Old 6th September 2011, 08:16   #31
Thanked: 31 Times
Default Re: Repair Alloy - Is it possible?
Originally Posted by triedeverything View Post
I've fixed a bend to my Alloys as well. This guy does a pretty good job. I drove the car for about 5k before I sold it. I've seen this guy repair alloys that have a portion that has broken off...and its not a hammer and wood block that is used. They use some kind of heat treatment.
This paricular alloy that I got fixed had taken such a beating that it pinched and sheared the tyre at a certain plac. I had to replace the tyre as it was tubeless. That way, steel rims are better. I had two flats in less than a minute. As the second flat was on a stepne which was a steel rim, I found a shop nearby where they used a large hammer to beat the rim back into shape so that it would now hold air for the tubeless tyre.
Lessons learnt
- avoid low profile tyres
- always maintain optimal air pressure
- keep an additional spare wheel during long trips-preferably a steel rimmed one
Thank you very much for this information. last month my Linea alloys scraped through the kerbs and has a dirty gash on Front LHS Alloy. Its a big eyesore to see that daily, let me get in touch with the above guys and check if they can repair it.
EARTHed is offline   Reply With Quote
Old 31st October 2011, 11:19   #32
Awaiting Email Confirmation
Thanked: 4,212 Times
Originally Posted by PatienceWins View Post
The alloy wheel of my bike (CBR 250) got bent. Is there any recommended place in bangalore where I can repair it?
Did you get the bent alloy wheel repaired at A1 Car Care Centre, Jayanagar, Bangalore? If so, kindly give details like nature of work done, cost, whether repainted after repairs, etc. I have a spare alloy wheel with a slight bend at the edge. I want to get it repaired and use it as spare, if it is feasible.
J.Ravi is offline   Reply With Quote
Old 15th November 2011, 09:11   #33
Finally, I got the bent alloy wheel repaired satisfactorily at A1 Car Care Centre. My review is here (Alloy wheel repair + Balancing + Alignment : A1 Car Care Centre (Bangalore)). Details of the work carried out are here (Cara Mia Fiat Linea!).
Old 10th March 2012, 16:38   #34
Ricci's Avatar
Thanked: 914 Times
You know as they say, stuff happens. While taking a U turn, the front left scraped the kerb, now the alloy is scuffed over several spokes, a little scrape on the bumper. The wheel looks worse than the bumper though, is there some place in Pune where it can buffed/leveled to even finish and idea of approx cost ? The process involves sanding/grinding , will this cause the structure to weaken ?
Ricci is offline   Reply With Quote
Alloy wheel repair + Balancing + Alignment : A1 Car Care Centre (Bangalore) J.Ravi Bangalore 22 29th November 2017 14:02
Body Repair & Painting, Glass Repair, Detailing etc. - Trend Automobiles (Bangalore) decode Bangalore 278 9th November 2017 00:44
Autocop remote repair possible? mohit Modifications & Accessories 24 8th November 2017 15:41
Alloy Wheel Repair Specialists - India Maverick5490 Tyre & Alloy wheel Section 24 1st September 2017 00:27
Sidewall cut in tubeless tyre - repair possible? archat68 Tyre & Alloy wheel Section 91 30th June 2017 11:41
