Tyre & Alloy wheel Section Everything to do with footwear for your car!
Thread Tools
Old 5th February 2008, 18:14   #1 (permalink)
Ricky_63's Avatar
Default Tyre Upgrade AUDI A4
Hi
I recently bought an AUDI A4 2.0 TDi. It runs on Pilot Primacy Michellins 205/55/16. I was thinking of wider tyres (old habits die hard) as the wheel wells look like they could take in wider rubber.
I was considering YOKOHAMA S-Drive 225/50/16 which seems to be the perfect upgrade. My only concern is they may not scrape. Although none of my previous experiments failed me, but this is not a car I wish to take chances with .
Tyre Gurus please advise.
Thanks in advance
__________________
Everybody is entitled...... to an opinion !!
Old 5th February 2008, 18:22   #2 (permalink)
Steeroid's Avatar
You have VERY good tyres. Why do you want to upgrade?
If you must, the logical upgrades are Pilot Sport or Pirelli Pzero Rosso but for a 2.0 Diesel it would be an overkill IMHO.
__________________
Steer
Petrols Suck. Diesels Torque. Q.E.D
Steeroid is offline   Reply With Quote
Old 5th February 2008, 18:23   #3 (permalink)
akshay1234's Avatar
IMO just stick with these till(if) you get a remap. primacys are pretty good.
akshay1234 is online now   Reply With Quote
Old 6th February 2008, 14:35   #4 (permalink)
Ricky_63's Avatar
I agree that the tyres are good. I was talking of asthetics (filling in the wheel wells). I feel the wider rubber will make the car look more muscular
__________________
Old 6th February 2008, 14:50   #5 (permalink)
kpzen's Avatar
Ricky
The stock tyres are damn good.
In 225/50-16 u can get Yokohama S drives or Michelin PP2 but i think for an Audi u should look beyond these too.
__________________
Prajesh
ECLIPSEd
kpzen is online now   Reply With Quote
Old 6th February 2008, 15:59   #6 (permalink)
androdev's Avatar
no warranty issues with tyre upgrades?
androdev is offline   Reply With Quote
Old 7th February 2008, 09:26   #7 (permalink)
Ricky_63's Avatar
I certainly hope not. The upsize would be a calculated thing & not an overkill. I spoke to the Audi Showroom - they seem OK with it, but will still ask another time from the technical guys at the workshop.
__________________
Old 7th February 2008, 09:49   #8 (permalink)
Cyrus43's Avatar
when did you buy an AUDI???
moving up in the world i see..about the tires..i dont think tires are a part of waranty anyways
__________________
hungry BHPian
Cyrus43 is online now   Reply With Quote
Old 7th February 2008, 10:00   #9 (permalink)
iraghava's Avatar
Ricky, correct upsizes for your car are mentioned here:
https://www.team-bhp.com/forum/tyre-...-your-car.html
Download the excel file and go through it.
Before I suggest anything one question for you, what is rim width??
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Old 7th February 2008, 10:07   #10 (permalink)
Ricky_63's Avatar
Hi Cyrus
Got it on the 31st of Jan '08. I see you don't follow the What Car thread
As for the tyres, they are covered under warranty as I did get a replacement on all 4 tyres on my Octavia (Goodyear NCT 3's)
__________________
Old 7th February 2008, 10:24   #11 (permalink)
Hey, remember the BMW guy who had warranty issues after changing the tyres. That's not directly linked to tyres, I think xenons but there was some mention of tyres.
That's an expensive car and you should get 100% confirmation from the Audi guys that the warranty on the car stands valid after you upsize and they will not use that to deny you warranty on suspension and the overall car incase you run into some issues.
raul is offline   Reply With Quote
Old 7th February 2008, 10:44   #12 (permalink)
iraghava's Avatar
BMW has an issue as they fit Run Flat Tyres as stnadard fitment & object to people replacing them with Non-RFT's. Here the case is different as Audi does not fit RFT's on the A4.
Plus, all he's doing is increasing the width while keeping the OD within tolerances so I don't see a problem with that. All my cars have upsized tyres & since it's a reasonable & calculated upsize none of the companies have ever had any problems with that. But then, I've never owned an expensive car either!!
__________________
Old 7th February 2008, 12:07   #13 (permalink)
+1. You already have the right size + brand of tyres. No sense in upgrading.
__________________
Change the way you think, and watch the world change around you.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 7th February 2008, 12:33   #14 (permalink)
Iraghava, do you think I a mere mortal can deign to disagree with you on of all things tyres and upsizing. For me its very simple when it comes to tyres, Iraghava says, I do.
The poster sure is lucky to have both you and Kpzen on this thread and is certain to get some very good advice.
Old 7th February 2008, 15:30   #15 (permalink)
Ricky_63's Avatar
I had a chat with the BMW dealer about that particular car - I was "told" that the car had been extensively modified, hence the warranty being void.
In my case if I am changing to a wider width, I am ensuring that the overall diameter is remaining well within tolerances, hence should not pose a problem.
Thanks anyways
__________________
Thread Tools
Tyre Upgrade for Audi A6 tyres viper Tyre & Alloy wheel Section 4 31st January 2008 08:28
cedia tyre upgrade blue2ki Modifications & Accessories 3 25th September 2007 13:33
tyre upgrade Thomas T Modifications & Accessories 1 11th August 2007 23:50
Getz tyre upgrade srinath34 Tyre & Alloy wheel Section 3 16th March 2006 21:30
Help with right tyre upgrade. kb100 Tyre & Alloy wheel Section 8 27th February 2006 17:07
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
