Old 13th November 2007, 00:59   #61
speedy's Avatar
Thanked: 929 Times
Originally Posted by iraghava View Post
Is that the stock size??
this is the size on the car right now. my 240d aslo has the same size tyres.
In 17" the only options are (keeping in mind stiock size as 175/80 R14):
195/55 R17
205/50 R17
But I don't think you'll find either size.
i might be wrong at this but i have always been told if you put in 195 with the alloys they are like 205's on the car, increase/stretch an inch or something.so if i go for 205 they would be like 215's on the car and touch inside. i dont know how true this is.
how are bridgestone tyres for the car. i have had a bad experience with michellin so dont intend to go for them.
speedy is offline   Reply With Quote
Old 13th November 2007, 01:13   #62
kpzen's Avatar
Thanked: 1,655 Times
Originally Posted by speedy View Post
yes that is what i said 60/65 profiles are ok with me. will i be able to get 60 profiles with 17" alloys. atleast a remote possibility?
U can't have 60 profile 17" tyres bcos the correct 17" upsize is 205/50-17.
Find out the tyre of the merc(in pic) with 17" alloys.
why would a tyre manufacturer sell a 205 tyre as 195.
Old 13th November 2007, 01:18   #63
iraghava's Avatar
Thanked: 156 Times
Well the stretching part depends on your rims mainly, if you fit wider rims then they will stretch otherwise not. Do post complete details of the rims you're getting especially the width, so we can advise you accordingly.
It can also be a scenario that 195/205 are too thin to be mounted on that rim due to the rims width.
Old 13th November 2007, 01:38   #64
speedy's Avatar
Thanked: 929 Times
the tyre size i mentioned with the picture Kp. it is 205/50/R17.
the wheel that i want are the ones on Presidents E220 and the picture that Gordon has posted. i dont know the details of it as i have also seen pictures of it only. will do so when i see it at the shop dayafter.
i dont understand the highlighted part exactly . does it mean that if the rim is wider and you have to stretch the tyre to fit it on. this is bad for the tyre right. i hope i am understanding it properly.
Old 13th November 2007, 01:58   #65
iraghava's Avatar
Thanked: 156 Times
Can you ask Ronnie what tyre size he had on those wheels?
Well like every car has a maximum width tyre you can fit, similarly every wheel size has a recommended tyre size band that you can fit on it without any problems & expect it to perform to its optimal limits. For eg. if you mount a 215 sized tyre on a 5J rim, while it will work but the sidewall will be under tremendous strain as it will be flexing a lot as the beads of the tyre will be sitting too narrow (due to the narrow wheel) compared to the contact patch. This will lead to uneven tyre response when loading the tyre sidewalls & increases the chances of failure too as it puts unnecessary loads on the tyres.
Hence for every tyre size there is a recommended Wheel width which should be followed. For eg. 195 works best on 6J while 205 works best on 6.5J.
Old 13th November 2007, 02:06   #66
speedy's Avatar
Thanked: 929 Times
hey guys found the same rims posted by Rehaan and they are fitted on the W123. so i guess they would alright on the 230c.
will keep this in mind when i go to see the rims and tyres. thank you for the information ishan.
Old 13th November 2007, 12:34   #67
kpzen's Avatar
I need to know the tyre brand not size.
Now this looks like 205 or 215 Dunlop Sp9000 tyre to me.
Old 13th November 2007, 18:44   #68
speedy's Avatar
Thanked: 929 Times
i dont know what brand it is, was just told the size when the picture was sent to me. i shall see it when i go to bombay this time.
i do not have a clue about it. what are the good brands that i should go for Kp. so now if you say these are 205 or 215 on the w123, then i can fit in a 205 in the 230c. now it all depends on the rim size, hope they are 16".
Old 13th November 2007, 20:31   #69
kpzen's Avatar
Michelin and Yokohama are the best brands available at the moment.
Correct Upsizes assuming the rims to be 16" would be 205/55-16 and if its 17" then 205/50-17..
please confirm about the rim size first.
Old 18th August 2008, 20:28   #70
Akshay1234's Avatar
Thanked: 7,239 Times
oy speedy. what happened to the rims on this?
Old 18th August 2008, 22:20   #71
danlalan's Avatar
Thanked: 135 Times
These are my set of tires and rims we got for this car.
205/60/r 16 Michelins from benz themselves. A good simple design for the rims from AMG.
danlalan is offline   Reply With Quote
Old 31st August 2008, 14:23   #72
faithless_1984's Avatar
Thanked: 217 Times
E class with nice rims.....
faithless_1984 is offline   Reply With Quote
Old 4th September 2008, 11:00   #73
speedy's Avatar
Thanked: 929 Times
Still not found the right one akshay. i was traveling so things got delayed with the car.
nice rims Dan. Where did you get them from and how much do they cost?
@ Faithless. nice rims but they look bigger. i also feel the wheels would over shadow the W123's simple looks.
Radurra "Clear Wheels" - See Through Wheels!!! Rehaan Tyre & Alloy wheel Section 34 17th September 2011 13:27
Does anyone here watch "Overhaulin" on "Travel N Living"? Shan2nu Shifting gears 39 18th January 2011 23:17
What makes some cars the "winners" and others the "losers" ? mithun The Indian Car Scene 1 13th June 2007 06:55
Audi RS5 "M3 beater?" to be launched early next year "PICS" highwayblaze The International Automotive Scene 9 18th May 2007 01:59
