Tyre & Alloy wheel Section Everything to do with footwear for your car!
Thread Tools
Old 26th October 2007, 15:12   #31 (permalink)
ramie2400's Avatar
Originally Posted by akshay1234 View Post
ramie - 50 profile will be fine as long as you slow down a bit for the rough patches and potholes. and look at s-drives instead of es100s. they are newer.
Lolz.. I am a average driver dont speed up too much on our roads,i will suerly check out the S-Drives before going for the upgrade.Thanx for the advice akshay..cheers
Ramie
__________________
Honda ( I V I ( 1.8 M/T V
Getz Prime 1.3GLS (ICED)
Graduated from
"University of Error's"
ramie2400 is online now   Reply With Quote
Old 26th October 2007, 15:36   #32 (permalink)
Ajaybiz's Avatar
Anju visit Sai Iyengar near Lal bag just opposit to Garuda Motors and choose the size of tyre whatever you want(use tyre calculator for upsize or stick to stock) 185 70 R14 Michelin is about 3.2K, next to his shop one guy keeps all accesories, 14" alloys youll get for 15.5K for 5 pieces.
Ajaybiz is online now   Reply With Quote
Old 26th October 2007, 16:55   #33 (permalink)
PatienceWins's Avatar
Your Prime has 175/60-14 or 175/65-14..?
Sorry for the typo error..Its 175/65-14..
PatienceWins is online now   Reply With Quote
Old 26th October 2007, 19:00   #34 (permalink)
Anju's Avatar
I found that Getz has R14 5J steel rim.(As you know Tyre 175/65 R14).
So now, after many excellent inputs from all you folks choice is between
1. 195/60 R14 which requires R14 6J for optimum width.
(with lot of study, I feel that wheel center load line might shift considerably which would hurt wheel bearings and CV joints as load increases(farther the load center distance more reaction load on bearings/joints).
2.185/60 R14 which would require R14 5.5J for optimum width.
(which still shifts the wheel center line but relatively less.)
So please please suggest which is the best option out of two
I am going for Michelin Energy XM1 as suggested by most of you.
I kindly request you to suggest the good dealers in Bangalore who would have Neo/Aura/HR brand of alloys and tyres. I'll visit them next weekend.
I am buying Passion Red. Yes Getz CRDi might rock(Patienewins).
I can comment accuratly on car only after some 3-6 months of drive.
Test drive for 15-20 min can fool us sometimes..
I decided on this because, I did drive 110 BHP Getz(and Honda Jazz/AudiA4)when I visited Turkey for a week last year,but it had all the features(ABS/Alloy/Airbags etc). I also drove Fabia/Renault Clio Sport in Romania during the same trip.
Thank you all
PS: I also request ICE setup but in concerned forum.
Anju is offline   Reply With Quote
Old 26th October 2007, 23:00   #35 (permalink)
Hi Anju
Among the two that you have finalised the better option is 185/60 R14.
However do note that is still not the perfect upsize! In ascending order of speedo error:
Best 1: 195/50 R15
Best 2: 185/55 R15
Best 3: 185/60 R14
If you can i would still suggest 185/55 R15. It would be the perfect compromise between comfort (55) and looks (R15)
yes Michelin XM1 is a gr8 choice..especially if ur looking for comfort! I have the same in my Getz (175/70).
Lastly for Alloys i would suggest Hi-Join, Plati, League and Lenso (above R15 only). Also if choosing a really unique design, try and go for 5 instead for 4, else 4 should do.
Stay away from Aura. Its all style no purpose. They weigh almost like steel wheels!!!
All the best!
Elito
__________________
~ You boys going to get somewhere, or just going? ~
Elito11 is offline   Reply With Quote
Old 27th October 2007, 10:32   #36 (permalink)
Thats a pretty odd size.
Can anyone confirm this?
Hi KP
Both these got it wrong. You are right. the Getz GLX has 175/65 R14.
Elito
__________________
Old 27th October 2007, 11:09   #37 (permalink)
hemanthisgreat's Avatar
i strongly suggest not to go for aura. stick to brands such as HR , lenso, league, plati. for dealers go to car trendz on mission road for a good deal. i too did the same research while buying my alloys and found him to be very reasonable. this shop is just at the ending of the flyover which comes from double road. his number is 9845130613. work out a deal along with tyres.
__________________
It's not about how you act, how cool you are, or what you're wearing. It's all about how LOUD your car is.
hemanthisgreat is offline   Reply With Quote
Old 27th October 2007, 18:07   #38 (permalink)
rks
rks's Avatar
If the offset of your alloy wheels is the same as that of the stock wheels, then the alloy wheel centerline will be at exactly the same location as that of the stock wheel and you need not worry about the load on your wheel bearings, suspension/steering components. So you need to find out the offset of the stock wheel (usually between +35 mm and +45 mm for a front wheel drive car). As I said, the offset of the alloy wheels can be up to 10 mm less than that of the stock wheel and you will still be OK. Most (but not all) of the alloy wheels will have the offset in the required range.
