Old 15th December 2007, 12:19   #1
Aashutosh's Avatar
Default Wheel Balancing for my Santro 2001
I have a santro 2001 make. purchased second hand from First Choice (formerly Automart India). I have changed suspensions of car just two months back.
I still feel vibrations when car goes thru potholes, although the it is not that hard as compered to earlier, still I am amazed to feel the smoothness in other's cars which are even older than mine.
I am note sure if earlier owner done wheel balancing or now.
Please advice if wheel balancing would be required to ensure smooth ride.
Also please let me know any good shop in Mumbai to get this done. Thank you.
Aashutosh is offline   Reply With Quote
Old 17th December 2007, 13:17   #2
manojgautham's Avatar
Thanked: 11 Times
Originally Posted by Aashutosh View Post
Where did you get the Suspension done? What all was changed?
Check if your tyres are over flated.
Wheel balancing needs to be done to ensure the wheels travel in the reight direction. Get it done if your vehicle pulls to either sides while braking or going straght.
I guess someone from Mumbai will be able to help you with this.
manojgautham is offline   Reply With Quote
Old 17th December 2007, 16:50   #3
PatienceWins's Avatar
Thanked: 284 Times
If you get steering wheel vibrations at high speed, then balancing needs to be done. Not sure about vibrations on potholes.
The Santro ride is not good on bad roads.
I do allignement/ balancing/ rotation every 5000 kms and it helps to keep the suspension in good condition and increase tire life.
PatienceWins is offline   Reply With Quote
Old 18th December 2007, 09:48   #4
Aashutosh's Avatar
hello,
I am not getting vibrations at high speeds. Its only when I start car and put in 1st gear, then slowly release clutch, then car vibrates a bit (I guess thats normal) for approx 10 seconds and once I press acc, all fine. NO vibrations.
However, when car passes thru any pothole, one can feel the bump depending on the size. I dont think its suspension problem as I recently got it replaced. Many have adviced to get balancing done as it smoothens the car ride to an great extent.
Your suggestions please....
Wheel alignment or wheel balancing?? leodelg Tyre & Alloy wheel Section 27 22nd June 2011 00:44
Breakdown Assistance for 1 year, Wheel Alignment & Wheel Balancing just for Rs 199 Mitsun Soni The Indian Car Scene 11 8th March 2011 11:02
Newbie questions - wheel balancing, wheel alignment. johy Technical Stuff 8 6th December 2006 10:39
Are wheel Balancing Weights normal on a new showroom car? Rishi Technical Stuff 4 11th May 2005 10:40
