Old 20th May 2016, 10:44   #406
akshay380's Avatar
Thanked: 387 Times
Default Re: Ford Fiesta : Tyre & wheel upgrade thread
Couple of queries.
1. Can someone post photos of 185/60/R14 fitted to car? I am curious to know if it will look too small in wheel well.
2. Whats the recommended pressure for MRF Z2VKs running stock on Fiesta?
akshay380 is offline   Reply With Quote
Old 2nd August 2016, 18:45   #407
jprash75's Avatar
Originally Posted by akshay380 View Post
Couple of queries.
With 185/60 R14, the circumference will reduce, and it will look a wee-bit smaller in the wheel well.
If you're planning on an upsize on the stock rims, I'd recommend you go for 195/60 R14, which gives the car a much more planted stance; not to mention the obvious improvement in ride & handling. The resulting circumference increase (and speedo error) is only 1.1%, which is well within acceptable limits.
Here's what mine looks like with 195/60 R14 (Bridgestone Turanza AR10).
Ford Fiesta : Tyre & wheel upgrade thread-dscn0241.jpg
jprash75 is offline   (1) Thanks Reply With Quote
Old 2nd August 2016, 19:00   #408
Thanked: 33 Times
Try 185- 70 R14 and you can the difference. No more under body hits as clearance will get a slight enhanaced but not that easily noticeble . I have added Michelin XM2 and the car is now buttersmooth on big potholes too. I just love that.!!
Bibin is offline   Reply With Quote
Old 2nd August 2016, 19:16   #409
akshay380's Avatar
Thanked: 387 Times
Thanks for the reply. Btw I upsized to 185/65/R14 two months back and happy with the result. Went with Yoko Earth1. I'll run this set for a wjile before upgrading to 15" rims. That'll suit 195 profile more
Old 2nd August 2016, 19:16   #410
Thanked: 33 Times
Pfa the images after upgrading with 185-70 R14 Michelin Energy XM2 tyres
Ford Fiesta : Tyre & wheel upgrade thread-img_20160516_161047.jpg
Ford Fiesta : Tyre & wheel upgrade thread-img_20160516_184342.jpg
Old 3rd August 2016, 10:18   #411
KiloAlpha's Avatar
Thanked: 1,308 Times
Couple of queries.
I had 185/60R14 fitted to my old Figo for the longest time. Search the forum for pictures - there will be plenty of them peppered about. I am active in Bangalore T-BHP meets, and those threads invariably have a lot of pictures .
EDIT: http://www.team-bhp.com/forum/tyre-a...ml#post2409216
KiloAlpha is offline   Reply With Quote
Old 3rd August 2016, 15:04   #412
jprash75's Avatar
Great! The 185/65 definitely fills the wheel arches much better than 195/60. Came to know vnabhi had also done the same. And you are right about the 195 tread being better suited to 15 inchers. Happy motoring!
Old 25th August 2016, 11:34   #413
I need to replace the tires of my 2011 Ford Fiesta 1.6 Sxi. I went through the complete thread on various options and experiences of owners on this. I request owners to share their long time feedback on their upgrade choices that they would have made a while ago.
We can leave the upgrade to the stock size that is 175/65/R14. I request feedback on the following:
1) 185/65/R14 - I could see many went for this. This results in 6.5 mm increase in height. In this thread, I read about one case of the tire touching the wheel arches and damaging it, though the owner clarified it was specific to his car and that too on the LHS - no further info on what happened later. Another clarified, the handling was not as surefooted as it was with stock size, when driven speeds above 120KM per hour, though there were suggestions on tire pressure change, to solve that. Rest all had only positive things about this size upgrade, though this would result in 2% error for speedometer and odometer.
2) 185/60/R14 - very few seemed to have gone for this, though no negative reviews for this size. This is closest to the stock size, but I am not keen on this since this reduces the stock size height by 2.75 mm and I am keen for upgrade that will give a higher clearance, to tackle perennial bad roads of Bangalore.
3) 195/60/R14 - few went for this and had only positive things. While this gives a wider tire, gives only 3.25 higher ground clearance, with 1% error in speedometer and odometer.
My preference is to run without any issues and without compromising the terrific handling that Fiesta gives, with better ground clearance to tackle bad Bangalore roads. Tire noise and mileage is not an issue and also can live with the 1-2% errors.
Also while most preferred Michelin and have good feedback, I want to know if main criterion is to tackle bad roads of Bangalore, is Bridgestone better than Michelin tire?
Please share what is the recommended tire pressure for these sizes, when driven alone and when driven with 4 co-passengers and full boot load.
Please share your long term feedback and advice. Thanks, for your time and inputs!
sivaselvam is offline   Reply With Quote
Old 26th October 2016, 06:33   #414
This. You should look at Yokohama Earth1 for the rough roads. These have stronger sidewalls than Michelin XM2s (which are more comfortable as its softer). You can't go wrong with either of these two tyres.
SoumenM is offline   (1) Thanks Reply With Quote
Old 17th December 2016, 22:31   #415
Thanked: 61 Times
Has anyone put 16" wheels on the fiesta?
Vysakh is offline   Reply With Quote
Old 17th December 2016, 23:30   #416
devilwearsprada's Avatar
Thanked: 595 Times
Hi yes!
Just got the last set of Lenso PDX in India last week at a steal. Rs.32000 for a set of 4
These are paired with ADrives at 205/50/16. The stance is good, hoping for it to be better with the H&R springs coming soon, and the handling is far better than the stock.
Ford Fiesta : Tyre & wheel upgrade thread-img_0713.jpg
Ford Fiesta : Tyre & wheel upgrade thread-img_0710.jpg
devilwearsprada is offline   Reply With Quote
Old 18th December 2016, 10:07   #417
quakerme's Avatar
Thanked: 56 Times
Originally Posted by devilwearsprada View Post
Hi yes!
Attachment 1586019
Attachment 1586020
Fiesta looks nice with the new wheels, hows the ride comfort? I have a global fiesta when checked the feasibility of putting a 16inch the tech guys at ford says it will hit the sidewall and the ride comfort will drastically reduce pls let us know ur review.
quakerme is offline   Reply With Quote
Old 18th December 2016, 12:34   #418
Thanked: 595 Times
The ride comfort is 10-15% lower, thats it.
devilwearsprada is offline   (1) Thanks Reply With Quote
Old 18th December 2016, 21:08   #419
Thanked: 61 Times
Hi yes!
Attachment 1586019
Attachment 1586020
That looks sweet.
How's the GC with the 205/50/R16? Does it scrape anywhere?
Would be almost an inch dip from the 195/65/R15 I currently use. Side skirts too
Old 19th December 2016, 03:21   #420
Thanked: 595 Times
That looks sweet.
Nope, doesn't scrape anywhere atleast for me. The springs are coming, then it will scrape but you need to be patient with a lowered ride!
Ford Figo / Aspire : Tyre & Wheel Upgrade Thread arunphilip Tyre & Alloy wheel Section 127 24th May 2017 08:28
Ford Ecosport : Tyre & wheel upgrade thread dish Tyre & Alloy wheel Section 204 18th May 2017 14:29
Ford Figo : Tyre & wheel upgrade thread breakneck Tyre & Alloy wheel Section 512 9th May 2017 08:55
Ford Ikon : Tyre & wheel upgrade thread dkhatau Tyre & Alloy wheel Section 28 22nd February 2016 10:28
