Old 29th November 2007, 14:20   #1
inder_s1's Avatar
Thanked: 37 Times
Default Tyre and Alloys upgrade for my BMW 316i
Hi Guys,
I want to upgrade alloys and tyres for my BMW 316i.
At present it's on
Rims: 15"
Tyres: 195/65 Michelin Tubeless
I found out I can use 17" Alloys and 245/45 would be best for it from car bible site.
I want to know which tyre type and what tread pattern should I use. Any help is appreciated.
inder_s1 is offline   Reply With Quote
Old 29th November 2007, 15:14   #2
Thanked: 103,412 Times
Michelin PP2's. Tried + Tested. Superb quality rubber.
Old 29th November 2007, 15:52   #3
Originally Posted by inder_s1 View Post
Hi Guys,
At present it's on
Rims: 15"
I think 225/45 R17 will be beter inch-up.
itzzme is offline   Reply With Quote
Old 29th November 2007, 16:26   #4
inder_s1's Avatar
Thanked: 37 Times
Question
Thank You for the input guys...
Was checking Michelin webiste for India.
The aval tyre sizes which I feel will be good after your suggestions are :
225/45-R17
235/45-R17
Any idea on the alloy wheels front. Which brand is better lenso or acura or imported ones ?
Old 29th November 2007, 16:47   #5
iraghava's Avatar
Thanked: 156 Times
I would recommend you not go above 215/45 R17 or at the most 225/45 R17 for you car. Reasons being:
1. It's only got a 1.6litre engine, fitting too wide tyres like the 245's will slow her down.
2. Your FE will also drop along with the Ride Comfort.
3. 245's I'm pretty certain will also foul with the bodywork of your car.
P.S. I just checked, the 245's will also be beyond the OD difference tolerance limit so I would rule them out even if they fit.
Old 29th November 2007, 17:43   #6
Akshay1234's Avatar
Thanked: 7,240 Times
with ishaan. i dont think you should go more than 225. though IMO 205 would be enough.
Old 29th November 2007, 18:15   #7
inder_s1's Avatar
Thanked: 37 Times
I have decided on 225/45 courtesy your inputs guys!
Thank You.
Any idea on which brand 17" Rims should I go for??
Old 29th November 2007, 19:08   #8
Mpower's Avatar
Thanked: 1,687 Times
What year is your 316?
I have 225 front and 245 rear on 17s.
Old 29th November 2007, 19:25   #9
Akshay1234's Avatar
since its a bmw why not ac schnitzer or hamann?
Old 29th November 2007, 20:12   #10
inder_s1's Avatar
Thanked: 37 Times
Mpower
1. Did such combi 225 front and 245 rear slow the car down?
2. Did it affect the ride comfort?
3. My car is '95, what abt yours?
Akshay1234
Thanks for the suggestions. I need to check if AC Schnitzer or Hamann are available in B'lore.
Last edited by aah78 : 29th November 2007 at 21:25. Reason: Please no SMS / Slang. Eg. use "yours" and "check".
Old 29th November 2007, 23:05   #11
Harbir's Avatar
Thanked: 975 Times
My 330i had 225/45-17s front and 245/40-17s in the back. For handling and steering response, this was as good a combination as 225/45-17s in both front and back, but it worked very well for putting down impressive torque of the engine in tight corners.
The tire combination you are considering for an E36 316i is a bit ridiculous (no offence). Consider that the 321hp M3 version of your car had only 235/40-17s. What are you looking to gain with the enormous tyres given the modest power of your car?
This tire size with its matching wheel size will greatly increase the "unsprung" mass of your car, causing your ride and handling to deteriorate. The greater mass also translates into increased inertia, which your modest engine will face when accelerating the car, which means your car will lose acceleration and the throttle will become more sluggish. And thats just due to the added weight.
The excess width of the tires with the low profile will lead to crisper steering, better braking feel, and more grip in corners, but as your car's springs and dampers are tuned in expectation of a certain degree of softness from the tire sidewall, you will suffer ride quality deterioration and the car's handling will change. You will have more grip but less "communicativeness" from the contact patches. But the increased grip may for you offset that if you are not a driver who likes how a car comes alive as it approaches its traction limits in turns.
My advice is that this not an optimal tyre choice. It may be better than what you have now, but it is most certainly NOT the best you can do for your car.
If it was my car, with its modest 102hp, at the most I would it with 205/50-16s, but more likely with 195/55-16s.
Harbir is offline   Reply With Quote
Old 30th November 2007, 00:34   #12
Harbir's Avatar
Thanked: 975 Times
I am sorry, an error on my part reversed the meaning of what I was trying to say.
The above should have read:
"My 330i had 225/45-17s front and 245/40-17s in the back. For handling and steering response, this was NOT as good a combination as 225/45-17s in both front and back..."
Old 30th November 2007, 11:28   #13
Agreed. 245 will surely be overkill for a 316. 205 or 215 should be just perfect.
Old 1st December 2007, 20:39   #14
Mpower's Avatar
Mpower
Akshay1234
Mines a 97 M3. The 95s had 235s all around. Going to 245 in the rear adds some understeer.
Was it an E46? The one's I've seen with sport package had 255/18s in the back. Not sure about the short lived E90 330i.
Old 1st December 2007, 21:10   #15
Harbir's Avatar
Thanked: 975 Times
yes it was. there was the regular sport package with 17s, 245 in the back. then there was the performance package, aka the ZHP, starting with the '03 model, that had 18s, 255s in the back.
To Buy a 1994 BMW 316i or Not. Now: 1995 BMW 540i AT? snap316 Luxury, Imports & Niche 34 20th March 2016 12:50
Restoration project Of my 1989 BMW E30 316i Stroke^ Modifications & Accessories 111 9th November 2013 18:52
New Hyundai i20 or 8 years old BMW 316i rahulch What Car? 16 17th February 2011 15:00
Upgrading BMW 316i inder_s1 Modifications & Accessories 15 23rd August 2009 16:27
Need information on Fuel Pump for BMW 316i inder_s1 Shifting gears 7 11th October 2007 13:24
