Tyre & Alloy wheel Section Everything to do with footwear for your car!
View Poll Results: Rate Bridgestone Turanza [ b/w 1 and 10 --- 1--poor ---> 10 Best]
1-2 1 5.56%
3-4 0 0%
5-6 4 22.22%
7-8 10 55.56%
9-10 3 16.67%
Voters: 18. You may not vote on this poll
Thread Tools
Old 10th October 2007, 11:03   #1 (permalink)
kick.throttle's Avatar
Cool Bridgestone Turanza
Hi friends
Yesterday I upgraded my santor with Bridgestone Turanza Tubeless Tyers 165/65/R13. One of my friends said that the Bridgestone Turanza are not so good tyers. He recommended my potenza. But i prefered Turanza becaues its indian make. But still, i Would like to hear from you guys about the quality of the tyre..
ARE Bridgestone Turanza good Tyres????
__________________
2006Dec Santro Xing[160kmph]
2006 Honda Activa[85kmph]
kick.throttle is offline   Reply With Quote
Old 10th October 2007, 11:21   #2 (permalink)
rks
rks's Avatar
I have also fitted Turanza ER-60 tyres for my Santro (1 lit model). These tyres are more than good enough for Santro. In fact even my previous S322 tubeless tyres provide good enough grip for Santro, except that they are more noisy than Turanza. I have done about 1000 kms with Turanza and my impression is good so far. One observation is that this tread pattern picks up less junk from the road than the S322, especially those annoying little stones.
What needs to be seen is
(1) How good these tyres are after the tread has worn, say, after 20000 kms -- do they retain good grip and braking (especially in monsoon) and handling (cornering)?
(2) Secondly, what would be the life of this tyre under high speed driving (130+ kmph) on the Expressway concrete?
(3) And of course, how resistant are these tyres to impact with potholes/stones on the bad roads in the monsoon season.
The S322s were OK on (3), but bad in (1) and (2). The wet grip/braking and handling became bad after 20000 kms, and the tread wore out after 24000 kms, but this may have been due to failing suspension and steering components in my car.
With the side-wall protectors in Turanza, I think (3) is not a major worry and the fuel economy seems OK (despite the presumably better grip that this tyre has due to its H-rating, as compared to S322). And the H-rating plus suspension/steering column work on my car should give Turanzas the edge in (1) and (2) as compared to my previous S322's.
Old 10th October 2007, 11:31   #3 (permalink)
FATAL3RROR's Avatar
Hi!
I have recently shod my Esteem with Bridgestone Turanzas. The tyres are extremely comfortable and noise levels have drastically reduced.
Even I have noticed less picking of junk by the tyres as mentioned by rks. Have done close to 4000 kms on them on all kinds of roads. They haven't let me down.
Enjoy the Turanzas!
FATAL3RROR is offline   Reply With Quote
Old 10th October 2007, 11:35   #4 (permalink)
that was good review on the Bridgestone Turanza 165/65/R13.
Well what is the mileage that you are getting now. And how do less road noice help. If the Road noice is more.. what it reflcts??? what does that mean???
and what is the diffrence b/w Potanza and Turanza
__________________
Old 10th October 2007, 12:01   #5 (permalink)
rks
rks's Avatar
@kick.throttle: I have fitted stock size (155/70 R13) Turanzas (and my previous comments applied to this size, not 165/65 as you mentioned). The mileage I get is about 11-11.5 km/lit in city and 12-13 km/lit on highway (depending on the speeds done). The mileage may have dropped slightly as compared to S322, but it is not noticeable and the car has also just been serviced, so I am not sure about the comparison.
Tyre noise does not affect performance. It may bother you if you wanted to relax by listening to music or the radio. The G3 Potenzas are also supposed to more noisy than Turanzas.
The G3 Potenzas are more oriented towards performance. They will give better grip, but they are not really needed for Santro, for which Turanza is more then good enough. G3 Potenza may give you slightly less mileage and may have a lower life than Turanza (being more oriented towards performance means that the rubber will be softer). So they may also be less resistant to bad roads than Turanza. And finally I think you will get only 175/60 R13 or 165/60 R13 tyres in G3. But the latter is not the correct upsize, you need 165/65.
Old 10th October 2007, 12:27   #6 (permalink)
zakaaaaasss's Avatar
My Matiz is running these Turanzas ER60 for past 1 year 6 months now...way back, while buying, infact the dealer (a friend of mine) told me that I was the first person to buy as they were recently launched then.
till date have done around 10-11K kms on them...here are my observations:
1) the threads looks new even today and the tyres have not lost the sheen (unlike s322 that start looking bad IMO very soon). no punctures, yet, touchwood!
