Old 3rd October 2008, 23:28   #91
crazydiablo's Avatar
Thanked: 21 Times
I would not go 205 on a stock baleno. especially on 14s it looks a bit bulky.
crazydiablo is offline   Reply With Quote
Old 4th October 2008, 00:47   #92
iraghava's Avatar
Thanked: 153 Times
Originally Posted by kailashnj View Post
205/60 R14. This will give me exactly the same ground clearance as the stock tyre.
What is the rim width of the alloys you plan to run 205's on?
Old 4th October 2008, 07:16   #93
kailashnj's Avatar
Thanked: 275 Times
205 would run on the stock alloys that have come with the baleno. I think I will drop the plan for upsizing. I will stick to the stock size 185/65 R14 bridgestone potenza GIII as I see lot of issues behind upsizing.
kailashnj is offline   Reply With Quote
Old 4th October 2008, 10:31   #94
rjstyles69's Avatar
Thanked: 789 Times
Honestly having tried and tested that , the 205's would be an overkill for the Baleno. 195's should do the job, stick to it.
Old 4th October 2008, 13:04   #95
kailashnj's Avatar
Thanked: 275 Times
Hi Riju,
I am more concerned with the reducing gc. With 195, the current GC of the car would reduce. Hence I am now planning to go for the stock config of 185/65 R14 only but in potenza GIII tyres.
Old 5th October 2008, 10:33   #96
Thanked: 21 Times
I dont think that is actually a cause of worry. GC would reduce by 3.25 mm and would you notice that?
Old 5th October 2008, 11:51   #97
kailashnj's Avatar
Thanked: 275 Times
Crazydiablo,
GC of baleno is anyways low and it ends up scrapping many speed breakers in Mumbai. With the reduced GC I fear it will scrap all those which it currently does not. Correct me if I am wrong.
Old 5th October 2008, 12:54   #98
benbsb29's Avatar
Thanked: 3,478 Times
Some pics of a Baleno which i had clicked in my office parking lot.
What size are those wheels?
Old 5th October 2008, 12:57   #99
Akshay1234's Avatar
Thanked: 6,668 Times
benbsb29 - those look like 17s.
Old 5th October 2008, 14:28   #100
noidaboy's Avatar
Thanked: 260 Times
Awsome looking baleno, But 17"s will cause performance,and ride quality looses,but these rims seem worth it
noidaboy is offline   Reply With Quote
Old 5th October 2008, 15:26   #101
kpzen's Avatar
Thanked: 1,598 Times
Benny
Killer looking Baleno...BTW What was the color of Baleno? Black or maroon?
Old 5th October 2008, 17:26   #102
rjstyles69's Avatar
Thanked: 789 Times
kpgetz I hope you haven't gone color blind , its a maroon colored Baleno .
Old 7th October 2008, 10:44   #103
Thanked: 21 Times
Crazydiablo,
Dont be paranoid about a 3mm difference. You would really benefit from the 195s, but ultimately its your choice.
Old 7th October 2008, 14:23   #104
desigNation's Avatar
Thanked: 46 Times
my advice,if you traveling long distance,dont use a rim beyond 15",195-55-15,would be perfect.if the roads are bad,205-50-15 wont take the beating.
desigNation is offline   Reply With Quote
Old 11th October 2008, 00:48   #105
Thanked: 135 Times
I have a Baleno Vxi 2006 that came with 14" Alloys. I had Goodyear NCT5 Eagle 185/65/R14 Tyres . I usually travel a lot between Gurgaon and Chandigarh and sometimes even to interior Punjab. The Goodyears were okay till 20K after which they started making a lot of noise and then went completely out of balance. No amount of wheel balancing could get them balanced properly and inspite of best efforts I had to replace all 4 at 25K.
I now have Yokohama ES100 195/60/R14 tyres and I am impressed. Earlier I could not go above 130 with the Goodyears, the steering used to feel lifeless and disconnected. With the Yokohamas I have touched 152 just 2 days back on my return from chandigarh and the steering was rock solid. No floating feeling and the car was stuck to the road all the way.
I recommend these for your car. 14" is perfect for stability and ride comfort and there is no chance of the tyres touching the mudgaurds even with full load or full steer.
I paid Rs 3450/- per tyre (Total of 13K) for the Yokohama Tyres and got the wheel alignment and balancing free of cost here at Gurgaon from T-Mart Tyres and Wheels.
Manik
Traveler is online now   Reply With Quote
Kenwood AMP/ICE advice plz plz cuteavaya In-Car Entertainment 9 10th January 2007 11:52
Accessories in Delhi for the Baleno..plz help imjimmy Modifications & Accessories 3 10th December 2005 23:12
A very very very hot Murcielago. v12 The International Automotive Scene 18 14th July 2004 22:04
