Old 21st October 2007, 22:50   #1
redeye's Avatar
Default Lancer Tyre Size help for 15inch
Hi guys , i'm changing my stock alloys to a lenso 15inch Nx
http://www.uniracingwheel.com/wangye/LENSO-NX.jpg
why 15inch ?
cos i want performance and looks. cos if i use a 16inch the ride gonna get hard right.
also i drive mostly on high ways .
which size rubber should i use
2055015?
redeye is offline   Reply With Quote
Old 21st October 2007, 23:12   #2
rjstyles69's Avatar
Thanked: 795 Times
I think the NX Series has 15 inchers, the pic you have posted doesn't indicate 15 inchers though.
The lancer's PCD is 100(NX series is 100 PCD),so make sure that you pick up 100 PCD and 205/50/R15 is perfect me thinks.
Wait till the experts comment on the upsize.
Old 26th October 2007, 23:40   #3
redeye's Avatar
waiting for experts comments on the upsize
Old 26th October 2007, 23:44   #4
Vid6639's Avatar
Thanked: 21,052 Times
Hey redyeye, I think rjstyles has given you good advice on the upsize.
The lancer also takes 205/55-15 but one will have to be careful with the offset as that can foul with the wheel arch.
Old 27th October 2007, 00:09   #5
kpzen's Avatar
Thanked: 1,655 Times
Perfect suggestion for a Lancer.
Old 27th October 2007, 00:16   #6
razor4077's Avatar
Thanked: 258 Times
Yup, go for 205/50/15. I fitted that size on my Lancer and have had no problems with scraping or fouling. Perfect upsize.
There will be an speedo error of around 3.9% with this size, but as long as you have this in mind, it should not be a problem.
205/55/15 is a closer match to the OE size, but as vid says, it may foul with the wheel arches, especially under some load. It's also a slightly uncommon size and not easy to source.
razor4077 is offline   Reply With Quote
Old 27th October 2007, 00:43   #7
kpzen's Avatar
GLX and SFXi had two different tyre sizes with quite a different OD which why calculating the upsizes for Lancer still creates some doubt.
Old 28th October 2007, 11:54   #8
redeye's Avatar
guys i'm not satisfied with alloys Lenso nx . they look different in real compared to the pic above. the spokes are have too much curve . i think this won't suit my lancer but looks beautiful on swifts .
guys tell me other alternative alloy model numbers which suit lancer pls.
Old 28th October 2007, 12:33   #9
kpzen's Avatar
HR alloy HR-109......
Old 28th October 2007, 12:57   #10
redeye's Avatar
how about lenso rs5 white for my red lancer
Old 28th October 2007, 19:47   #11
Flyin very low's Avatar
hey bro redeye even i am planning to install the same LensoNX 15" in my black swift .
Flyin very low is offline   Reply With Quote
Old 28th October 2007, 20:54   #12
nitrous's Avatar
Thanked: 285 Times
195/55 is what I'd use for the 87bhp car.
Old 29th October 2007, 21:58   #13
redeye's Avatar
@Flyin very low- Bro these alloys will look beautiful will post some pics of the same alloy of some car ...
Old 30th October 2007, 20:10   #14
redeye's Avatar
@flyin very low - Leden Saxo's
Old 19th February 2008, 10:19   #15
redeye's Avatar
thanks guys for your suggestions i finally ended with these lenso dash 15inch the ride is good
Tyre size for zen.help needed streetracer_919 Tyre & Alloy wheel Section 33 12th October 2010 12:13
my 15inch sub's enclosure issue! rider60 In-Car Entertainment 16 30th January 2008 09:12
For Sale 15inch Swift Alloys with 205/55/15 Tires kumar_ranjan Shifting gears 9 25th January 2008 17:32
max tyre/alloy size for my Ikon? plz help young_icon Tyre & Alloy wheel Section 25 9th October 2007 09:16
Most VFM 15inch LCD screen w 12 Gadgets, Computers & Software 18 15th February 2007 16:58
