do any modifications to the suspension(say adding a spacer) or is it a direct fit in ?
Are my shocks weak ??? ( car has run 85K kms) If i press the car's body, my car doesn't bounce.
Pour in your suggestions
Thanks in advance
Old 6th September 2007, 19:06   #2
Akshay1234's Avatar
Thanked: 7,239 Times
i think the problem could be with your shocks. but anyway the ohc are known to have low clearance. did this happen earlier or has it started happening off late?
Old 6th September 2007, 19:57   #3
manson's Avatar
Thanked: 2,230 Times
The Ohc has low ground clearance, but at the same time something seems to not be functioing if the stock exhaust seems to be scraping.
Your car has clocked 85,000 kms, you surely need to get the suspension checked. Do let us know how it goes.
About the wheels, 14 or 15" wheels would be pretty ok, and would not scrape the fenders or anything.
I've been running my Ohc with 195/55/15 since almost two years now, and i havent heard a tyre scrape even one single time.
manson.
manson is online now   Reply With Quote
Old 7th September 2007, 10:34   #4
sushrutha's Avatar
Thanked: 325 Times
Well I need to check the suspension pretty soon.
@Manson... Is 14" / 15" rims/alloys direct fit in or did u put in any spacers ? or did you do any modifications?
Old 7th September 2007, 10:48   #5
lohithrao's Avatar
Thanked: 163 Times
Hey Sushrutha,
This is a common problem.
Solutions:
Go for "185,70,13" tyres, this will solve your problem to some good extent. atleast my ohc did manage to go through some bad speed brakers without scrapping.
About increasing the rim size... it wont make that great diffrence as higher the rim size you will have to scarifice on the profile of the tyre. This is what i learnt and agree with the logic.
I think you better check your suspensions, am sure it will need some work.
btw looks like you bought this machine recently, how much did you buy it for? pics etc?
lohithrao is online now   Reply With Quote
Old 7th September 2007, 10:54   #6
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Your shocks are the culprit. I don't think you have any rebound.
Old 7th September 2007, 11:04   #7
sushrutha's Avatar
Thanked: 325 Times
@lohithrao
I'm planning to go with higher profile (say 80 profile for the 13").
Saw ur garage pic. where was the photo taken ? was it in NH 48 ( sakleshpur) or charmadi ghats?
What are options to raise the suspension?
Yeah brought my car last week.
Got it from my relative( same town) for 2.65Lakhs...
Paid NCB, New battery . so it came for 2.75L...
Once i'm done with the tyres, suspension etc it may come close to 3L ...
Car is mostly run on highways. Chickmagalore - Bangalore-Chickmagalore
Old 7th September 2007, 11:08   #8
sushrutha's Avatar
Thanked: 325 Times
But as far as i know the car shouldn't rebound many a times if the suspension is good.
Correct me if i'm wrong.
Old 7th September 2007, 11:29   #9
lohithrao's Avatar
Thanked: 163 Times
Originally Posted by sushrutha View Post
@lohithrao
Hi Suchrutha,
Yae its taken on "Shiradi" ghats, on my way back from my home town(Mangalore)
Sounds like a good deal. even i hav a 1,3exi. got my suspension stiffened by Fazal(FRK) prior to that handling was very poor and very unconfortable.
Yae higher profile would be better but am not sure if you will get "80"??
Old 7th September 2007, 11:33   #10
sushrutha's Avatar
Thanked: 325 Times
Can I have FAZAL(FRK) contact number n workshop/garage address with nearest landmark
Let me consult him
Old 14th December 2007, 12:04   #11
abhinethra's Avatar
Lohith,
Are there any spacers needed for the stock suspension for 185/70-13?
I am planning to upsize for the same as I too am facing the scraping issues on a full load.
The sidewall increases by 7 mm (12.5-122.5)
ATM
abhinethra is offline   Reply With Quote
Old 14th December 2007, 14:00   #12
Shan2nu's Avatar
Thanked: 89 Times
Thanks in advance
Same prob on my car. I'm planning on removing the primary muffler, using a straight pipe and refitting the 2ndry muffler at the end.
Yeah, it should just come back to it's original height and stay there. If it bounces many times, that means your suspension has gone soft.
Shan2nu
Old 14th December 2007, 16:43   #13
Thanked: 103,359 Times
If thats 85K on the stock dampers, yes...they are pretty much beyond useable life.
Old 14th December 2007, 19:46   #14
toiingg's Avatar
Thanked: 83 Times
Originally Posted by abhinethra View Post
Lohith,
ATM
No spacers are needed if you are upsizing from 175/70 13 to 185/70 13
I have it on my ride, no issues whatsoever.
toiingg is offline   Reply With Quote
Old 26th November 2009, 15:58   #15
adi_iceman11's Avatar
Thanked: 7 Times
Even my OHC scrapes when its loaded with 5 people !
i was thinking of 185/50 R15 OR 185/55 R15 OR 185/60 R15 !
In quite a dilemma about it !
Help Please !
adi_iceman11 is offline   Reply With Quote
Art of taking Speed Breakers(humps) without scraping the belly. dhanushs Technical Stuff 66 26th April 2016 11:32
Upsized my Civic's tyres. Now scraping under load! keertan Modifications & Accessories 14 8th June 2011 14:35
IT companies got a new project- Building speed breakers WhiteKnight Street Experiences 39 18th February 2008 15:38
Hole in silencer (OHC VTEC). Need help. hondadude Technical Stuff 18 15th February 2008 14:19
Scraping the Underside of my OHC aveek Modifications & Accessories 21 21st October 2005 14:15