2) they are little noisier than the S322 (@rks my observation inverts yours!). i have used s322s on 3 cars till now....and yes the s322s do long last (40-50K kms) under normal driving conditions as compared to GPS2. Too early to say anything abt the ER60s.
3) I have stock size on Matiz (145/70R13)..i find roadgrip and comfort same like S322. The GPS2 seems to provide more comfort and are definately less noisier.
4) The threads design attracts small stones to get trapped...i guess the distance between threads is marginally more as compared to s322/gps2.
zakaaaaasss is offline   Reply With Quote
Old 10th October 2007, 12:49   #7 (permalink)
yes mane are 165/65. that sound correct size for my santro. not driven much on it.. [may be 25KM only as of now.] ...
wait for a long drive once i fix my suspensions.. met with an accident 2 weeks back. 2 alloys damaged and 3 stock tyres got screwed. thats y i upgraded to new 165/65. wil post the pics soon
__________________
Old 10th October 2007, 12:52   #8 (permalink)
lohithrao's Avatar
Have been using Turanzas om my OHC for sometime and am loving them!
__________________
" I'd rather live with the consequences of my actions rather than the regrets of my inactions."
lohithrao is online now   Reply With Quote
Old 10th October 2007, 12:52   #9 (permalink)
ER60 means what
is that you too got 165/65/R13.. dose this mean ER60???
I m new to this and hence dont know much about the readingof tyres and parameters. but... good things is that i m learning....
__________________
Old 10th October 2007, 12:57   #10 (permalink)
kjdesigns_2000's Avatar
I have fitted 185/70 Turanza on my esteem.
Grip is nice, noise is low, small stones are always stuck here and there and i get a FE of 15-16 km/l with tyre pressure of 30, and looks very nice and smart
When these will wear out i will surely go for the same thing again.
kjdesigns_2000 is offline   Reply With Quote
Old 10th October 2007, 13:01   #11 (permalink)
Originally Posted by kick.throttle View Post
ER60 means what
ER60 is the Series name like others are EL42, ER30, ER300, etc
ER60
Old 10th October 2007, 14:07   #12 (permalink)
rks
rks's Avatar
The greater width of the tread pattern seems to help in trapping fewer stones. The stones that are trapped are more easily removed. With S322, the stones were very tightly stuck in the grooves and were hard to remove.
Old 10th October 2007, 14:29   #13 (permalink)
Steeroid's Avatar
I use Turanza GR80s on my Lumina SS here. These came highly recommended by various dealers. Overall the experience has been mixed but highly enjoyable. Noise levels are much lower than most other tyres, the tyres are rather comfortable despite the low profile, but come summer my grip levels have slipped a bit in the heat. Nothing too drastic - its now JUST right for the parking lot drift and the manic roundabout exit with your tail sticking out, if you know what you're doing. Hence the enjoyable part.
I will wait until winter to confirm whether the change in grip levels is caused by the heat, or whether the tyres have actually lost grip after a few months of usage.
__________________
Steer
The Land is in the past, now where do I find the 6-cylinder Ponton?
Steeroid is offline   Reply With Quote
Old 10th October 2007, 15:28   #14 (permalink)
I have been on ER60 for 10,000km on my indica and they have given me no problem at all, only thing is they are not a stiffer side so the ride in hard...other than that really good tyres.
dinar is offline   Reply With Quote
Old 10th October 2007, 15:40   #15 (permalink)
kpzen's Avatar
Is this thread specifically for the ER 60 or the whole Turanza series of tyres??
All the tyres in Turanza series dont perform the same. So how do we vote??
__________________
Prajesh - << will be mostly offline till August >>
A true friend is someone who says nice things behind your back...
Thread Tools
why MRF are costlier than Bridgestone ? sankeerthreddy Tyre & Alloy wheel Section 12 26th June 2008 13:07
Bridgestone Potenza G3 - First Impression.... Shan2nu Tyre & Alloy wheel Section 33 12th October 2007 20:19
Goodyear vs Bridgestone. namit Tyre & Alloy wheel Section 3 10th July 2007 11:57
Bridgestone in trouble ??? ranjan united Motor-Sports!! 10 18th September 2006 22:24
Bridgestone B700 AQ naveendhyani Tyre & Alloy wheel Section 2 24th April 2006 15:50
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
