Tyre & Alloy wheel Section Everything to do with footwear for your car!
Thread Tools
Old 25th October 2007, 22:56   #16 (permalink)
kpzen's Avatar
Originally Posted by PatienceWins View Post
I have Getz Prime 1.3 GLX with the same tyre profile. The rim size of mu stock alloys is 5.5 J. I intend to upsize my tire from 175/60-14 and this thread is useful for me as well.
What I had in mind for upsize was 185/60-14. The steering is pretty hard in slow speed and I do not want to make it worse. Should I go for 195/60-14 tyre?
Akshay, what was your experience after upsize?
Your Prime has 175/60-14 or 175/65-14..?
__________________
Prajesh - << will be offline till August >>
A true friend is someone who says nice things behind your back...
Old 25th October 2007, 23:05   #17 (permalink)
ramie2400's Avatar
hi kp I think its 175/60/r14 on alloy rims the last i had seen when i took the TD
__________________
Honda ( I V I ( 1.8 M/T V
Getz Prime 1.3GLS (ICED)
Graduated from
"University of Error's"
Old 25th October 2007, 23:55   #18 (permalink)
kpzen's Avatar
Thats a pretty odd size.
Can anyone confirm this?
__________________
Old 26th October 2007, 09:08   #19 (permalink)
hemanthisgreat's Avatar
Originally Posted by Anju View Post
I thought of not changing the size(175/65 R14) because I felt anything else would penalise the ride quality that Getz offers.
Anju
if you stick to 14 inch your ride quality will not be compromised. do change the tyre.for the power getz crdi offers you could use better road handling and grip. go for the 195/60/r14 michelin XM1. do not worry about the rim size etc. the alloy wheel shops do this everyday and will give you the right width. so what colors are on offer for the getz crdi and which one did u opt for.
__________________
It's not about how you act, how cool you are, or what you're wearing. It's all about how LOUD your car is.
hemanthisgreat is offline   Reply With Quote
Old 26th October 2007, 09:31   #20 (permalink)
akshay1234's Avatar
I have bought a Getz 1.3L GLS i am planning to upgrade to 15'inchers Lenso NX series with 195/50/R15.is that the correct upsize and will the ride be affected alot with this wheel size or grind to the wheel arc???? can i go till 16inchers???
mods,I am sorry if i jacked the thread.
cheers Ramie
195/50 r15 is the perfect upsize. it has less than 1% error. it definitely wont scrape. the ride will become a little stiffer than normal. dont go to 16" since the getz anyway ahs a suspension on the stiffer side and it will kill the ride.
patience wins - i havent upsized my tyres. will do so soon.
akshay1234 is offline   Reply With Quote
Old 26th October 2007, 09:58   #21 (permalink)
JayD's Avatar
Infractions: 0/1 (4)
i feel the getz needs wider tires than the stock ones offered, try putting on 195s. Yoko es100 would be my choice. I'm using the michelin xm1 and while it is a great tire, i feel it wears out too fast. As for the alloys, don't buy them from the dealer but from the aftermarket tire shops. U could go in for hr, league or lenso. Also while choosing the tire size, go through the tire size calculator so that u can get a proper size which does not change the speedo readings.
__________________
A lil more work and she'll fly like a streamlined butterfly! :)
Old 26th October 2007, 10:32   #22 (permalink)
Default Getz stock tyres
Getz GLS stock tyre: 175/70 R13 (no alloys)
Getz GLX stock tyre: 175/65 R14 (alloys)
Getz CRDI stock tyre: 175/65 R14 (no alloys)
sups is offline   Reply With Quote
Old 26th October 2007, 11:09   #23 (permalink)
ramie2400's Avatar
Akshay i had gone to see the Lenso NX series and they are just mind blowing,ok i will stick to the 15inchers i would go for the Yokohama ES100 with 195/50/R15.
can any one explain the tyre size 195/50/R15 the 50 stands for,is it related to the width of the tyre??
Ramie
__________________
Graduated from
Old 26th October 2007, 11:36   #24 (permalink)
kpzen's Avatar
50 means that your tyre sidewall has 97.5mm of rubber(50% of 195).
More the sidewall better would be the ride quality and vice versa.
__________________
Old 26th October 2007, 12:04   #25 (permalink)
ramie2400's Avatar
thanks kpzen for the information will the 50 profile be comfortable to drive on our roads and some time out station drives??
__________________
Graduated from
Old 26th October 2007, 12:52   #26 (permalink)
akshay1234's Avatar
ramie - 50 profile will be fine as long as you slow down a bit for the rough patches and potholes. and look at s-drives instead of es100s. they are newer.
Old 26th October 2007, 13:01   #27 (permalink)
kpzen's Avatar
More the comfort its the damage caused while running the car with such low profile tyres.
If u are driving on some unfamiliar highway and doing 100kmph + speed and suddenly u see a pothole which u cant avoid and the result is a bent rim or tyre bulge or even a bent suspension arm damage in some cases.
I've had such experience in my zen which is running on 165/65-13 rubber which has 107mm sidewall rubber so imagine with 97mm sidewall rubber in 195/50..Comfort part will be taken care off by the suspension which is way better than what zen has....
__________________
Old 26th October 2007, 13:16   #28 (permalink)
ramie2400's Avatar
165/65-13 i think i was also using the same on my 1997 zen with HR alloys wheel,for sure the ride was bumpy and i had installed spacer rings at the rear suspension,moreover the pain was no power steering and stiff steering wheel:( got fed up with this and then finally one sold it,but i did good outstations on that car without even a punture till date i sold.I was using goodyear.
__________________
Graduated from
Old 26th October 2007, 13:55   #29 (permalink)
I own a Getz 1.3
The correct Stocksizes are as follows:
Getz GLE and GVS: 155/80 R13
Getz GLS: 175/70 R13
Getz GLX: 175/65 R14 (with Alloys)
Getz CRDi: 175/65 R14
A short history:
The Getz originally came with only two stock configs
175/65 R14 (with alloys) for GLX and the 175/70 R13 for the rest (GL and GLS)
Then the Swift happened and Hyundai changed the trim/model nomenclature to GLE, GVS, GLS and GLX instead of GL, GLS and GLX when first introduced.
Under the new models GLE and GVS came with 155/80 R13 and GLS and GLX remain unchanged.
Then came Getz Prime - The stock tyre config was retained for all the four models HOWEVER the GLE and GVS now came with 1.1 engine. SO we can say that the 1.3 was discontinued for GLE and GVS. However some GVS can be seen with 175/70 R13 as on requests some dealers gave the 175/70 tyres with GVS (offcourse for some cash)
Coming to the question. Going by the above logic the correct upsize for the Getz CRDi should be 185/60 R14 or 185/55 R15. With the second one being more accurate.
__________________
~ You boys going to get somewhere, or just going? ~
Elito11 is offline   Reply With Quote
Old 26th October 2007, 15:03   #30 (permalink)
EDIT: However if we take GLS as base (i.e. 175/70 R13) the 195/50 R15 is the PERFECT upsize!
__________________
Thread Tools
Need help for a tubeless tyre tsk1979 Tyre & Alloy wheel Section 22 23rd May 2007 21:59
Alloy wheels and tubeless for Palio 1.2 NV ELX bangboy Accessory/Parts Reviews 13 22nd June 2006 01:10
Alloy vs Tubeless vs Mag tyres badboy Tyre & Alloy wheel Section 4 11th May 2006 14:12
Tubeless tyre. VMG Technical Stuff 2 2nd August 2005 13:26
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
