Old 13th December 2008, 23:29   #76
sbala's Avatar
Thanked: 158 Times
Finally settled with Bridgestone Turanza ER60 175/65/R14....
i was deliberate to get Michelin Energy XM1 Plus.. But the dealers near by my area didn't had stock :( and i was looking for 8 tyres (4 for me and 4 for me Brother-in-law).. So had to settle with Turanza ER60 since my car badly needs a tyre change.
Price per Tyre: Rs.3325/-
Dealer : Sri Venkateshwara Tyres, BTM layout, Blore
The dealer charged me Rs.500 for Wheel alignment and balancing for both the Fiesta's.
So - howz the car now?
Its Good. Road noise has reduced. Ride quality has improved, but not sure it might be due to brand new tyres
Will post more about the new tyres..
sbala is offline   Reply With Quote
Old 20th December 2008, 22:42   #77
ariendj's Avatar
Thanked: 83 Times
i guess the stock tyres on fiesta are MRF ZV2K,how much could i expect to get on brand new ones that has been driven for just 50 kms??
and what about michellin XM1+ 185/65 R14??how much would brand new costs?
ariendj is offline   Reply With Quote
Old 20th December 2008, 22:56   #78
kpzen's Avatar
Thanked: 1,649 Times
185/65-14 XM1 + should be around 3600 per tire
The best deal for the stock tires would be 2000 per tire.
Old 20th December 2008, 23:08   #79
zuch's Avatar
Also note that the stock size of Fiesta's tyres is 175/65 R14. So the size that you have selected will give you 2.2% speedo error (you can check on Tire size calculator).
The correct upsize would be 185/60 R14 and the price of these would be higher than 185/65s.
zuch is offline   Reply With Quote
Old 20th December 2008, 23:33   #80
ariendj's Avatar
Thanked: 83 Times
i did inquire about the XM1+ at the mentioned size and was told 3750 and my stock would be taken for 2k.
btw thanks for the quotes cause i badly needed them urgently
i did look in both these tyre profiles and seemed 65 was preferred over 60 by many.thats why im planning to get the 185/65.
anyways il inquire about the above mentioned tyres too.
i was also looking at 195/60 R14 or going to 15" but im sure the FE will go down.i was curious to know whether the FE drop is comparable to each other in the above 2 profiles!!
Old 20th December 2008, 23:37   #81
kpzen's Avatar
Don't worry !
185/65-14 won't cause any problem in Fiesta.
Old 20th December 2008, 23:48   #82
abhinav.gupta88's Avatar
Thanked: 310 Times
I guess one can expect a 0.5-1 kmpl drop in efficiency with a conversion from 14" to 15"
I too am facing the same difference. ( Hovers between 11-11.5 as compared to 12 earlier- NHC VTEC)
Old 20th December 2008, 23:54   #83
ariendj's Avatar
Thanked: 83 Times
is it true that warranty gets void if the tyres are upgraded to 15"?
(stocks are 14" except for fiesta S type)
Old 21st December 2008, 00:05   #84
zuch's Avatar
I had been doing a similar research about tire sizes for my fiesta a few months ago. I stopped at the point when I was told by Ford that warranty would get void on tire change. And I didn't want to lose out on the money I've spent on extended warranty.
By the way I've been running on stock tires for 6 months and its not too bad. Depends on how you drive. I'm a sedate driver and I drive mostly in the city. So far I've not felt the need to change my tires.
Old 28th December 2008, 22:04   #85
lamborghini's Avatar
Thanked: 1,642 Times
Update:
Getting the Fiesta's tyres changed soon.
Lot of jhol happened when I was in the U.S, which I wasn't informed about.
When I landed, I saw new MRF ZVTS (Yes the tube ones) on the car and I was like ***!
Then I found a pair of new Goodyear Eagle NCT 5's, 185/65R14 meant for the palio waiting to be put on and I am thinking of a swap, as the Palio is going to be parked more than it will be used by me and the fiesta is the daily drive.
Even though the NCT 5's aren't as good as the Yokohama's, they will definitely do the job well, right?
Alloys will take some time though. Maybe another 6 months, Maybe longer. And for all I know, they might not even happen if we decide to upgrade the car.
lamborghini is offline   Reply With Quote
Old 28th December 2008, 22:30   #86
iraghava's Avatar
Thanked: 156 Times
NCT5's will cope fine. Will be noisy though.
Old 3rd January 2009, 17:51   #87
ariendj's Avatar
Thanked: 83 Times
what is the idle air pressure to be maintained for 185/65 R14!!
Old 7th January 2009, 23:17   #88
ariendj's Avatar
Thanked: 83 Times
guys any ideas about pressure to be maintained in 185/65 R14.i had kept it at 30psi but the ride feels harsh on the otherwise smooth XM1+.i feel there is a lot of road noise heard inside the car too.
Old 8th January 2009, 01:38   #89
iraghava's Avatar
Thanked: 156 Times
Try 28 psi and see if there's a difference. Remember to also check the pressures when the tyres are cold.
Old 9th January 2009, 13:47   #90
Jo-G's Avatar
Thanked: 41 Times
Default Experts please help
I have a Fiesta 2007, SXi TDCi with stock tyres (MRF) and alloy wheels (Ford 9 spokes). Tyres have run 31000 KMs, I would like to upgrade the tyres after some time but would like to see if there is any upgrade that can increase the ground clearance. Could any of the experts help?
Will changing the tyre size increase the ground clearance?
Do I need to upgrade the alloy wheels too?
Thanks for your help in advance.
Jo-G is offline   Reply With Quote
Ford Figo : Tyre & wheel upgrade thread breakneck Tyre & Alloy wheel Section 518 15th June 2018 11:11
Ford Ecosport : Tyre & wheel upgrade thread dish Tyre & Alloy wheel Section 239 27th May 2018 05:32
Ford Figo / Aspire : Tyre & Wheel Upgrade Thread arunphilip Tyre & Alloy wheel Section 168 17th April 2018 17:01
Ford Ikon : Tyre & wheel upgrade thread dkhatau Tyre & Alloy wheel Section 28 22nd February 2016 10:28
