Old 18th October 2007, 00:07   #1
Thanked: 44 Times
Default optimum tyre pressure on upgrades
Most cars have a placard showing recommended tyre pressure on the tyres the car came with as OE.
What happens when you upgrade? I cannot find any guidance.
In my case I had 165/80R13 on the Baleno, tyre pressure recommended was 29 psi. Now I upgraded to 185/70 r13. Should I maintain the same 29 psi?
Is there any formula to calculate the new pressure, based, say on the increase air volume after upgrade?
The Car Tyre Bible (sorry don't know how to post the link) suggest you can go upto 10% below the max recommended pressure printed on the side of the tyre. In my case the Michelins have 44 psi printed as max pressure. Does this mean I can go up to 44 - 4.4 = 39.6 psi?
Expert opinions please!
filcord is offline   Reply With Quote
Optimum ground clearance of a Car? & how it is measured... skamb Technical Stuff 84 17th May 2017 22:36
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
Optimum techniques for defogging the windscreen Samartha Technical Stuff 35 24th January 2012 21:20
Swift ZXI : Won't get to optimum engine temperature level bhogalrajnish Technical Stuff 11 27th November 2009 17:20
