Old 14th February 2008, 16:56   #16
Maibaa's Avatar
Thanked: 39 Times
Originally Posted by nishantgandhi View Post
I thought air was free!
True! But remember you are paying for the service. Not for the air.
Maibaa is offline   Reply With Quote
Old 14th February 2008, 16:59   #17
Xehaust's Avatar
Thanked: 74 Times
Check it every 2 weeks as people have stated.
A good point to note would be to fill in 1 or 2 psi extra in cold weather because when its cold, tyres do not heat up much and the eir does not expand much, so you should fill a little extra to compensate. In hot weather, fill factory recommended pressures as the climate in India is really hot and tyres heat up rapidly and air expansion takes place.
Hope this helps
Xehaust is offline   Reply With Quote
Old 14th February 2008, 17:04   #18
praveen_v's Avatar
Thanked: 120 Times
OT: A little bit off topic but i thought this will help many people also
I am thinking of getting a foot pump to fill air so that I need not rely on petrol pumps for air. But i'm not sure as to whether I'll be able to pump into car tyres using foot pump. I dont want to buy it and then finding that i'll not be able to do it.
So can I use a foot pump for the car?? How much will a standard foot pump with preassure meter cost?? If not any other suggestions for doing it at home?? (Other than getting compressors, of course!!)
praveen_v is offline   Reply With Quote
Old 14th February 2008, 17:18   #19
PatchyBoy's Avatar
Thanked: 1,397 Times
Guys,
I bought a dial type pressure guage. Every Sunday, it is time for interior cleaning, fluid level checks and tyre pressure check. If I find the pressure a bit low, I either pump it up using my battery operated pump, or get it corrected at the pump, depending on how soon I need to fill up.
Cheers,
Rajan
PatchyBoy is offline   Reply With Quote
Old 16th February 2008, 09:23   #20
praveen_v's Avatar
Thanked: 120 Times
Duh.. No one uses their own foot pump to maintain the car's tyre pressure???
Old 17th February 2008, 20:47   #21
Thanked: 160 Times
Why do u say that ???
It is very helpfull to have one incase in the highway if u don't find a petrol pump or puncture shop this thing will come handy.
We keep it in our car for emergency, it costs hardly Rs.250-300.
One time investment
gowda79 is offline   Reply With Quote
Old 19th February 2008, 08:40   #22
praveen_v's Avatar
Thanked: 120 Times
One time investment
hey, thanks for the Info. I have seen people use it for two-wheelers. I was going to buy one and was wondering if I can use it for car tyre too. You can refer to my other post in this thread a little below.
One small question though. Will you be able to pump a fully deflated tyre with the foot pump??
Old 5th April 2008, 15:42   #23
I've used a foot pump only to fill cycle tyres. It does the job but takes really long. If you're up to it then yes you can fill a deflated tyre with a foot pump. Side effects would be aching calves and thighs!
blitzkrieg is offline   (1) Thanks Reply With Quote
Old 10th April 2008, 12:05   #24
Wolffe's Avatar
Are the Petes AirCheckers worth it?
Wolffe is offline   Reply With Quote
Old 10th April 2008, 12:46   #25
srijit's Avatar
i had a footpump, and it does take a bit to inflate a car tyre. Cycle tyres are OK, i guess. Make sure that there is another person who can help you pump.
srijit is offline   Reply With Quote
Old 10th April 2008, 18:21   #26
Chevy_lover's Avatar
Thanked: 121 Times
I check my tyre car's tyre pressure whenever I fill fuel. It works out cheaper as the air is free in my regular HP pump in Pune Camp. But I sometimes tip the staff.
Right tyre pressure is very important for getting good fuel efficiency and also to avoid uneven wear and tear of tyres.
Please see the link below for more information.
Tyre Inflation
Chevy_lover is offline   Reply With Quote
Old 30th April 2008, 07:43   #27
mithun's Avatar
Thanked: 59 Times
Stay away from that. 100% waste of money.
Old 2nd May 2008, 20:40   #28
Alfa_Kilo's Avatar
Foot pumps usually have a pressure limit around 50-60psi, so they are compatible with most vehicles.
It is possible to fill air using a foot pump, I habe 235/75R15 tyres which I maintain ~27psi. It is not a difficult job to check pressure and air up weekly. Once the tyres had to be aired up from 10psi to 27, that took three guys a good 20min.
Foot pumps are generally more consistent than air fillers at fuel bunks.
Alfa_Kilo is offline   Reply With Quote
Old 2nd May 2008, 20:49   #29
Jaggu's Avatar
Thanked: 8,686 Times
Whenever i fill fuel (once in 2 weeks), which is in the morn before office. So cold air and higher density fuel. Alternate times fill up the spare also.
Before long trips, the previous day. 1Rs per tyre.
Old 2nd May 2008, 23:18   #30
BAKIYA_2K12's Avatar
i use nitrogen for the tyre and for month or two i use to check the pressure and it's still in the same psi
BAKIYA_2K12 is offline   Reply With Quote
How often should we change gear oil? zaks Technical Stuff 156 12th January 2016 16:31
Correct Tyre Pressures Kaizer Sozay Tyre & Alloy wheel Section 83 7th March 2015 19:56
tyre pressures for the drag paras211 Tyre & Alloy wheel Section 10 13th February 2007 23:54
Uneven tyre pressures Hells Bells Technical Stuff 8 13th November 2006 15:27
Tyre pressures for various performance tyres theMAG Tyre & Alloy wheel Section 1 17th June 2006 10:08
