Tyre & Alloy wheel Section Everything to do with footwear for your car!
Closed Thread
Thread Tools
Old 28th September 2007, 18:37   #1 (permalink)
Deeps's Avatar
Default Tube tyres converted into tubeless - Is it possible and safe??
In the last two weeks, i have come across two tyre dealers who say they can convert the regular stock tube-tyres of my Xeta into tubeless ones.
This is the procedure according to them:
1.Remove Tube
2. Check tyre for any existing punctures and then repair them.
3. Fit the valve to fill air.
4. Check for leakages by filling tyres with water.
The cost is around 500/- depending on how many punctures need to be carried out. So experts, what;s your take on this? Is it a safe practise? Have had four punctures in the last seven days so i am tempted by this option as long as it is safe.
__________________
Stupidity is not a handicap! Park somewhere else!
Deeps is offline
Old 28th September 2007, 18:44   #2 (permalink)
WasavaTyres's Avatar
Infractions: 0/1 (4)
I can vouch that goodyear tubetype tyres can safely be used as tubeless tires b'coz thier tubetype tires also have a halo butyl lining inside the tires which prevents air from permeating,resulting in loss in air pressure.Would not know about other brands for sure. A simple way to find out is to look at the inside of the tires. Tires with halo butyl linign would have a texture-effect on the walls,whereas plain tires would look just that plain on the inside with radial lines on the walls at the most.
__________________
Man made booze........
God made grass.........
Who do u trust ??
WasavaTyres is online now
Old 28th September 2007, 18:50   #3 (permalink)
n_aditya's Avatar
Deeps, topic already exists. Please use the search function.
linky: http://www.team-bhp.com/forum/tyre-a...onversion.html (Tube-type to Tubeless conversion?!)
n_aditya is offline
Old 28th September 2007, 20:22   #4 (permalink)
Team-BHP Moderator
aah78's Avatar
Exclamation
Thanks n_aditya.
Thread closed. Please continue discussion in the existing thread.
__________________
Ein bißchen Frieden
aah78 is offline
Closed Thread
Thread Tools
Tube-type to Tubeless conversion?! tsk1979 Tyre & Alloy wheel Section 37 22nd July 2008 13:21
Tubeless or tube type for wagonR without PS english Tyre & Alloy wheel Section 14 12th December 2007 04:37
Using Tube in Tubeless Tyre! saurabhkum Tyre & Alloy wheel Section 5 29th November 2007 18:08
Tube-Type Tyres Converted to Tubeless - Is it safe? bhp Tyre & Alloy wheel Section 39 30th September 2006 13:23
Tube inside tubeless tires... Samurai Tyre & Alloy wheel Section 1 25th February 2005 15:32
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
