Old 17th March 2009, 13:19   #16
genesis's Avatar
Thanked: 171 Times
A tube in a tubeless tyre is okay if it is an emergency and you are someplace where knowledge/availability of tubeless tyres is less (like in the hills). I personally would not be comfortable using such a thing on a highway/expressway for long.
As others suggested use the old tyre as a spare but do get a new tubeless after getting the rim fixed or bite the bullet and get a new wheel and tyre (more expensive but safer)
genesis is offline   Reply With Quote
Old 17th March 2009, 13:26   #17
Thanked: 40 Times
Originally Posted by Nikhilb2008 View Post
@Happywheels -- I'm assuming he has alloy wheels. In which case getting the rim fixed is nearly impossible... Not recommended at all unless you use it only in case of emergencies and that too at low speeds.
Absolutely true!
It's a Palio 1.6 Sport: missed that out! My bad!
HappyWheels is online now   Reply With Quote
Old 17th March 2009, 14:38   #18
mmmjgm's Avatar
Thanked: 11 Times
Dude, remove the tube and have the tyre replaced/repaired ASAP.
We had a safari, with Tubeless radials on it, some how during the course of its life many drivers drove the car, someone placed tubes to repair a puncture, one fine day, the tube burst due to excessive flexing against the sidewall (heat generated due to friction with the internal walls of the tyre), luckily we were at low speeds and meters away from home.
Extensive tube use in a tubeless tyre is not safe. The tubeless tyre is designed to have a layer of impermeable rubber inside to avoid leakage of air.
Have it changed as soon as you can and avoid high speed runs (anything over 60kmph while the tube is on).
M
mmmjgm is offline   Reply With Quote
Old 17th March 2009, 14:51   #19
PankajP's Avatar
Hey all,
Thanks for all your replies.
just wanted to tell you all that the tyre is all right nothing has happened to it. This tyre is new one which I had replaced after 1st bump.
The problem is only with alloy wheel which is bent slightly. I just now called up Tata-Fiat showroom in Pune and they quoted 5900 for a single Fiat Alloy wheel.
What I am thinking is to keep that bent alloy wheel as a spare(5th) and put on new one on the car.
But I think 5900 is too much for a single alloy when I had heard that we get all 5 in 12k. Need to research on that
PankajP is offline   Reply With Quote
Old 17th March 2009, 15:00   #20
sgiitk's Avatar
Thanked: 1,186 Times
Have we forgotten the fifties and sixties. All cars came with tubeless tyres. As son as you had the first puncture you had to put in a tube since there was no facility for fixing tubeless tyres. I think the first car to come with tubeless tyres in the recent past was the Cielo.
The only difference between tubeless and tube tyres is a soft rubber lining to hold the air. Otherwise theya re identical. So go ahead and use the 'now tubed' tyre with impunity.
sgiitk is offline   (1) Thanks Reply With Quote
Old 19th March 2009, 19:41   #21
If this is true then I might find some use of the two A-Drives in my garage. But will it be safe having a tube in a tubeless tyre??
Also I'll need to get a sidewall patch in one of the tyres as well. So please let me know if it is safe as well.
goel.honey is offline   Reply With Quote
Old 20th March 2009, 00:56   #22
Raccoon's Avatar
Thanked: 83 Times
Dude, is this even a valid question? Do you know a single tyre company that says you can use tubes in a tubeless?? Now supposing some smart-*** bloke like me , on the internet, says that you can safely do so, and you belive me, and end up in a hospital due to some mishap or something, you can be pretty sure I won't be paying your hospital bills...
Old 20th March 2009, 10:49   #23
sgiitk's Avatar
1. No problem in putting a tube in a tubeless tyre. Perfectly fine.
2. Any repairs outside the tread area are a big NO-NO. So patching a sidewall is definitely out. You have to get a new tyre.
Old 20th March 2009, 20:28   #24
Thats the reason I was asking. Just wanted to confirm the same.
Thanks mate. Atleast now I can use 1 of those tyres.
Old 21st March 2009, 04:48   #25
Originally Posted by yzfrj View Post
Tube-type and tubeless are made differently.
Tubeless tyre is supposed to have a stiffer side wall.
Yes a tube can be used in a tubeless tyre, but this is not a permanent solution and should be used in case of any emergency.
A tubeless with tube as a spare will be fine.
But for regular use, I'm not sure.
Its not designed for that so the results of a tube in a tubeless is a bit of uncharted territory and is definitely "not" recommended in the long run.
During the recent wheel balancing, I realized that all my my tyres (stock on Swift VXi -- JK Tornado Tubeless) have tubes!! I had driven this car for 16K Kms in almost three years on quite a a few occasions on real bad roads!! No punctures so far (touchwood).
The tyre has a clear marking on it saying tubeless
I presume this is as per Maruti standard, since that's how this car was delivered to me!
I am just curious -- does all the swifts' sotck tubeless tyres have tubes in it? Can folks corroborate this?
Is it recommended to remove the tubes?
regards
zensure is offline   Reply With Quote
Old 21st March 2009, 10:21   #26
SS-Traveller's Avatar
Thanked: 2,813 Times
Zensure, my Swift ZXi has JK tubeless tyres, and there are no tubes inside. This (fitting tubes in a tubeless tyre) would be a highly unusual practice, sometimes followed by commercial (taxi) drivers.
Was your car run/maintained by any other person during its lifetime? Otherwise, if you have been the 1st owner, you can lodge a complaint with the dealer you procured it from.
And please get rid of the tubes from the tyres, since the puncture-resistant characteristics of a tubeless tyre are lost when a tube is present inside.
Old 21st March 2009, 10:38   #27
Thanked: 45 Times
Very interesting thought!
How does this happen?
Old 21st March 2009, 11:10   #28
With a nail buried in the tyre tread of a TL tyre, the leakage of air is only through the thick rubber around the nail - a slow process. With a nail going thru the tread and the tube, while the tyre rolls, the tip of the nail gradually makes a bigger hole in the tube (due to a slight shuffling movement between tyre and tube) -this makes for faster air loss from a tubed tyre (or a TL tyre with a tube in it).
Old 21st March 2009, 11:10   #29
MindSpeeDs's Avatar
A puncture on the side wall made me go for a tube in a tubeless tyre. 5k km done, no issues as yet.
MindSpeeDs is offline   Reply With Quote
Old 21st March 2009, 11:18   #30
Thanked: 45 Times
...... the tip of the nail gradually makes a bigger hole in the tube (due to a slight shuffling movement between tyre and tube) -this makes for faster air loss from a tubed tyre (or a TL tyre with a tube in it).
Two things:
1) What if the puncturing nail does not stay embedded?
2) What if the nozzle of the tube is fitted to the rim with suitable gaskets to prevent air leaks from that portion?
Mixing tube and tubeless tyres achinthg Tyre & Alloy wheel Section 21 8th September 2012 14:10
Tube-type to Tubeless conversion?! tsk1979 Tyre & Alloy wheel Section 53 1st August 2008 08:37
Tube tyres converted into tubeless - Is it possible and safe?? Deeps Tyre & Alloy wheel Section 3 28th September 2007 20:22
"Tube type" tubeless tyre vRS Tyre & Alloy wheel Section 4 8th March 2006 22:39
Tube inside tubeless tires... Samurai Tyre & Alloy wheel Section 1 25th February 2005 15:32
