Old 19th September 2007, 21:51   #1
Thanked: 44 Times
Default Baleno rear-wheel alignment
Apologies if this has been posted earlier.
I believe the Baleno, with independent rear suspension, will require rear-wheel alignment also in addition to front-wheel alignment. Can anyone confirm. And if so, what should the values be?
filcord is offline   Reply With Quote
Old 20th September 2007, 02:15   #2
rohan_fonseca's Avatar
logic says rear wheel alignment is required for independent suspension. But try finding someone to do that in Goa!
rohan_fonseca is offline   Reply With Quote
Old 20th September 2007, 14:52   #3
crazydiablo's Avatar
Thanked: 21 Times
Good that you brought it up... will check at 20K
crazydiablo is offline   Reply With Quote
Wheel alignment or wheel balancing?? leodelg Tyre & Alloy wheel Section 27 22nd June 2011 00:44
Toyota innova Rear wheel alignment problem neo_trace Technical Stuff 13 30th July 2010 00:18
Newbie questions - wheel balancing, wheel alignment. johy Technical Stuff 8 6th December 2006 10:39
