| Tyre & Alloy wheel Section Everything to do with footwear for your car! |
| | Thread Tools |
| | #211 (permalink) | ||
| BHPian | Quote:
__________________ Cheers DJ ------------------------- Getz Prime CRDi VGT (TS 175KMPH) Chevy Spark LT (TS 160KMPH) | ||
| | #214 (permalink) |
| BHPian | I got car delivered on 30th may at around 8:30PM Upgraded tires to 195/60-14 Michelin Pilot preceda and bought 4 alloys of brand P&W(comes with 2 years warranty, website- P&W GROUP). Handling is just amazing. Its raining here in bangalore and i can do 80+ comfortably. KP, The tire dealer (super tyre tec) told me not to do alignment as its a new car. Is it really required?
__________________ Cheers DJ ------------------------- Getz Prime CRDi VGT (TS 175KMPH) Chevy Spark LT (TS 160KMPH) Last edited by djay99 : 2nd June 2008 at 12:23. |
| | #216 (permalink) | |
| Senior - BHPian | Congratulations Djay for the beast!!! Quote:
35 offset would be fine...
__________________ Prajesh ECLIPSEd | |
| | #217 (permalink) | |
| BHPian | Quote:
I think it will be fine as its just 3mm off the stock offset. I was more concerned for the clearance between inside tire wall and suspension components (lesser offset means nearer to suspension), but it took the 205 tires easily.
__________________ If everything seems under control, you are not going fast enough! | |
| | #218 (permalink) | |
| BHPian | Thanks kp Quote:
I was doing 80KMPH on airport road which is flat and a speedbreaker appeared and i had to brake suddenly as there was another car infront of me. Car started wobbling and tires behaved as if nuts are loose and front left tire srarted pulling towards left and even steering was moving left and right. My heart almost came in my mouth as i thought nuts are loose and wheels would get off. Nothing happened and finally car came to halt and i checked nuts and all were tight. I spoke to super tyre tec guy and he said he has no clue about the problem and asked me to repeat the same case. I dont want to do that ![]() Any idea what is the problem?
| | #219 (permalink) | |
| BHPian | Quote:
| | #220 (permalink) |
| Senior - BHPian | Without checking it out in person can't be sure about the problem but i'm guessing that the solution to your problem is here (Solution for vibrations after installing alloy wheels)
| | #221 (permalink) |
| BHPian Join Date: Jun 2008 Location: Madras
| I am thinking of 185/65/R14 (MICHELIN Energy XM1+) for the Getz D. While I didnt see anyone suggesting this (or did I miss it?!), this size happens to be 2.23% bigger than the stock. The speedo error (as per Tire size calculator) is 2.2% slower than the stock 175/65/R14. I was thinking that usually the speedo reading with stock rubber would be faster than actuals, so this may actually be a correcting factor - is it a bad idea to go for this upsize? |
| | #223 (permalink) |
| BANNED Join Date: Nov 2005 Location: ??
| Actually lower offset by 3 mm means the center-plane of the wheel will move away from the suspension components by 3 mm. However, now you have wider wheels. Let us say your wheels are one inch wider than that of stock. Then your clearance from suspension components has reduced from that of the stock wheel by (1/2 inch - 3 mm), i.e., by about 9.7 mm. Plus if you take the extra width of your tyres into account, your clearance from suspension components may have reduced further as compared to stock. You need a minimum clearance of 4 mm from suspension components to take into account extra tyre flex on bad roads or under load. |
| | #224 (permalink) | |
| BHPian Join Date: Dec 2006 Location: Delhi
| Quote:
Elito
__________________ ~ Maybe we have no needs, only wants.. ~ | |
| | #225 (permalink) |
| BHPian | 185/65-14 is not a correct upsize for Getz. Get 195/60-14 Michelin XM1+. Good handling and great ride quality. Also it will last 40K KM for sure.
| Thread Tools | |
Similar Threads | ||||
| Tubeless Tyres For Getz CRDI | BalajiShankar | Tyre & Alloy wheel Section | 15 | 7th October 2008 12:41 |
| Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! | aks_karthik | Hatchbacks | 70 | 13th July 2008 01:15 |
| Alloy wheels and tubeless for Palio 1.2 NV ELX | bangboy | Accessory/Parts Reviews | 13 | 22nd June 2006 01:10 |
| Alloy vs Tubeless vs Mag tyres | badboy | Tyre & Alloy wheel Section | 4 | 11th May 2006 14:12 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458
