Old 2nd November 2007, 17:49   #1
Default Best Tyres under 3.5k for Esteem
Hello Friends,
I have a 2000 model Esteem. Its now time to change the tyres.
Till date its on its stock 155/80/R13 tyres on its stock steel rims. I dont have the budget to go with alloy wheels. But I would want to go for a real good tyre set. I have allocated 3.5k max for a tyre. I am pretty newbie at Tyre models.
I have already done some homework by going through the threads on this forum which has been very very informative. I now know the advantages and disadvantages of low-profile tyres and also the tubed Vs tube-less comparison et al.
I am based at Bangalore. The other day I went to a good Tyre Store and he showed me Michelin 185/70/R13...It looked pretty decent and this guy quoted 3.4k for them. I can buy them but now before I get a thumbs-up from you punters.
My preference goes in this order:
1. Comfort
2. Grip (lowest Braking distance)
3. Handling (I dont drive all that fast, but sometimes I do)
Please suggest the best set of tyres for my purpose considering it would be on the stock rims.
BTW, the store guy told me that I can also use my existing tubes inside my Tubeless tyres....are there any advantages of this ??????
Pani is offline   Reply With Quote
Old 2nd November 2007, 18:43   #2
I am also concerned about Mileage drop. What kind of mileage drop should I be expecting with an upsize from 155/80/13 to 185/70/13 ??
Old 2nd November 2007, 21:07   #3
rr_zen's Avatar
Thanked: 268 Times
175/70/R13 should be the ideal size for the Esteem considering the fact that you are using the stock rims. Michelin is certainly good and rated high amongst T-BHPians. You can try Yokohama as well.
Why would you want to have tubes inside a tubeless tyre ?
rr_zen is offline   Reply With Quote
Old 2nd November 2007, 21:22   #4
lamborghini's Avatar
Thanked: 1,664 Times
Hey,
firstly tubes in a tubeless tyre is a big NO NO safety wise.
Avoid it as much as possible. You can do a search and understand why.
Which Michelin did the tyre guy show you?
On the stock rims, 175/70R13 is the perfect match.
You should look at Yokohama S and C drives, as well as the Michelin Energy XM1/XMV8.
There should be a small, insignificant mileage drop but a noticeable increase in comfort and handling and braking.
lamborghini is offline   Reply With Quote
Old 2nd November 2007, 21:23   #5
iraghava's Avatar
Thanked: 156 Times
Pani - I would recommend 175/70 R13's for your car. 185's would be too wide. Also the mileage drop from 155 to 175 should be around 1kmpl.
And both Michelin's or Yokohama's would be good for your car. 175/70 R13 in Michelin should cost you around 2700 or so per tyre. Yokohama will be slightly cheaper.
Lambo neither S-Drives nor C-Drives are available in India in this size.
Old 2nd November 2007, 21:24   #6
recently i bought Yokohama ES-100 2900rs a piece, 185/60/14 fitted with Optra rims for my Esteem, I did not want to spend on alloys, You need to increase the centre dia of the optra wheel. Also optra wheels are scarce, when you buy make sure the valves are in good shape, otherwise each valve might cost around 500rs, then make sure you take the wheels to a lathe guy who does the job well. no need to have tubes on the tubeless unless the steel rims are old / rusted or the valves are bad.
for me Overall it's a satisfying effort!!
Remember that ES-100 is a soft tyre and it's uni-directional.
bruce is offline   Reply With Quote
Old 2nd November 2007, 21:24   #7
kjdesigns_2000's Avatar
175 would be the best suited tyre on the stock rims. Bridgestones and Michelins would be the best brand to go for. Low noise, good comfort and braking and looks good. Have'nt tried a Yokohama ever so i can't comment on that.
Also i am sure there would be a little milage drop and a bit heavy steering because of the upsize. Although keep in mind that VXI comes with 175 company fitted, so it should be good for esteem.
kjdesigns_2000 is offline   Reply With Quote
Old 2nd November 2007, 22:41   #8
kpzen's Avatar
Thanked: 1,655 Times
Get 175/70-13 Michelin XM1 or Yokohama A300.. Its the best upsize possible in an esteem.
Both tyres would be well within your budget.. Prices have been mentioned by Ishan.
Old 3rd November 2007, 10:05   #9
Rightly suggested by KP, 175/70 R13 is best option.
In 2000 Esteem sometimes there can be fouling in case of 185/70 R13.
itzzme is offline   Reply With Quote
Old 3rd November 2007, 10:25   #10
kpzen's Avatar
Yes, the 185/70-13 tyres would scrape with the mud flaps.
I think fellow tbhpian turbo_c had them on his esteem but without mud flaps.
Old 6th November 2007, 14:35   #11
Default Thanks a Lot
Guys....thanks a lot for all your suggestions....I went 175/70/13 as almost all of you concurred on that choice....I got Michelin XM1....I couldnt get Energy XM1 as the company people said that Energy series starts at R14 only...
but nevertheless, it turned out to be an excellent decission...the tyres are amazing....my steering feels soooo light (I have a manual steering) and the grip and control is superb...noise has reduced drastically and comfort levels have gone up significantly..all in all Michelin Zindabad
Old 6th November 2007, 15:54   #12
reignofchaos's Avatar
Thanked: 1,302 Times
Yup... seemingly Energy XM1 is only on 14" or higher.
Michelin India - All Patterns
Old 6th November 2007, 16:12   #13
iraghava's Avatar
Thanked: 156 Times
Congrats Pani, glad to know you're happy with the tyres, enjoy!!
Old 6th November 2007, 18:56   #14
kpzen's Avatar
Congrats pani....
Another Michelin fan in the making i guess...
Old 6th November 2007, 19:12   #15
n_aditya's Avatar
Thanked: 2,779 Times
Hey pani, congrats on the purchase and the excellent choice. Fill 'em up with nitrogen for better results. Search for more info.
From a City Down Under to a Country Down Under : From a RX100 to a Fatboy... LTAutoMad Introduce yourself 9 22nd July 2014 16:35
100 BHP+ Diesel Sedan under 10 lakhs - Booked Verna CRDI SX (ABS), now under 9 lakhs newcoolgadgets Sedans 84 16th September 2009 21:28
best gear oil & best coolant & best engine decarb: please cyneverdie Technical Stuff 7 19th October 2007 03:57
BFGoodRich Tyres available in Mumbai? Also Best Size For Esteem for Max Performance.. Tool Tyre & Alloy wheel Section 1 4th June 2006 03:28
