Tyre & Alloy wheel Section Everything to do with footwear for your car!
Thread Tools
Old 5th May 2008, 17:19   #151 (permalink)
My Getz has run about 58K KMs and the tyres are nearing their end (I am a sedate driver, anticipate braking and tyres on my cars usually last long. even these tyre are still good enough for another 5K KMs).
The stock tyres were tube type - 175/70. Now I want to go for tube-less ones. Please suggest which ones should I go for.
Nitin
ntomer is offline   Reply With Quote
Old 5th May 2008, 18:10   #152 (permalink)
djay99's Avatar
Originally Posted by ntomer View Post
Are you looking for upsizing the tires?
Looks like the stocks are 175/70-13.
If 175/70-13 then its Michelin XM1.
If upsizing to 175/65-14, then its Michelin XM1+.
Both the tires offer very good ride and handling. XM1+ is the best among two.
__________________
DJ
Getz Prime CRDi VGT
Chevy Spark LT
djay99 is offline   Reply With Quote
Old 5th May 2008, 19:08   #153 (permalink)
vabs78's Avatar
I sent a PM to vittalnrv about this and he says that there is no issue with even with max load.
djay99, are you going for 14" or 15" wheels?
__________________
If everything seems under control, you are not going fast enough!
vabs78 is offline   Reply With Quote
Old 5th May 2008, 19:50   #154 (permalink)
djay99's Avatar
Really confused vaibhav. Budget - not a problem.
15" will reduce ride but increase looks and handling.
14" Overall good ride and handling.
I am inclined towards 14"
Will check 15" S drives and if they last for 30K KM then will go with them. Heard good news about them.
What about you?
__________________
DJ
Getz Prime CRDi VGT
Chevy Spark LT
Old 5th May 2008, 19:56   #155 (permalink)
vabs78's Avatar
I am inclined towards 15".
But I have decided to take final call based on the alloy design that I like. If its in 14" then I will go for 14"s.
__________________
Old 5th May 2008, 21:29   #156 (permalink)
undead's Avatar
djay is going for 14"
vabs going for 15" .. Good . Lets see how it goes for you guys.
__________________
Getz CRDi VGT Bright Silver
undead is offline   Reply With Quote
Old 6th May 2008, 09:18   #157 (permalink)
Thanx DJay. No I am not looking for upsizing the tyres. I know very little about tyres, and don't know the pro/cons of upsizing.
How will it affect performance/ride/handling/fuel efficiency? What do you recommend?
Ishan, your inputs will be valuable here :-)
\N
Old 6th May 2008, 10:19   #158 (permalink)
kpzen's Avatar
ntomer
Get either Michelin XM1 or Yokohama A drive in 175/70-13 size.
__________________
Prajesh - << will be offline till August >>
A true friend is someone who says nice things behind your back...
Old 6th May 2008, 10:46   #159 (permalink)
ntomer
Thanx KP. Any idea how much Michelin XM1 costs? And where should I buy it from? I am based in Noida.
\N
Old 6th May 2008, 10:46   #160 (permalink)
Super-Admin
Since you are a sedate driver, don't mess the awesome Getz ride quality with a tyre upsize. Stick to the same size, and enjoy the ride quality / better FE.
__________________
Self-imposed limits are the only type that exist. Break them....then, make it a habit. Exceed.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 6th May 2008, 11:18   #161 (permalink)
kpzen's Avatar
\N
Michelin XM1 should be around 2800 per tyre.
Lajpat Nagar has a couple of good tyre dealers.
__________________
Old 6th May 2008, 12:56   #162 (permalink)
vabs78's Avatar
Guys, I am thinking of buying only 4 wheels and tires and keeping the stock wheel as spare wheel.
Is it a good idea?
__________________
Old 6th May 2008, 13:59   #163 (permalink)
djay99's Avatar
Is it a good idea?
Thats a very good idea and will save money if you are going for 195/60-14.
Buy 4 alloys and 5 tires. Mount 5th tire on steel wheel (5.5J)
__________________
DJ
Getz Prime CRDi VGT
Chevy Spark LT
Old 6th May 2008, 14:24   #164 (permalink)
vabs78's Avatar
I am thinking of only buying 4 tires and go for 15" alloys and tubeless. I think I can still use the stock wheel+tire for a short distance. The difference in outer diameter of 175/65-14 and 205/50-15 is only 3mm.
Thats how it was with my Camaro in US.
__________________
Old 6th May 2008, 15:01   #165 (permalink)
djay99's Avatar
For short distance - no problem.
Thats a good idea vaibhav. You will save close to 8K
Main bhi yahi soch raha hu
__________________
DJ
Getz Prime CRDi VGT
Chevy Spark LT
Thread Tools
Need help for a tubeless tyre tsk1979 Tyre & Alloy wheel Section 22 23rd May 2007 21:59
Alloy wheels and tubeless for Palio 1.2 NV ELX bangboy Accessory/Parts Reviews 13 22nd June 2006 01:10
Alloy vs Tubeless vs Mag tyres badboy Tyre & Alloy wheel Section 4 11th May 2006 14:12
Tubeless tyre. VMG Technical Stuff 2 2nd August 2005 13:26
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
