Old 8th November 2007, 13:27   #1
funkydevil's Avatar
Thanked: 93 Times
Default NHC Tyre Upgrade...Help needed !!!
Hey guys,
I drive a 32000+ kms run NHC, had given it for service recently and was told that the life of my tires were over as they are worn out, and that i needed to get them changed . However i felt that i still could use them for sometime but the service center guy told me that it would be dangerous at high speeds as i wouldnt have enough grip on the tires . These are completely stock and have not been changed ever. The car presently runs on bridgestone 14inchers. I have been eying a few rims on passing NHC's and have got an idea of the design of the rim needed. Its the tires that have me confused, altough i have read quite a lot over the forum on NHC tyres i just donno what to choose!!! hence im listing out what i need the most from my tires,
Fuel efficiency is a first priority
Comfort
Less tire noise
Any suggestions on what to put n where would be very helpful, I wouldn't want to spend much on the tyres as im saving up for the ICE in december . I reside in mumbai. Thank you all in advance
funkydevil is offline   Reply With Quote
Old 9th November 2007, 16:48   #2
funkydevil's Avatar
Thanked: 93 Times
Plz guys give me some suggestions
Old 11th November 2007, 13:47   #3
175/65 R14 YOKO A300 or Michelin En XM1.
Best tyres on low NVH.
itzzme is offline   Reply With Quote
Old 11th November 2007, 14:07   #4
iraghava's Avatar
Thanked: 156 Times
Yup, I too would suggest either the Yoko's or Michelin's in stock size as you're looking for FE & Ride Comfort.
Old 11th November 2007, 14:23   #5
nithinnarayanan's Avatar
Yes, I back @ itzzme for the tyres and as far as alloys, I would suggest League as they are lighter than most other brands which will help you in getting good FE.
nithinnarayanan is offline   Reply With Quote
Old 11th November 2007, 19:24   #6
kpzen's Avatar
Thanked: 1,655 Times
Yokohama A300 and Michelin Energy XM1 should serve u the best.
Old 11th November 2007, 20:05   #7
funkydevil's Avatar
Thanked: 93 Times
Hey guys, thankx for all yre replies, altough i would like to know if would ride comfort and FE go down considerably if i put on 15 inchers?? tires would be the same one's you all suggested.
Old 11th November 2007, 20:11   #8
kpzen's Avatar
FE would only go down marginally but the ride quality would definitely go down. My suggestion - stick with 14".
Old 11th November 2007, 20:20   #9
funkydevil's Avatar
Thanked: 93 Times
Hey thanks for the quick reply Kpzen, would get them changed then..with the usual 14 inchers..
Old 18th November 2007, 22:09   #10
funkydevil's Avatar
Thanked: 93 Times
Hey guys,
Went to closing tyre shop with a friend today and kinda looked around for the required tires, Michelin Energy XM1 (yes those are the one i have chosen for my ride as suggested by my fellow T-Bhpians). Was in a little bit of a hurry as was pretty late and the shop was almost closed so just thought of asking the dealer for the price, when i saw something that got me completely confused. Ther are supposedly 3 series in the Michelin xm1 range i.e. 70, 65 and 60 series. The dealer wasnt present, another person was at the place who had no knowledge of these series tough he did tell me there are 3 different series in that range. I went through the michelin india site and just could not understand anything from the table given. Posting the link below
Michelin India - Energy XM1
Could someone plese suggest me the difference between these series and how they will affect my ride...thanks
Old 19th November 2007, 08:19   #11
DieselFan's Avatar
Thanked: 234 Times
The series you are referring to is the aspect ratio (one of the tire size parameters). you will get more inputs on tires and wheels in the following link -
http://www.carbibles.com/tyre_bible.html
DieselFan is offline   Reply With Quote
Old 19th November 2007, 12:49   #12
kpzen's Avatar
Stick with your stock size and u would never go wrong.
Tyre upgrade/alloys fitment - NHC AshOnTheRocks Tyre & Alloy wheel Section 21 26th July 2014 19:18
NHC Tyre Upgrade Advice sunilvarma Tyre & Alloy wheel Section 24 6th June 2010 15:47
ICE Upgrade needed for NHC Vtec.. Help bobster In-Car Entertainment 5 1st July 2008 19:05
NHC tyre and wheel upgrade!! nikkibike Tyre & Alloy wheel Section 12 4th October 2007 19:02
Tyre upgrade for NHC Samurai Tyre & Alloy wheel Section 13 29th March 2005 13:56
