Old 18th October 2011, 09:32   #31
ilangop's Avatar
Thanked: 591 Times
Default Re: PCD Conversion: How Safe and Availability
Hello Lowbassmaker,
Had you tried chopping off the hexagonal head of the wheel nut used in a Jeep or Sumo and use it as a wobble washer? Will that be a simpler job.
Have you installed the 114.3 PCD rims in your car. Please post pictures.
ilangop is online now   Reply With Quote
Old 29th December 2011, 13:42   #32
ilangop's Avatar
Thanked: 591 Times
Default 100 PCD to 98 Conversion for 118NE
Originally Posted by low_bass_makker View Post
Ya sure !!!! Do ask if in doubt !!!
Attachment 820104
Hi low_bass_makker,
Here is the picture of a M800 wheel nut that has been machined to function as a wobble washer.
Also I had to fabricate a spacer plate to account for a difference in the recommended offset. The rest is all understood from the attached pictures. Also I did have to fabricate a bush to adjust for the hub dia at the centre of the rim. Yet to paint the wheel, actually the whole car
PCD Conversion: How Safe and Availability-25122011094.jpg
PCD Conversion: How Safe and Availability-25122011124.jpg
PCD Conversion: How Safe and Availability-25122011093.jpg
Old 9th December 2012, 20:39   #33
o.D
o.D's Avatar
Thanked: 41 Times
Originally Posted by vikram_d View Post
My replies in bold. Hope this helps.
Hey Vikram,
Looking for similar conversion from 114.3 PCD to a 100 PCD. I had tried them with aluminium blocks in the past(2008) and was not satisfied with the handling and back then both rjstyles69 and theMAG recommended on reaching you out. I am currently looking for 114.3 pcd alloy options but found none to my liking until recently chanced upon a 100 pcd 4 hole 13" alloy.
Kindly in help/guide in getting them made.
Cheers.
o.D is offline   Reply With Quote
Old 9th December 2012, 23:37   #34
vikram_d's Avatar
Thanked: 940 Times
I can help you get these made. What car are they for?
Old 10th December 2012, 22:44   #35
o.D
o.D's Avatar
Thanked: 41 Times
Great.Thanks! These are for m800. Have you heard from you're friend lately on the performance or alignment.
Cheers.
Old 11th December 2012, 07:33   #36
vikram_d's Avatar
Thanked: 940 Times
Cheers.
My friend sold the car some time ago and till the end he never mentioned any problems.
Old 16th January 2013, 20:12   #37
Cheers.
Hello,
Can you please let me know how much would it cost to get PCD converter of 114.3 to 100. Please mail me to kariappa.m@gmail.com
kari is offline   Reply With Quote
Old 26th February 2013, 02:26   #38
SHAHBAAZ's Avatar
Thanked: 109 Times
Hi, I am looking out for 13" 98 PCD alloys, and its been really hard to find one. Should I go for adaptor plate and fit in 100 PCD - 13" alloys? How good will it be is use for my 2002 palio considering the fact that its no power steering.
I would appriciate your feedback.
SHAHBAAZ is offline   Reply With Quote
Old 26th February 2013, 10:20   #39
ilangop's Avatar
Thanked: 591 Times
I have used an adaptor & wobble washer setup in my 118NE to adapt a 100 PCD alloy. I haven't faced any issues so far. I have driven the car for about 5K kms.
Things to ensure are -
1) The same wheel track is finally achived, means be sure about the offset of the wheel.
2) Use the right size of tyre as recommended by the manufacturer.
Since you are in Pune, you may drop in at my place in the evenings to see how the adaptor & wobble wahser setup has been done in my car.
Availability of Spares by Indian and Foreign Car/Bike/Scooter Makers?? anjan_c2007 Vintage Cars & Classics in India 7 17th November 2009 17:12
Help Required: Procuring Alloy Wheel nuts for Palio (98 PCD conversion) basilmabraham Tyre & Alloy wheel Section 33 12th July 2009 12:40
Meguiars and Turtle Wax availability caliper Modifications & Accessories 5 14th June 2007 17:36
Streetglow availability in Singapore and/or London manveet Modifications & Accessories 4 25th September 2006 11:40
Optra Rims PCD and Offset help! iceman-kimi Modifications & Accessories 22 27th September 2005 20:49
