| Tyre & Alloy wheel Section Everything to do with footwear for your car! |
| | Thread Tools |
| | #226 (permalink) | |
| BHPian Join Date: Jun 2008 Location: Madras
| Quote:
Thanks Elito. I think I would be deciding between that and a 15" upsize. | |
| | #227 (permalink) |
| BHPian | any idea about the rates of tyres Michenlin XM1+ 195/14/60 and 185/14/65 or 60 Bridgestone Potenza GIII 185/14/65 or 60 Good Year EAGLE F1 GSD2 185/14/60 and 195/14/60 (i love the design but heard it's not good and afraid will fit in 5J rims) No plans for alloys that is big issue for me. Tyre selection is restricted to 5J rims.
__________________ Cheers :) K Last edited by aks_karthik : 2nd July 2008 at 18:04. |
| | #229 (permalink) | |
| BHPian | Quote:
KP, I have mounted 195/60-14 Michelin PP1 on spare steel wheel which is 5J (as told by you). Is it ok or shall i change it back to 175/65-14 stock tire?
__________________ Cheers DJ ------------------------- Getz Prime CRDi VGT (TS 175KMPH) Chevy Spark LT (TS 160KMPH) | |
| | #230 (permalink) | |
| Senior - BHPian | Quote:
My cousin is running with 195s on stock rims...No problems till now..
__________________ Prajesh ECLIPSEd | |
| | #231 (permalink) |
| Senior - BHPian | @aks - don't even go near the Goodyear Eagle F1s. They are one of the worst tyres that we have ever bought. If you like the design, there are many more tyres available in the market with a similar design.
__________________ ¢нєєяѕ ℓαмвσ lamborghinirules@gmail.com |
| | #232 (permalink) |
| Newbie Join Date: Mar 2008 Location: Mumbai
| Hi I have a Getz GLX 1.3 petrol. I want to upgrade from the factory fitted 175/70 R13 alloys & tyres to a 195/50 R15 set of 5. Is this the ideal ratio? What the best company makes I should go for ? My budget is up to 20 thousand. Will there be any hit in performance. I am told putting 17 inch alloys severely affects pickup/performance. Is this the same for 15 inch alloys as well? I'm not so concerned about the extra fuel it might burn but just curious as to how much it will affect. Since I am going for a set of 5, I am a little worried about the spare 15 inch alloy and tyre not fitting in the space allotted to it in the boot. Has any one with the specifications I mentioned above had that problem in the getz? How do I test after the fittings that the wheels have put aligned/balanced properly and that there is no extra load or wearing out on a particualr tyre. Is there anything else I need to watch out for? Thanks. |
| | #233 (permalink) |
| BHPian Join Date: Jul 2008 Location: jalandhar
| well ideally +1 scheme is applied in case of an upgrade. but as u want to go from 175/70/13-195/50/15, the mathematics you have applied is right, but this will have marked affect on ride, it will deteriorate, handling would improve, braking will also improve, fuel consumption will inc.& suspension will get worn out sooner. performance tyres from bridgestone- g3 potenza, michelin -pilot preceda & yokohoma- advan sport are good . each tyre costs around 4000-5000/rs. 17" would mean frequent visits to garage. |
| | #235 (permalink) |
| Distinguished - BHPian ![]() | Daemon - 195/50 R15 is indeed the correct size for your car so you can go ahead with it. but you will not be able to buy both the tyres & the wheels in that budget. You would need to up your budget to around 35k-40k at least to but that tyre size & wheels. There are lots of options available in that size including Michelin PP2, Yokohama S-Drives etc.
__________________ There is a very fine line between "Hobby" and "Mental Illness". |
| | #236 (permalink) |
| BHPian Join Date: Mar 2007 Location: New Delhi
| Hi Guys, Moderators, I have almost read all the threads on tires for Getz and specifically these two tires and still the following doubts remains. Please allow me to open this thread. Thanks. Just about to get the delivery of my getz crdi. Will straight away go for the tire change. Please suggest on the following. Size for PPs - 195/60-14 (PP2 not available in that size) Size for S.drives - 205/50-15 (not available in 60 profile so 14" is out) Not considering PP2s in 205/50-15 as they are atleast 1.2-1.3K expensive then S.drives I had previously used ES100 and was not entirely satisfied. Too soft and very noisy, although grip was fantastic. My Requirements --- 1. Need a sports tire (to tame the 24kgm torque) 2. Decently comfortable 3. Decent life (40K kms) 4. Low road noise (Fed up with noise of ES100) 5. Lots of highway traveling - Hard sidewall (ES100 were too soft and I had sidewalls cut in 2 tires) So out of S.drives and PP1 in the respective sizes. 1. Which is grippier (both in dry and wet) 2. Which will last long ? 3. Which is more comfortable ? 4. Which has less road noise ? 5. Which has tougher sidewalls ? (Very important criteria as cut sidewalls cost dearly to replace with a new tire) Also, is there a size in S.drive in 14" for Getz. Waiting for replys. Naman |
| | #237 (permalink) | |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
| Quote:
Please continue the discussion in this thread,so that the relevant information stays in one place for future reference. Thanks, Jaggu
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin | |
| | #239 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
2. Equal 3. S-Drives 4. Equal 5. Equal Remember, both tyres will be noisy on rough/cemented roads. No.
__________________ There is a very fine line between "Hobby" and "Mental Illness". | |
| | #240 (permalink) | |
| Quote:
I'll go for the alloys as well. And that's what I've no clue about. Since S-drives are not available in 14", I guess its better to check PPs in 195/60-14. How do you think the deal for PP is @ Rs 3600 apiece and exchange price of Rs 2000/- per tire for stock tires Same dealer quoted Rs 11K for a set of 4 alloys of Stallion (14"x6" in HS). Have you guys heard about the brand. | |
| Thread Tools | |
Similar Threads | ||||
| Tubeless Tyres For Getz CRDI | BalajiShankar | Tyre & Alloy wheel Section | 14 | 19th July 2008 10:09 |
| Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! | aks_karthik | Hatchbacks | 70 | 13th July 2008 01:15 |
| Alloy wheels and tubeless for Palio 1.2 NV ELX | bangboy | Accessory/Parts Reviews | 13 | 22nd June 2006 01:10 |
| Alloy vs Tubeless vs Mag tyres | badboy | Tyre & Alloy wheel Section | 4 | 11th May 2006 14:12 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457
