Tyre & Alloy wheel Section Everything to do with footwear for your car!
Thread Tools
Old 12th May 2008, 19:26   #181 (permalink)
vabs78's Avatar
Originally Posted by djay99 View Post
For how much the dealer is ready to take your stock tires?
What is the cost of buyback?
Oops... sorry missed that.
Michelin only dealer is offering 2400 /tire but then I will have to go for PP2s(expensive). Others are offering ~2K /tire.
__________________
If everything seems under control, you are not going fast enough!
vabs78 is offline   Reply With Quote
Old 12th May 2008, 19:31   #182 (permalink)
djay99's Avatar
2K is a very good deal. Here its between 1.5 to 1.6K
I think michelin dealer is trying to adjust the money. He is charging more for pp2 and showing you that he is giving best offer for stock tires.
__________________
DJ
Getz Prime CRDi VGT (TS 175KMPH)
Chevy Spark LT (TS 160KMPH)
djay99 is offline   Reply With Quote
Old 12th May 2008, 20:45   #183 (permalink)
vabs78's Avatar
Actually there is huge difference between 14" PP2s and 15" PP2s. 14" PP2 tires are available for ~4K and 15" for 5800.
15" Yoko S.Drives are available for 4.5K
Is PP2 really worth the premium??
__________________
Old 13th May 2008, 11:51   #184 (permalink)
djay99's Avatar
No. Go for the S-Drives
We have pothole filled roads in and around bangalore and i should not end up with a bent rim. Also the ride quality would be on lower side compared to stock ones. Thats my concern. If S-drives provide decent ride quality then i will buy them.
__________________
DJ
Old 15th May 2008, 16:12   #185 (permalink)
thebagchi's Avatar
Am novice about cars
My Getz has 155/80 R13.
I'm not looking for Alloys but am looking for R14 Steel wheel with proper upsizing.
Is it possible to put 175/65 R14 and remove 155/80 R13 without compromizing on ride quality and handling.
Please do guide me.
__________________
roadrollers-kolkata.blogspot.com
motorcycle adventure tourers
thebagchi is offline   Reply With Quote
Old 15th May 2008, 20:00   #186 (permalink)
djay99's Avatar
You can very well use 14" steel wheels and mount 175/65-14 on them as the OD difference is 0.83%.
Ride quality will be reduced because sidewall height is reduced by 10mm where as handling and braking will improve a lot.
If you dont want compromise on ride quality while improving handling and braking, you can go with 175/70-13.
__________________
DJ
Old 15th May 2008, 21:01   #187 (permalink)
kpzen's Avatar
I think 195/60-14 would be PP1 and the 15" would be PP2s...
__________________
Prajesh
If you think your teacher is tough, wait till you get a boss.
Old 15th May 2008, 21:15   #188 (permalink)
vabs78's Avatar
Yes KP. I came to know about it latter.
As per Ishan there is not much difference in performance of PP1 and PP2.
But I still want to go for 15".
P.S. - Expected delivery date of my GetzD is 26th.
__________________
Old 15th May 2008, 21:30   #189 (permalink)
kpzen's Avatar
Depending upon your budget, choose between Michelin PPs or S drives. U won't go wrong with any of the two.
Good Luck.
__________________
Prajesh
Old 16th May 2008, 01:00   #190 (permalink)
thebagchi's Avatar
today i went to one tyre shop he quoted me discount of 800 per tyre in exchange.
he showed me 175/70 R13 some Bridgestone tyres.
Is that good exchange rate that am being offered
__________________
Old 16th May 2008, 12:22   #191 (permalink)
vabs78's Avatar
I think I will go for PP2. I am a Michelin fan.
Good Luck.
Thanks!!!
I am waiting for that day like anything.
__________________
Old 16th May 2008, 15:44   #192 (permalink)
razor4077's Avatar
Good choice! I haven't driven on S Drives but I can say with conviction that PP2s are superb tyres!
razor4077 is offline   Reply With Quote
Old 19th May 2008, 11:22   #193 (permalink)
Default Aire pressure in tyres
Hyundai recommends 33 psi in front tyres and 30 psi in rear ones (for 2 people, for full load it is 33 psi). This recommendation is for stock 175/70 R13 tube-type tyres.
However I always kept all tyres inflated at 33 psi regardless of load, and it worked for me.
Now recently I changed the tyres to Michelin XM1+ 175/70 R13. Now should I keep the tyre pressure same as earlier or should it be any different for tubeless tyres?
\N
ntomer is offline   Reply With Quote
Old 19th May 2008, 11:27   #194 (permalink)
kpzen's Avatar
Maintain 33psi for all tires..In case u feel the ride is bumpy then u can lower it to 30 psi..
__________________
Prajesh
Old 19th May 2008, 11:46   #195 (permalink)
djay99's Avatar
Spoke to Sai Iyengars, CMH road and they are quoting
Michelin PP1 195/60-14 for 4200 per tire
Michelin XM1+ in 195/60-14 for 3950 per tire.
Are the prices ok?
P.S.- My car is in-transit and will reach bangalore on wednesday(21) and i am planning to get it on 26 or 27
__________________
DJ
Thread Tools
Need help for a tubeless tyre tsk1979 Tyre & Alloy wheel Section 22 23rd May 2007 21:59
Alloy wheels and tubeless for Palio 1.2 NV ELX bangboy Accessory/Parts Reviews 13 22nd June 2006 01:10
Alloy vs Tubeless vs Mag tyres badboy Tyre & Alloy wheel Section 4 11th May 2006 14:12
Tubeless tyre. VMG Technical Stuff 2 2nd August 2005 13:26
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
