Old 20th August 2009, 16:18   #76
tsk1979's Avatar
Thanked: 16,011 Times
Always check tire pressure when cold.
For example when I fill 32 PSI when cold, after a highway run it sits at 35PSI approx.
Tires get hot on running, and this increases the pressure.
Remember P1V1/T1=P2V2/T2
Old 20th August 2009, 22:13   #77
Thanked: 61 Times
The old model Maruti Zen (mine is 2003 Lx) recommends 24 psi with tube type tyre. Now I have fitted alloy wheels with Bridgestone Turanza tubeless tyres and running with 26 psi. I earlier started with 32 psi as recommended by the tyre dealer and gradually decreased the same to 26 psi. Ride quality is good enough. Should I stick to 24 psi? Does Maruti recommended tyre pressure is ok for tubetype and tubeless tyres?
gaddiwale is offline   Reply With Quote
Old 20th August 2009, 22:32   #78
frankmehta's Avatar
Thanked: 2,310 Times
i got PP2s on my Fiesta, and they are 205/55/R15 in size. The tyre placard indicates 36 PSi in the front tyres and 41 in the rear. I have 30 front and rear right now. What should be done????
Old 20th August 2009, 22:44   #79
Fountainheader's Avatar
I have 29 psi and the tyres look deflated. But 36 is way too much!!
Fountainheader is offline   Reply With Quote
Old 20th August 2009, 22:51   #80
frankmehta's Avatar
what should make the ride quality better? i felt that the car was riding over potholes better @ 30 than the previous 28. it was way too bumpy @ 28.
Some guru should comment!
Old 20th August 2009, 23:04   #81
nitrous's Avatar
Thanked: 285 Times
So, run nitrogen.
Old 21st August 2009, 11:23   #82
Originally Posted by Speedzone View Post
I have a OHC 1.5 exi fitted with 205/60,R13 on the stock wheels done by the previous owner. what is best typre pressure i should be maintaining
Also do you think 205/60, R13 is the best replacement for the stock tyres
As mentioned earlier 205/60/R13 stock tyres running on my OHC are tubeless. I've tried 32 PSI on both front and back, but the ride seems to be little bumpy at low rpm's.
Just to add, i normally ride alone to everyday with no added luggage. Should i be changing it all to 34 PSI? Or as suggest by Nitrous, should i try Nitogen?
Experts pls suggest
Speedzone is offline   Reply With Quote
Old 17th September 2009, 14:49   #83
Chevy_lover's Avatar
Thanked: 121 Times
Default Tyre pressure for Tavera
Dear Team,
My Tavera has 205/60 R15 tyres. I have replaced all old ones and now I have Goodyear Assurance tyres. The company recommends 26 and 35 psi. I feel the front tyres are a bit under-inflated. I am in the middle of a long road trip and am presently in Ooty. The tyre dealer insisted on 32 psi in the front tyres. And I use nitrogen now.
My query is whether this pressure is correct? I now have 32 and 35 psi. I lost two front tyres earlier due to sidewall bursts. Could it be because of under inflation? I had a very smooth ride in the ghats yesterday, with brand new tyres and new air pressure. What is the opinion of the Gurus here?
Chevy_lover is offline   Reply With Quote
Old 17th September 2009, 15:07   #84
Gansan's Avatar
Thanked: 909 Times
Can someone suggest the correct tyre pressure for Alto? Right now I am keeping 31 PSI for all tyres. I have it checked every Sunday morning, on cold tyres.
Old 17th September 2009, 15:46   #85
Thanked: 121 Times
Default Tyre patching
Dear Team,
Is using a tyre with a patch ok?
Old 17th September 2009, 15:54   #86
gpa
gpa's Avatar
Thanked: 281 Times
@ Gansan: 31 psi all-round on cold tyres is the best for the Alto. I run 31 psi (city) and 33 psi (highway) on my car and after 20,000 kms and 2 sets of WA/WB and WR, the wear is even on all 5 tyres.
Which brand of tyres does your Alto have? Mine runs on MRF ZVTS.
Old 17th September 2009, 16:03   #87
Gansan's Avatar
Thanked: 909 Times
Thanks gpa. Mine too runs on the MRF ZVTS tyres. Just one more doubt. Since the spare wheel is free of any load while checking pressure, and we keep 31 psi in that tyre too, will it have a higher pressure when it is actually used to replace a flat tyre and load is applied? Some guys say we should keep about 2 psi less in the spare tyre.
Old 17th September 2009, 16:04   #88
Thanked: 49 Times
Originally Posted by Chevy_lover View Post
Dear Team,
What kind of patch are we talking here ? Are you talking about a simple puncture repair or a tyre cut/sidewall cut that was repaired ?
Please describe further or post a picture if possible.
CrackedHead is offline   Reply With Quote
Old 17th September 2009, 16:39   #89
yzfrj's Avatar
Thanked: 119 Times
Dear Team,
26 for Front ?
Even for a Zen its 28 at front.
Tavera being a diesel thus having a heavy front end IMO needs more pressure.
Dear Team,
I guess you mean patch used to repair a minor damage or a huge size puncture. In my experience its pretty ok provided the job is done properly.
Only thing you need to do is to get the tyre balanced as the patching would have upset the "normal" state of the tyre else you can have a wobbly/vibrating tyre.
yzfrj is offline   Reply With Quote
Old 17th September 2009, 20:05   #90
Thanked: 121 Times
Thank you everyone for the replies.
My front right tyre's sidewall burst. There was a 4 cm long cut. I repaired it with a patch and put tubes inside. After that my Chevy was vibrating like a chainsaw! I drove @ 60 km/hr from Kodai to Coimbatore! If the speedo touched 62, then the steering would vibrate like anything. Finally replaced the tyre @ Coimbatore.
My advice to the team, never use patched tyres! Saying from my experience, it will take your breath away! You can lose total control anytime!
Coming back to my earlier query, what is the best tyre pressure for a ton heavy vehicle like Tavera? How good is Nitrogen? I have 4 new tyres. And I want them to last long! Two of my old tyres gave me 72k kilometres.
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
Right air pressure after an upgrade watashi75 Tyre & Alloy wheel Section 4 24th July 2008 10:15
right tyre pressure for dunlop sp9000 205/55 R15 nisheel Tyre & Alloy wheel Section 5 5th March 2008 04:56
accord is it right price and right time to buy used rubin2006 Luxury, Imports & Niche 15 6th December 2006 15:36
Right tyre pressure for my baleno premdiv Tyre & Alloy wheel Section 5 13th July 2006 22:52