In my case I have alloy wheels with +26 mm offset, whereas the offset of the stock wheel was +46 mm. So my alloys jut out a little from the wheel well and I had to remove the front mud flaps to avoid fouling while turning the car. My wheel bearings are fine after more than 15000 kms with alloys. Not sure about the effects on suspension/steering components, as I just overhauled them at 58000 kms. Have to wait and see.
Old 27th October 2007, 18:29   #39 (permalink)
iraghava's Avatar
Given the specs of the Getz CRDi, I would choose 195/60 R14 on 6J rims over all the other choices. I'm running the same size in my OHC & it is a fantastic compromise netween excellent grip & braking & comfort esp. keeping in mind our road conditions.
Another positive point of going with 195/60 R14 is that you have wide plethora of tyre choices available in that size. If you want comfortable tyres you can choose between the Michelin Energy XM1's, Yokohama A300's & Bridgestone Turanza's. If you want a performance tyre you can choose between the Michelin Pilot Preceda's & the Yokohama ES100's. So basically in this size you can get whatever kind of characteristic you would like in your set of tyres.
Best 1: 195/50 R15
Best 2: 185/55 R15
Best 3: 185/60 R14
Elito - You're right about the correct order of speedo error's on the listed sizes. Let me list them out in detail for everyone again:
195/50 R15 - -1.2%
185/55 R15 - 0.2%
185/60 R14 - -0.9%
195/60 R14 - 1.1%
But there are a couple of things related to your suggestion which are a problem:
1. 185/55 R15 is not officially available in India in either Michelin, Yokohama or Bridgestone. So finding them is one issue.
2. Secondly, looking at it practically how much difference does a speedo error difference of 0.5% or so make? Is it something that we should really be bothered about that much? Does it any way change the practical use of our vehicle to the extent that it is not recommendable (while keeping in mind that it does stay within the limits of OD difference of +2 to -3%).
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Old 30th October 2007, 18:34   #40 (permalink)
Yup I had my doubts about the avalaibility. So now its confirmed.
Yeah i agree. 195/60 R14 is indeed a good upsize for a lot of cars.
__________________
Old 30th November 2007, 09:29   #41 (permalink)
Anju's Avatar
Guys,
Finally going for Michelin 185/60 R14. The tyre guys are not at all recommending for 195/60 R14.
Also probably going for "Aura" alloys(though I am not liking the design) as they have R14 X 5.5" which is optimum width for that tyre size.
League doesn't have 5.5" they have R14 X 6". And HR, availability is the issue.
Update you after Monday more about this. This weekend is the judgement day for me for both tyre and Alloy and ICE set up as I am getting my GEtz CRDI in Weeeek !!!!!!
Anju
Old 30th November 2007, 09:50   #42 (permalink)
@anju
i am myself am using league alloys with 185/60/14 on league alloys, no problems what so ever. its already run 14k.
do not go for aura, not good looking at all. the crdi deserves nice alloys. take a look at my gallery for the league alloys. think it over about the alloys.
__________________
Old 30th November 2007, 09:59   #43 (permalink)
iraghava's Avatar
6J will work perfectly fine with 185 or 195. You can go in for that also.
__________________
Old 1st December 2007, 05:20   #44 (permalink)
I have Getz Prime GLX. My alloys are OEM, 5.5 J with 175/ 65 R14. Will 195/60 R14 be fine with the current alloys?
What would be the effect on ride and ground celarance?
What I had in mind for upsize was 185/ 60 R14.
Old 1st December 2007, 12:02   #45 (permalink)
kpzen's Avatar
Yes u can go for 195 with 5.5j alloys..Elantra comes with 195 tyres and 5.5j alloys.
There won't be much difference in ride quality with those upsize as the sidewall almost remains the same.
I have answered your GC query in some other thread.
__________________
Prajesh - << will be offline till August >>
A true friend is someone who says nice things behind your back...
Thread Tools
Need help for a tubeless tyre tsk1979 Tyre & Alloy wheel Section 22 23rd May 2007 21:59
Alloy wheels and tubeless for Palio 1.2 NV ELX bangboy Accessory/Parts Reviews 13 22nd June 2006 01:10
Alloy vs Tubeless vs Mag tyres badboy Tyre & Alloy wheel Section 4 11th May 2006 14:12
Tubeless tyre. VMG Technical Stuff 2 2nd August 2005 13:26
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
