Closed Thread
Old 9th November 2007, 00:29   #1
Default Tyre upgrade for lancer. help pls..
hai frnds.. iam having lancer & my tyre size is 175/80/r13.Iam planing to upgrade it to 15''.so please tell me the suitable size in 15" to fit & cost.I want
Performance
Control
Milage
Looks
also tell me whether it will affect when travelling with 5 persons.
prav_05 is offline
Old 9th November 2007, 04:46   #2
WasavaTyres's Avatar
Thanked: 255 Times
Performance + control + MILEAGE + looks !! Is santa coming to town Dude if u plan to go for 15" be ready to compomise on ride quality as well as fuel efficiency to some extent. You can go for a max size of 205/65/R15 for your lancer. Though I would suggest you stick to 195/60/R15
WasavaTyres is offline
Old 10th November 2007, 00:00   #3
@wasava tyres..
thanks for your advice..should i modify the suspension for 15"?will it affect when travelled with 5 persons
prav_05 is offline
Old 11th November 2007, 10:33   #4
Bikerboy5432's Avatar
i think 205/50/15 Yokohama would be just fine .. redeye has got the same for his lancer 15inch alloys
Bikerboy5432 is offline
Old 11th November 2007, 19:52   #5
razor4077's Avatar
Thanked: 258 Times
That's not a very good upsize. Would suggest you go for 205/50/15, which is the option I selected. No scraping issues, even with full load. Some have opted for 205/55/15, whose rolling radius is closer to the stock size. This, can however, have scraping issues under full load.
The other option is 195/55/15... not too much choice in this size though.
As WasavaTyres has mentioned, you will have to compromise a bit on the ride quality if you opt for low profile perormance-oriented tyres. There are several options out there, and you can go through the tyre & alloys section to know about these.
I have fitted 205/50/15 Michelin Pilot Preceda 2 tyres on Plati alloys, and am very happy with the overall package.
razor4077 is offline
Old 11th November 2007, 20:00   #6
kpzen's Avatar
Thanked: 1,655 Times
205/50-15 is the perfect 15" upsize for Lancer.
Get either Michelin PP2 or Yokohama S drive
Don't expect any mileage improvement when u upsize from 175s to 205s..!
kpzen is offline
Old 12th November 2007, 02:27   #7
I have chosen 195/60/R15 with bridgestone potenza tires..is it correct upsize?
prav_05 is offline
Old 12th November 2007, 13:58   #8
kpzen's Avatar
Have U finalised or bought them already..??
The size is incorrect. All the correct upsizes have been mentioned in the above posts.
kpzen is offline
Old 12th November 2007, 21:16   #9
@Kpzen
No..I just choosen not yet bought.if i choose the 195/60/r15 tyre size calculator shows "when ur speedo reads 100kph,u r actually traveling 100.8kph".when i choose 205/50/r15 it shows "when ur speedo reads 100kph,u r actually traveling 96kph".what does it mean? does it affect the speed when choosen 205/50/r15.
prav_05 is offline
Old 12th November 2007, 23:15   #10
Zappo's Avatar
Thanked: 2,080 Times
This is one dead horse and no point flogging it over and over. Please use the search feature to locate details about how to calculate tyre sizes and what they mean. You can even use the tyre bible at carbibles.com. It has excellent reference on the subject.
Thread closed.
Zappo is offline
Closed Thread
Tyre and rim upgrade for the Lancer razor4077 Tyre & Alloy wheel Section 64 1st May 2017 03:19
pls pls wear helmets!!! ns_jughead Street Experiences 35 3rd August 2009 15:05
Pls help in ICE upgrade in Santro Vino_David In-Car Entertainment 10 13th September 2007 14:16
Tyre upgrade for lancer sfxi Vid6639 Tyre & Alloy wheel Section 25 23rd September 2006 23:18
