Tyre & Alloy wheel Section Everything to do with footwear for your car
LinkBack Thread Tools
Old 19th September 2007, 10:08   #1 (permalink)
gopz's Avatar
Default Replace the tyres?
Hi TBHP! I have stock tyres on my 2001 M800 which has done about 51000KM till date. The tyres are good and might go on for another 10k KM (well maintained car isnt it )
...but the manufacturing date on the tyre is Dec2000
Should I keep these tyres or just throw them away and get new ones? Because they are almost 7 years old!
I had plans to sell this car, but now I ve decided to keep it.
I am planning to go in for 145/80 R12 when I change them next.
gopz is offline   Reply With Quote
Old 19th September 2007, 10:21   #2 (permalink)
Shelf lfe of rubber is around 5-6 years, its good if you can change your tyres now.
Why you want to switch to 145/80 R12??
itzzme is offline   Reply With Quote
Old 19th September 2007, 10:31   #3 (permalink)
akshay1234's Avatar
since youve decided to keep the car then why not get new tyres? anyway your tyres are pretty old. also are you going to get alloys? then upsize to 13".
__________________
Accord V6
Pete'd Innova
Stage 1 Getz
akshay1234 is online now   Reply With Quote
Old 19th September 2007, 11:02   #4 (permalink)
gopz's Avatar
I am influenced by ram's thread..it improves the handling and ride.
http://www.team-bhp.com/forum/tyre-a...800-tires.html (Maruti 800 tires)
@ahskay1234: I am not going for alloys
Old 19th September 2007, 11:14   #5 (permalink)
akshay1234's Avatar
you could get wider steel rims and get 165/60 r12 potenza g3s. now that would improve your handling.
__________________
Accord V6
Pete'd Innova
Stage 1 Getz
Old 19th September 2007, 11:19   #6 (permalink)
kpzen's Avatar
It will surely improve the ride but don't think there will be any improvement in handling.
In the market GIIIs are totally out of stock AFAIK.
__________________
Prajesh
Old 19th September 2007, 11:30   #7 (permalink)
gopz's Avatar
165/60R12
well that would bring down my mileage and pick up, isnt it?
I'd rather stick to 145/80R12
Old 19th September 2007, 11:56   #8 (permalink)
akshay1234's Avatar
i doubt 12" would be.
gopz - that would bring down your mileage a bit but if your doing mods on your car then it would be fine. i remember a thread you had created about mods for your car.
__________________
Accord V6
Pete'd Innova
Stage 1 Getz
Old 19th September 2007, 12:10   #9 (permalink)
kpzen's Avatar
165/60R12
Yes, its better to stick with 145/80-12 for an old car.
Chances are almost nil otherwise it would be an old stock .
__________________
Prajesh
Old 19th September 2007, 12:11   #10 (permalink)
gopz's Avatar
yup..im going for a K & N + free flow later
how much mileage would go down with those tyres? I am OK with a drop in 2km but if its going to drain my petrol tank then I will stay away
and how much do these tyres cost?
Old 19th September 2007, 12:29   #11 (permalink)
gopz, better decide whether you want performance (handling) or comfort.
145/80R12 is good for comfort (and economy) while 165/60R12 would give you better handling (but reduced ground clearance).
anupmathur is online now   Reply With Quote
Old 19th September 2007, 12:38   #12 (permalink)
gopz's Avatar
I want high GC and comfort/economy.
I called up a dealer here, he said that potenza g3 is out of stock (12")
I probably will stick to 145/80R12 - which is the best tyre in this size?
Old 19th September 2007, 13:26   #13 (permalink)
gopz's Avatar
How are Bridgestone Turanza's ER-60 145/80R12??
Old 19th September 2007, 13:29   #14 (permalink)
mobike008's Avatar
Turanza's are great tyres for a nice comfortable ride with a bit of performance thrown in. Potenza's are out and out performers.
__________________
I have terrible reflexes- I was once run over by a car being pushed by two guys !!!!!!!
mobike008 is online now   Reply With Quote
Old 19th September 2007, 13:40   #15 (permalink)
Ram
Ram's Avatar
165/60R12 will give you a wheel with outer diameter of 502.8 mm (19.8") with 9.9 cm of rubber sidewall.
145/80R12 will give you a wheel with outer diameter of 536.8 mm (21.1") with 11.6 cm of rubber sidewall.
Ergo, 145/80R12 would give superior ride quality and 17 mm more ground clearance than the 165/60R12.
As the 165 mm wide 502.8 tall tire will have both more grip and lower diameter, it will yield poorer fuel economy than the 145 mm wide 536.8 tall tire.
Ram
__________________
The world doesn't care about your self-esteem.
It expects you to accomplish something to deserve to feel good about yourself!
Ram is online now   Reply With Quote
Thread Tools
SX4 Zxi, JK Vectra Stock Tyres, should I change to low profile tyres ? Shankyz Tyre & Alloy wheel Section 24 19th December 2009 21:10
Difference between slick tyres and bald tyres watashi75 Technical Stuff 32 5th August 2009 15:26
Alloys And Tyres For Innova. EDIT: With New Tyres. Mugen_Power Tyre & Alloy wheel Section 144 28th February 2009 00:20
Replace only two worn out tyres forbhaskarm Tyre & Alloy wheel Section 11 5th January 2008 11:28
Exchange - 185 Michelin Tyres -with- 175 Honda City Tyres eflanker Shifting gears 2 23rd September 2007 18:36
Powered by vBulletin
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2000 - 2010, Team-BHP.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654
