| Tyre & Alloy wheel Section Everything to do with footwear for your car! |
| | Thread Tools |
| | #136 (permalink) | |
| BHPian | Quote:
Well coming to the point - looks like its better to stick to 195/60-14 michelin XM1+. Any other tires you recommend?
__________________ Cheers DJ ------------------------- Getz Prime CRDi VGT Chevy Spark LT | |
| | #138 (permalink) | |
| BHPian | Quote:
If i am going for PP2's then it should be 195/50-15 as 195/60-14 is available in PP1.
| | #139 (permalink) |
| BHPian | I am thinking of 205/50-15 Michelin XM1+. Is it available? EDIT: I am trying to view Michelin website but combo-boxes don't work in Safari. PS - I have made up my mind finally. I am booking GetzD tomorrow. ![]()
__________________ If everything seems under control, you are not going fast enough! Last edited by vabs78 : 3rd May 2008 at 00:20. |
| | #140 (permalink) |
| Distinguished - BHPian ![]() | Nope but that size is available in PP2's/BFG's/Yoko S-Drives. But, I think there is a possibility that 205's in that rim size might foul with the rear arches. KP, you got any info on this? Congratulations!
__________________ There is a very fine line between "Hobby" and "Mental Illness". Last edited by iraghava : 3rd May 2008 at 00:54. |
| | #141 (permalink) |
| BHPian | Thanks Raghav. BHPian vittalnrv is using 205/50-15 s on his petrol Getz, so I am hoping that this size will work. http://www.team-bhp.com/forum/798734-post208.html (Test drive : Hyundai GETZ CRDi diesel) If I stay with 14" wheels then I am thinking of not going for alloys and just upgrading tires. Saved money can be spent to get Pete's box ![]()
__________________ If everything seems under control, you are not going fast enough! |
| | #142 (permalink) | |
| Senior - BHPian | Quote:
AFAIK In getz 205/45-16 doesn't touch anywhere which makes me assume that 205/50-15 also shouldn't touch. Right?? Offset of the alloys will also have a key role when upsizing to 205. Negative offset alloy is a strict NO-NO.
__________________ Prajesh - << will be offline till August >> A true friend is someone who says nice things behind your back... | |
| | #143 (permalink) |
| BHPian | Alloy offset should be same or within 5mm of the stock offset right? I need to check the stock offset of Getz. I think Getz PCD is 100. Is there anything else that I need to consider while shopping for alloys?
| | #146 (permalink) |
| Distinguished - BHPian ![]() | I think the PP2 price is a bit too high, will confirm & post tomorrow. And regard the 6J thing, wider rims will increase the chances of you rims scraping the arches & also alter the ride/handling balance.
__________________ There is a very fine line between "Hobby" and "Mental Illness". |
| | #147 (permalink) |
| BHPian | Thanks Ishan. Really appreciate yours and kpzen's support. I don't wan't to go overbord with rim size. I will stick with 6J size. The tyre deal is working out to be quiet expensive. 6000-2400=3600/tyre= 14400 for 4 tyres + ~20K for 15" alloys = ~ 35K. I was thinking more like 25K-30K.
| | #148 (permalink) |
| Senior - BHPian | Vab78 205/50-15 PP2 should be around 5k per tyre. 6k is just too much.. Have u confirmed from vittalnv if 295/50-15 works fine in a Getz without any spacers?
| | #149 (permalink) | |
| BHPian | Quote:
![]() I guess you meant 205/50 ![]() vittalnv has confirmed(in some other post) that 205/50-15 does not touch anywhere and steering is pretty ok.
| Thread Tools | |
Similar Threads | ||||
| Need help for a tubeless tyre | tsk1979 | Tyre & Alloy wheel Section | 22 | 23rd May 2007 21:59 |
| Alloy wheels and tubeless for Palio 1.2 NV ELX | bangboy | Accessory/Parts Reviews | 13 | 22nd June 2006 01:10 |
| Alloy vs Tubeless vs Mag tyres | badboy | Tyre & Alloy wheel Section | 4 | 11th May 2006 14:12 |
| Tubeless tyre. | VMG | Technical Stuff | 2 | 2nd August 2005 13:26 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
