Old 30th November 2014, 17:39   #346
el lobo 6061's Avatar
Thanked: 946 Times
Default re: Ford Fiesta : Tyre & wheel upgrade thread
Originally Posted by hothatchaway View Post
This query is regarding the Ford Classic whose official tyre specs are 175/65 R14. Is it possible to upgrade to 15 inch rims? If yes then what width and aspect ratio?
Ford Fiesta S came with 15 inch alloys 195 55 R15 rubber. But Fiesta Classic comes with a HPS which may become even harder with upgrade to wider rubber. Fiesta S had different HPS to deal with wider rubber.
My suggestion would be to stay put with stock size.
el lobo 6061 is offline   Reply With Quote
Old 15th December 2014, 08:06   #347
glenmz's Avatar
Thanked: 202 Times
Hi All,
As mentioned, upgraded my rides tyres from 175/65 to 185/65 r14s, Yokohama Earth 1s. The ride is harsher compared to the previous MRF's and I feel the tyre pressure has to be changed?
The current pressure that I maintain is 30 psi Front and 35 Rear. Should I go for a lower pressure for a softer ride?
Thanks,
Glen
glenmz is offline   (1) Thanks Reply With Quote
Old 15th December 2014, 08:18   #348
mayankk's Avatar
Thanked: 3,096 Times
Originally Posted by glenmz View Post
Hi All,
Thanks,
Glen
Maintain 30-32 in all four, you'll see a marked difference.
Why are you running 35 in the rear.
mayankk is online now   (1) Thanks Reply With Quote
Old 15th December 2014, 09:24   #349
batterylow's Avatar
Thanked: 591 Times
Hi All,
Thanks,
Glen
I made the same switch and the ride has improved, I guess the excess pressure is at fault. Please try 30 to 32 all around and revert on your experience.
batterylow is offline   (1) Thanks Reply With Quote
Old 15th December 2014, 12:28   #350
glenmz's Avatar
Thanked: 202 Times
The manual says so. 35 for normal load and 44 when full!!!
I should try this now.
glenmz is offline   Reply With Quote
Old 16th December 2014, 12:09   #351
XetaGLGRocks's Avatar
Thanked: 28 Times
I maintain 30psi for city and 32psi for long highway trips (with a full trunk). That should give you the coveted ride and handling.
XetaGLGRocks is online now   (1) Thanks Reply With Quote
Old 18th December 2014, 20:05   #352
Thanked: 690 Times
The recommended pressure on the driver side door says 30 psi all around if its city driving. With full load of 5 passengers and luggage, the recommended pressure is 36 psi front and 44 psi rear!!
I too changed the tyres on my new Classic 1.6 to 185/65/R14 Continental CC5 and the ride is definitely much better over bad roads compared to the stock MRF's. I maintain 30 psi all around.
abhinav.s is offline   (1) Thanks Reply With Quote
Old 19th December 2014, 11:44   #353
theredliner's Avatar
Thanked: 715 Times
Won't Ford void suspension and steering warranty for this? Is the dealer okay with changing tyre size?
theredliner is online now   Reply With Quote
Old 19th December 2014, 11:59   #354
batterylow's Avatar
Thanked: 591 Times
Talking by the book, yes Ford will void the warranty.
But I guess if one has a good rapport with the service center it is possible to still get things done under warranty.
Nonetheless, the better ride and handling afforded by the wider/better rubber offsets the Damocles sword of warranty forfeiture.
My car is out of warranty so it is immaterial in my context.
Old 19th December 2014, 12:16   #355
glenmz's Avatar
Thanked: 202 Times
Yup definitely depends on the rapport with the service center.
The suspension warranty I am told is over by about 35000 km. The upsize helps me cover Bangalores infamous speed breakers.
Old 19th December 2014, 16:18   #356
Thanked: 690 Times
I am not sure of this. I went to the SVC on the 4th day after taking delivery. The SA saw the tyres and asked me if I had changed it. When said yes, he did not say anything at that time. When walking around the service center i saw that they themselves are advertising the upsizing and its benefits (Board was from Bridgestone & the SVC carried a few tyres). They even described different types of up sizing as well (0, +1, +2). So they should not have an issue ideally but you never know how these SVC's work. As already mentioned by other BHPian's it would depend on the rapport with the service center personnel.
Old 27th December 2014, 08:28   #357
Thanked: 685 Times
The stock MRF zv2k tyre doesn't show the expected wear for the 42k km done, but the hard(ended) rubber is giving me frequent punctures.
Ford Fiesta : Tyre & wheel upgrade thread-imag0024.jpg
ramzsys is offline   Reply With Quote
Old 6th February 2015, 11:08   #358
FordDodo's Avatar
Thanked: 139 Times
My Fiesta Classic's trye nightmare continues.. At 26k on the odo, with stock GoodYear tyres, 3 out of 4 tyres have screwed up. The tyres have lost the shape i.e the surface isn't flat and bulged at some places with even treadwear indicating tyre issue and no mechanical issue.
FordDodo is offline   Reply With Quote
Old 6th February 2015, 12:02   #359
WasavaTyres's Avatar
Thanked: 184 Times
Why don't you have them inspected by a Goodyear service engineer ? It may be a deformation fault. Call 1800-266-6767 and give them vehicle details and tyre serial nos. A service engineer will call you back to arrange the inspection at a tyre store closest to your location.
WasavaTyres is offline   (1) Thanks Reply With Quote
Old 11th February 2015, 11:17   #360
FordDodo's Avatar
Thanked: 139 Times
Thanks for the info! Just registered a complaint.
Today I removed one of the tyres and rolled it on a even floor. The tyre rolled over in zig zag manner!
Ford Figo : Tyre & wheel upgrade thread breakneck Tyre & Alloy wheel Section 505 23rd March 2017 14:31
Ford Ecosport : Tyre & wheel upgrade thread dish Tyre & Alloy wheel Section 191 22nd March 2017 20:12
Toyota Etios & Liva : Tyre & wheel upgrade thread nkrishnap Tyre & Alloy wheel Section 55 22nd March 2017 12:27
Ford Figo / Aspire : Tyre & Wheel Upgrade Thread arunphilip Tyre & Alloy wheel Section 101 22nd February 2017 21:48
Ford Ikon : Tyre & wheel upgrade thread dkhatau Tyre & Alloy wheel Section 28 22nd February 2016 10:28
